No Quick Release Wheel in Salsa Vaya
Quoted: 17 Post(s)
I just noticed no Quick Release Wheel in front of Salsa Vaya 2019. The back has the Quick release lever. Any idea why this common feature was not provided? Thanks
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Thru axle?
From the 2019 Vaya build kit
https://salsacycles.com/bikes/vaya/2019_vaya_105
I think all the carbon forks on the Vaya were thru axle, while the steel forks (no longer offered) were QR.
Likes For katsup:
Thru axles are supposedly better at handling the braking forces that come with disc brakes, especially in the front. While highly unlikely, it is possible for these forces to cause a quick release wheel to come undone. I don’t know why Salsa didn’t just go with thru axles on both front and rear on the Vaya.
Expired Member
Liked 5,441 Times
You are fortunate they stepped up to at least a front thru axle. QRs and disc brakes are an unhappy match, especially on the front.
Most folks haven’t either. But the internet is famous for people repeating what someone else says without fact checking or trying it themselves. Cycling is no exception. 90% of the opinions online are just that, opinions.
Expired Member
Liked 5,441 Times
My experience with QR and discs was that the caliper often needed to be realigned when the front wheel was removed/replaced. A small variation that would be acceptable with rim brakes would cause rubbing with the discs. Not a safety issue but an annoyance.
Quoted: 1873 Post(s)
Liked 692 Times
That's literally never happened to me once. I wouldn't group all QR disc setups into the same bunch.
2019 Salsa Warbird
2019 Salsa Warbird
Expired Member
Liked 5,441 Times
Good to hear! FWIW, it doesn't seem there will be any question going forward. Seems as if manufacturers are going to T/A when their stock of older frames is exhausted.
Quoted: 86 Post(s)
Liked 51 Times
I have a 2014 Vaya with discs and QR F&R, and I speak from personal experience when I say I loathe QR and disc. The steel fork on that bike flexes and causes brake rub in most corners. Also it winds up and judders under hard braking. Would an equivalent thru-axle steel fork rub less - yes. Would a rotationally-stiffer QR carbon fork rub less - yes. Would a stiffer carbon TA fork rub - probably not ever.
Do note that I'm 200+ lbs, and most of my riding on that bike was with 50+ lbs of gear. If I take off the luggage and lose 50 lbs, no problem LOL
I've only experienced judder with a cantilever bike, but I didn't have the threaded headset snug enough.
Quoted: 232 Post(s)
Liked 146 Times
I remove my wheels quite a bit as my 650b gravel bike also folds.
Using TPR Spyre which are dual actuated cable brakes so I'd expect it to be better than one sided actuation of many of the other cable disc brakes.
I have not experienced such a problem with QR and disc brakes.
Bikes: 2014 Trek Crockett 5, Crockett 7, 2016 Specialized Crux E5 Sport, 2016 Salsa Warbird 105, 2017 Trek Boone 5, 2019 Trek Checkpoint ALR5, 2019 Trek Checkpoint SL5, 2021 Trek Checkpoint ALR5, 2023 Trek Checkpoint SL5
Quoted: 18 Post(s)
Liked 13 Times
I've had the same issue with my 2016 Specialized Crux. A definite huge annoyance.
My other disc equipped bike has QR and rarely has any rub. If it does, it's got mech discs so a few clicks fixes things.
Randomhead
Liked 3,699 Times
I like TA in theory, but my only bike with TA front and rear has annoying skewers. The Fox skewers are ridiculous, I had to go watch a youtube just to figure out how to take them apart. And the Salsa one on the back is nearly as bad, it combines a QR with a TA and I never seem to be able to get it right. I don't quite see why they aren't all like the DT Swiss style where you just tighten down the skewer and go.
My first gravel bike, Giant TCX SLR 2, had mech discs and QR skewers. It was a bit fidly to get the wheels like up perfectly to avoid any issues. My new gravel bike, Niner RLT 9 RDO, has thru-axles with 15mm front and 12 mm rear. They are bolt on thru axles, no QR mix levers. They are quite solid and I've had zero alignment issues even with some very heavy off road riding. With a 15mm front, the fork is rock solid.
Quoted: 4806 Post(s)
Liked 3,932 Times
(I will forever be puzzled why they didn't just mount the caliper in front, similar to the rear. Then the same forces are pushing the fork down harder onto the axle. I know one of the thoughts with mountain bikes was less likelihood of snagging the caliper on brush, etc. but on the road?)
Ben
QR and disc brakes are fine with the right dropout orientation. TA is in the same safety hedge that tapered steerers and full-carbon forks are currently a part of.
There is no mechanism in TA that creates repeat-ability of axle placement and subsequently, rotor/caliper alignment. TA has erroneously been given credence for something more to do with being paired with hydraulic discs than anything else. If you're having an issue with caliper/rotor alignment the answer is to witness mark the hub locknuts and place them in the same orientation each time the wheel is installed - same for both QR and TA.
I have several bikes with QR and a few with TA, and I’d take TA over QR any day.
Expired Member
Liked 5,441 Times
I won't pretend to be qualified to discuss the physics involved in either system, but it seems as if folks who are (manufacturers) have moved to TA for discs. I'm happy with QRs on my rim brake bikes and the TA on my one disc brake bike. This will soon be fodder for C&V discussion
Agreed. There’s no play in a properly set up TA and good hub. I have both QR and TA, and given the choice I’d always choose TA for security. Also, good luck finding any decent high end disc bike that’s still running QR’s.
Quoted: 1218 Post(s)
Liked 298 Times
the advantages of having precision steering from a thru axle far out weighed the annoying factor of misaligned brakes of the QR & disc brake marriage.
as in even if QR worked perfectly every time, I'd still want thru axle. Once you have experienced it going back to QR is super hard!! I'd give up disc brakes and go back to rim brakes if I had to have a QR fork.
Physics be damned. I just know what is nice, and what is annoying.
Likes For Metieval:
Liked 298 Times
Only an Issue when it comes to upgrading wheels. and then dealing with end caps etc.....
Or worse. People like TREK selling Boost spacing QR rear hubs. Now try to find an Upgrade boost spacing QR hub.... (a hub is possible out there, but a premade upgraded wheelsset, isn't going to happen)
Personally I won't buy a new bike at new bike prices unless the entire thing is updated.
