Thread for Specialized Sirrus
#901
Quoted: 7 Post(s)
Well........as no one replied to my post asking if it was ok to attach a pannier rack to a carbon frame Sirrus.....I went ahead and risked it. So much for the "special relationship" between the UK and the US eh ??
I went for the Topeak Super Tourist Uni Pannier Rack as it has adjustable stays. And as the Expert Carbon doesn't have a seat post clamp I had to buy a M-Part seat post clamp with pannier attachment points. The Sirrus has a 27.2mm seat post, and the smallest clamp is 28.6mm, so I had to buy a seat post shim tube sleeve adapter to make it all fit.
I'm all too aware of the dangers of crushing a carbon frame so I put a small washer between the pannier stays and eyelets attachment points on the frame. That keeps the stays away from the frame and eliminates the risk of crushing.
Here's a few pics for anyone else considering a pannier rack:
Likes For TigerG:
#902
Finalizing the brake upgrade for my X comp:
Shimano XT BL-M8100 L/R
Shimano SAINT SM-RT99 160MM Center Lock Rotors
Shimano GRX Calipers BR-RX400
Shimano R160D/D Disc Brake Adapter
about 50 miles in, feels quite a bit better than stock. Worth all the money, maybe not, but what are hobbies for?
Also recently added rib cage II carbon bottle cages, and swapped out the composite specialized pedals for raceface rides. The raceface pedals are super smooth and comfortable for 35$
#903
Do you need an adaptor for the disc brake rotor upgrade ? the stock rotor was 160 mm right.
#904
Hello guys & gals. I’m looking at getting a hybrid bike and really wanting something lightweight. I stopped by a LBS that carries Specialized and looked at the Sirrus Elite carbon. I asked about the necessity of front suspension for having a softer ride and they showed me a Crosstrail. Since I already have a MTB and really don’t want to do much of that anyway I felt like the front suspension of the Crosstrail added more weight than I’d benefit from for riding on Greenways or on-road. The fella mentioned the X comp and that kind of interests me with the Future Shock, & wider tires. I’m not a fan of black paint BUT it sounds like there’s purple or something in the paint(?)which sounds cool. Can’t say I’ve found any high res pics of that paint...it just looks black in photos.
I’ve yet to check specs but the LBS mentioned he thought the fork and subframe were a bit wider to accept the wider tire.
So, cost difference not being an issue, is the X Comp going to be a more comfortable/better ride than a Sirrus
carbon elite?
Anything else I should consider (pluses/minuses) between those?
Last mention, the LBS has neither in stock and requires a 30% deposit to bring one in. Also if it’s helpful, I’m 5’10” with 32” inseam, weigh 200lbs and am looking at a large in the Sirrus.
carbon elite?
#907
Likes For GravelGurty:
#908
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times
It's not about GRX or Ultegra or another groupset, but rather the standard to which the disc brakes were designed. If I'm not mistaken, you've got flat mount disc brake calipers, and the "native" size for the rear rotor on these is 140mm. You are correct that you would remove the adapter in order to run 140mm, but that would apply to any brand or groupset that conforms to the flat mount standard.
#910
According to information obtained from Specialized, Sirrus X 5.0 is an additional X model for 2020 and will be available in all countries at the end of 2019 (I hope in November). I hoped it would be matte, but unfortunately it would be shiny
#912
Quoted: 1579 Post(s)
Liked 1,187 Times
Not sure what would be "additional" about it? It is identical to the '19, including price within a few dollars/pounds, save for the switch to SLX shifter/derailleur from NX, and a change of tires and colour. The only possibility I can see is that the FS is changed to the 1.5 version; that would be a good change. The specs. on the linked site are silent about that.
#913
#914
Quoted: 16 Post(s)
Liked 10 Times
@mscenic The Hunt wheels that you got, I read rave reviews about it, but wanted to know whether the bearings/free hub is noisy. Is it smooth and runs quietly ?
#915
Help with BB / chainring
Hello! I'm looking to change up my gearing and would like to add larger chainring, but I can not find what direct mount pattern will work with these cranks. Or can anyone provide some option they used for new bb/cranks/chainring to change ratios.
Thanks!
Thanks!
#916
What year and model is your bike and crankset?
#917
Liked 1,187 Times
I have the same bike with that no-name generic crank. This winter I'll change it out for a 'known' (and much lighter) single-ring crank, e.g. SRAM Force 1, Shimano GRX, or similar.
#919
I suspect you'll either have to have your lbs pull the crank/ring and determine what, if anything, it's compatible with, or email Specialized customer care and see if they'll tell you.
#923
Specialized website does not provide details about this bike's cranks other than the spindle having 24mm diameter. You can however look at the markings on the bottom bracket and/or cranks to get more info. Once you figure out the bottom bracket, it would be easy for you to decide what you need.
#924
I converted my 2014 Sirrus to 1 x 12/36 a couple of weeks ago and the Shimano cranks that i ordered came with 36t chainring, i have a 40t chainring waiting to be swapped but have been too lazy to do so. As my username suggests, i ride slowly being in my early 60's and not in a hurry, so a 36t chainring works fine for me as well.
#925
Liked 1,187 Times
Likes For badger1:
