Hi, anyone know how to remove this?
Hi, I need help, anyone know how to remove this? I need to change the PAS system sensor which is damage. I would like to know how remove this? Do I need a special tool to do that? If have tell me which tools can do? Can I use bike bottom bracket tools to removed it? The picture of the tools is below. Your help will be very much appreciated. Thanks, you.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
To help you, the experts here need more information. What brand PAS? Bottom bracket or crank/magnet? Picture?
You're new here and can't post a pic til your tenth post. For now, you can take a picture upload it to google pics, and then post a distorted url, for example
https colon double slash photos.google.com/photo/AF1QipO800dlhy_2E6cKZ5HSaxs9A0MzUqgkJlYQJQxi
This will allow us to see it.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Until you can post a photo, give us a "word picture" -- write a detailed description of what you see. It's like a puzzle and that's always fun.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
You might have better luck here.
https://www.bikeforums.net/electric-bikes/
eBikes aren't very standardized so without a lot of good pictures or the bike in front of me I can't be of much help. I'd recommend contacting the manufacturer to see if they have a more detailed service document for replacing the PAS sensor on your bike.
Quoted: 18378 Post(s)
Liked 4,512 Times
@ebikebeginner's Album:
https://www.bikeforums.net/g/user/511679
https://www.bikeforums.net/g/album/16586416
There is also a photo of a Shimano style splined square taper bottom bracket and tool. And, that tool should be good for that bottom bracket. Let's see, pedals go right=right, left=left. The bottom bracket is the opposite, so right hand threads on the left, and left hand threads on the right.
Liked 4,512 Times
Looking at your electrical connectors, the triangles are likely the key to getting them apart.
Do you have a loose connector from the spare part that you can inspect?
I'd first try squeezing in on both triangles, then see if the plug will separate. If that doesn't work, possibly gently pry out on the triangles.
Keep in mind, plastic connnectors often get brittle as they age, and those little catches have a bad habit of just falling apart. I.E. Be gentle.
