How do you decide which hubs to buy?
Quoted: 14 Post(s)
I'm looking at Enves, but having trouble deciding on the hubs. How do you pick them? Where can I read up on them (google is my friend, but has been tough in this regard)? What do you look for in a hub? How do you know if better hubs are worth the extra money?
The ones I am comparing are:
DT 240 $0
Chris King R45 +$158
DT 180 +$600
DT 240 $0
DT 180 +$600
Bikes: 2007 Pergoretti Marcelo
Bikes: Spec Roubaix, three Fisher Montare, two Pugs
Quoted: 39 Post(s)
there isn't much to go on beyond Google, recommendations from friends and personal experience. For instance, I've built exactly one set of wheels, but I have years of experience adjusting standard cup and bearing hubs so in my case I was very open to buying a quality hub with replaceable bearings that I knew I could easily maintain. With that in mind, with recommendations from friends and the net I simply bought some Ultregra hubs and built my wheels around them. Easy. If I were building wheels for cyclocross and wanted cartridge bearing wheels that would better withstand mud and such, I would have had to rely more heavily on the net and I would simply have limited myself to hubs that were well known enough to have reviews and were, in fact, known to be excellent. If a brand like Enves had insufficient reviews in order for me to feel rock solid about their reliability, they would not make it to my final list. There are plenty of well known hubs out there that are popular and well established as reliable. I see no reason to look for an unusual, uncommon, specialty hub that has no solid, well tested track record.
Obviously the critical place to start is what your needs are and what kind of hub might meet those needs, ie some hubs are best for "never have to touch it" like Phil Wood, or "easy to repair by popping in a new cartridge" or simple and easily adjustable (like a Shimano cup-and-cone hub).
Based on blacksquid's reply and everything I've heard, between the three choices above you're best off with the Chris Kings. The DT240s are well regarded hubs, the DT180s seem to be considered over-priced (I've neither ridden nor seen them), and the Chris Kings are generally regarded as excellent in quality and performance. Were I building an enve wheelset for myself, they would almost certainly be number one on my short list.
Quoted: 14 Post(s)
DT 180
FWB Opinion: This is one of the hubs in this review that I just don’t quite get. The 180 has a carbon barrel in place of the alloy. That and the bearings are the only weight savings for this hub vs the 240 front hub. So for more than double the price of the 240 hub you get a 8 gram weight savings and ceramic bearings. But you also can’t get it in black.
Ron’s perspective: I guess this is a good hub for those who want the best and most expensive DT hub. If you like the DT180 rear, then this is the front hub that matches it.
Blacksquid - did you read the reviews? The one above is priceless!! Thanks.
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
Hubs are basically jewelry. What kind of jewelry do you prefer? Do you wear a Tag or a Casio? Honestly, it doesn't matter. You may be budget oriented..or may like to have your color's match and a certain look. Performance won't be much different...or even durability. Weight doesn't matter so much close to the axle...even though it may contribute a few meaningless grams in static weight to your bike. White makes a good value hub and you didn't have them on the list.
Bikes: are better than yours.
Telemachus has, indeed, sneezed.
Quoted: 5890 Post(s)
Liked 3,475 Times
One thing you have to give Shimano credit for is retaining a good design for a long time. I have a Shimano 105 hub that was original equipment on a 1993 bike and I was able to replace the cones last year without any trouble.
Bikes: Mikkelsen custom steel, Santa Cruz Chameleon SS, old trek trainer bike
Quoted: 70 Post(s)
Liked 6 Times
I would go Chris King, but I have always wanted a set of blue R45's to match my headset...
My personal choices from cheapest to most expensive would be:
Novatec 482/291
Shimano Ultegra (if you just want durability over weight savings)
White Industries T11 (or H2/H3 if you can find a set and you aren't going with 11s)
Shimano DA
Chris King R45
Now, since you are looking at Enve rims I would think the King would be in order, but the DA or White would not be out of place, either.
DT hubs never impress me. Between their price and geometry I think there are always better alternatives. Although I only look at weight after checking every other spec. To me a ~300-250g rear and ~130-100g front are more than acceptable.
Novatec 482/291
Shimano DA
Chris King R45
Of the 3 listed, go with CK. Their stuff is always very well built. I've never had happy results with DTSwiss hubs.
Some sort of pithy irrelevant one-liner should go here.
Quoted: 14 Post(s)
Thanks for the info. Just FYI the listed hubs are the manufacturer options on the Enve 6.7s. Just those 3. Looks like CK is the best bang for the buck.
Ah, I see. You may know this, but Enve also sells their rims alone. It may not be a bad idea to send an inquiry to Psimet or wheelbuilder.com to see some options and get hub recommendations based on your preferences.
Quoted: 14 Post(s)
I do know, but I don't have enough of a preference to get into it. I like the idea of a factory built wheel from them. Thanks for the heads up though.
Falls Downalot
Bikes: Now I Got Two
Quoted: 5 Post(s)
If I was springing for new Enves, I'd go with the newest Alchemy hubs to maximize my bling quotient. Otherwise, Novatec (in the SL version) or BHS hubs are great value for the money. If you want the Enve-built wheels, then CK R45 is the sweet spot from those three options. My opinion only, so it is pretty much without merit.
Bikes: Specialized Sirrus Comp
DT 180
Visit my blog -->MyOrangeBike
"There is love and there is work, and we only have one heart." Edgar Degas
Quoted: 14 Post(s)
But if you want a good noise, try mad fibers. I've ridden them and I can make them bark in a sprint. Literally, the sound is like a barking dog.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
Also look into White Industries, they make fantastic hubs that are less expensive then CK and at least as good.
Quoted: 14 Post(s)
