no valve caps?
Quoted: 7 Post(s)
no valve caps?
Seen a lot of people recently with no valve caps. Is it a new fad or just that they are unnecessary??
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
They are unnecessary. Their sole purpose to protect the tube from puncture while in the box or your pouch. Once tubes are mounted, toss the cap.
Bikes: Helix, HonkyTonk, NailTrail
Odd. Except for newbies that just took their bike home from the showroom floor, I've never seen anyone else use them.
Bikes: Colnago CX-1 Record 11sp. Carbon Epic expert 29er, Claud Butler Dalesman. Proflex X-px Works, Cougar 653. KHS Montana Pro, Hercules Alassio. Ammoco Monte Carlo F/SS. Corratec Superbow Fun 29er. Claud Butler Midas. Kenisis T2. Peugeot Perthus.
Well imo they are necessary, they protect the valve and keep it clean, i think it's more likely to be laziness/bad practice/loss of cap.
Fred-ish
Possibly useful with schrader valves because grit can get lodged in the valve and ruin the seal. I find them useless on presta valves and they simply add two steps to adding air to each tire.
Throw the stick!!!!
I remove the cap and valve nut when I install the tube and never use them again. They are both unnecessary.
I may be fat but I'm slow enough to make up for it.
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
½ Throttle
Bikes: 2006 Tirreno Razza 3.0, 2007 Schwinn DH 2.0
the only thing I find them useful is to signal which tubes are new and have no problems.
other than that i make jewelry out of them like watches, belt buckles, and fronts.
Liked 8,928 Times
Do you wear a bike chain bracelet? I was thinking of making one.
Likes For dspaff088:
Throw the stick!!!!
I just use my thumb to hold the outside of the tire when I push the pump / co2 on.
I need speed
Bikes: Giant Propel, Cervelo P2
Velominati Rule 60:
You are not, under any circumstances, to employ the use of the washer-nut and valve-stem cap that come with your inner-tubes or tubulars. They are only supplied to meet shipping regulations. They are useless when it comes to tubes and tires.
Bikes: Specialized Roubaix SL3, Lynskey Cooper CX
I find the nut very useful for inflating tires, and the cap keeps my valve from getting gunked up when riding in our daily summer rainstorms.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12780 Post(s)
Liked 7,695 Times
Peripheral Visionary
Liked 5 Times
Valve cap is useful as it keeps dust out. If dust gets into the inner workings, it might cause the valve to leak very slowly because the little dust particles might prevent it from closing completely.
If you take them off, wheels will all-encompassinlgy be lighter tho' .
Quoted: 4236 Post(s)
Liked 2,949 Times
As a schrader tube user with a very heavy bike, I've always used them and never seen the point in not using them as the weight difference is so small (my caps have the valve puller thing on them, not that I've ever used it but it's cool to have).
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
