F.A.G.G.I.N. dropouts
Old 08-08-19, 01:13 PM
CTony
Bikes: 74 Raleigh InternationalRiva-Sport,Frejus
Quoted: 15 Post(s)
Liked 4 Times in 4 Posts
Hello, My dropouts on my F a g g i n are stamped Gipiemme.How important is it to be using those components?Im building this bike for Eroica 2020.Im planning of having some wheels built using Campagnolo Record hubs with Regina28-14.Will it matter?
CTony is offline
Old 08-08-19, 01:19 PM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
Liked 1,844 Times in 609 Posts
Originally Posted by CTony
Hello, My dropouts on my ***gin are stamped Gipiemme.How important is it to be using those components?Im building this bike for Eroica 2020.Im planning of having some wheels built using Campagnolo Record hubs with Regina28-14.Will it matter?
The manufacturer of the dropouts means nothing. The two critical elements are that the hanger is correct for the rear derailleur you'll be using and the spacing is right for the hub. Considering your F a g g i n is an Italian bike, it almost certainly has a Campagnolo-style hanger and if the spacing isn't perfect this can always be corrected with a bit of elbow grease by cold setting.
Kilroy1988 is offline
Old 08-08-19, 01:56 PM
noobinsf
noobinsf's Avatar
Quoted: 1088 Post(s)
Liked 1,205 Times in 701 Posts
Wellllll, that's not 100% true, strictly. If you have Simplex or Huret dropouts, you need to pause and think about things, which is likely the root of the question. But yes, Gipiemme dropouts will most likely conform to the "universal" Campy standard.
noobinsf is offline
Old 08-08-19, 02:06 PM
CTony
Quoted: 15 Post(s)
Than you Kilroy for responding back so quickly.When I purchased bike it came with one Campagnolo part which was bb,The crankset was Aroe mighty 52-42 and wheel set are Suzue Juno 23-13 gears matched with Araya 700c Sorry and down tube shifting paddles Campagnolo.Front and rear derailleurs are sun Tour cyclone M2.I replaced rear derailleur with Campagnolo nuovo Record fits that hanger just right.Thank You again.Fogot what's your thoughts on rims to mate with Campagnolo hubs?I do have a set of Tiplo Campagnolo tubulars tires are costly.Again Thank You
CTony is offline
Old 08-08-19, 02:59 PM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
For those in the know, it is often easy to recognize the significance of what one dropout/hanger manufacturer means in terms of compatibility, but there were many variations. Gipiemme also used a lot of Simplex derailleurs at one time or another, but I presumed that these were probably Campagnolo-style on a F a g g i n frame. Apparently I'm right based on CTony's previous post.
It still stands as a matter of fact that if you look beyond the manufacturer (which can cause confusion - for example, many early Simplex dropouts didn't even come with hangers) you can discern all of the component compatibility simply by checking the style of hanger and the rear dropout spacing. As far as hub spacing goes the manufacturer and style of hanger has no bearing whatsoever, of course, since that depends on the frame geometry.
-Gregory
Likes For Kilroy1988:
Old 08-08-19, 03:09 PM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
@CTony
You can put whatever rims you like on the Campagnolo hubs as long as the number of spokes matches the number of holes drilled in them! Unless if there is some kind of technical issue caused by the mixing of components (such as putting a rear derailleur on the wrong hanger or fitting the wrong sized seat post or not having long enough reach on some brake calipers) then you're welcome to use whatever you like!
It is very hard to offer advice to you without knowing the year your frame set was manufactured, and what priorities you have with the build. Are you trying to only use components that were available when your frame set was new, or do you want to have a solid climbing bike, or one that will be comfortable all day, etc?
-Gregory
Old 08-08-19, 05:17 PM
CTony
Quoted: 15 Post(s)
Sorry all.After purchasing and tear down bike. I did some researching and came across ***gin website.I contacted Cristina and sent her pictures she told me year of construction 1980 and the tubing is Columbus AELLE.And to answer your first question.Yes.And I do believe I have those components.Answer to second question.For climbing,I'll try working on gearing without going to a triple crank.being comfortable? I'm hoping to find that sweet spot.Agian Thank You.
CTony is offline
Old 08-08-19, 08:31 PM
Drillium Dude
Drillium Dude's Avatar
Quoted: 2588 Post(s)
Liked 4,824 Times in 1,709 Posts
***gin.
Well, what do you know? This is a sensitive censor!
DD
Drillium Dude is offline
Old 08-09-19, 06:41 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Ya, F A G is not a slang word, but when I pointed this out to BF, my post was deleted.
Shame on this forum.......shame......shame...shame.....
To the admin that removed my post.... Shame on you
trailangel is offline
Old 08-09-19, 06:57 AM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 1628 Post(s)
Liked 1,059 Times in 633 Posts
Pretty soon, we won't be able to say words like "assume" any more. Are they censoring that one yet?
EDIT: I guess not. Uh oh, now I'm being turned-on by a dirty word in my own post. Back in a minute.
Lemond1985 is offline
Old 08-09-19, 08:20 AM
xiaoman1
xiaoman1's Avatar
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times in 1,183 Posts
What a Bum
Ben
Voltaire
xiaoman1 is offline
Old 08-09-19, 08:55 AM
Mr. 66
Mr. 66's Avatar
Quoted: 1143 Post(s)
Liked 1,747 Times in 965 Posts
The bike that shalt not spoken, what's next are the ***gin pictures to be deleted to?
Mr. 66 is offline
Old 08-09-19, 09:09 AM
ksryder
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times in 329 Posts
I understand the mods have a hard and thankless job but this is approaching MLB umpire levels of sensitivity to criticism.
ksryder is offline
Old 08-09-19, 11:01 AM
CTony
Quoted: 15 Post(s)
I started this post.So,I'll add to it.Its all about pronounciation.
CTony is offline
Old 08-09-19, 01:29 PM
cinco
cinco's Avatar
Bikes: Forty of them
Quoted: 99 Post(s)
Liked 33 Times in 21 Posts
There are a lot of adults who want to be treated like children these days.
cinco is offline
Old 08-09-19, 01:50 PM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
Stick around! Just expect threads like this to derail quickly when strange topics arise...
Now that you have ten posts you can share some photos of your frame set and other materials you've collected so far.
Cheers!
-Gregory
Old 08-10-19, 07:20 AM
jonwvara
jonwvara's Avatar
Quoted: 765 Post(s)
Liked 660 Times in 351 Posts
Matsu****a, the Japanese conglomerate that manufactured Panasonic-branded bicycles, is another one that the censor doesn't like.
www.redclovercomponents.com
--Ogden Nash
jonwvara is offline
Old 08-10-19, 09:14 AM
Bianchi84
Bianchi84's Avatar
Quoted: 235 Post(s)
Liked 349 Times in 190 Posts
Can we still discuss ***anium frames and components?
Bianchi84 is offline
Old 08-10-19, 09:39 AM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
Titanium...
Yes, yes, you can.
Old 08-11-19, 06:17 AM
jonwvara
jonwvara's Avatar
Quoted: 765 Post(s)
There's an interesting Wikipedia article about the problem of overzealous web censorship--the so-called S****horpe Problem:
https://en.wikipedia.org/wiki/S****horpe_problem
Clearly, we suffer from it here.
--Ogden Nash
jonwvara is offline
Old 08-11-19, 06:32 AM
Rollfast
What happened?
Rollfast's Avatar
Quoted: 1835 Post(s)
Liked 292 Times in 255 Posts
That's Because it's called Panasonic Corporation now.
Rollfast is offline
Old 08-11-19, 06:33 AM
Rollfast
What happened?
Rollfast's Avatar
Think about it, the censor has to keep up with all the *#%)@ you kids invent all the time. It doesn't get paid enough.
Rollfast is offline
Old 08-11-19, 06:38 AM
Rollfast
What happened?
Rollfast's Avatar
For about a billion years it has meant a shortened form of a derogatory indication of a ****sexual. To others, it's a cigarette. So please, consult Mirriam and Webster if in doubt.
See? Your milk is ****genized.
Which has nothing to do with Marvin Gaye except that he wanted to get it on.
Now, go back to tuning in and turning on to dropuots.
Rollfast is offline
Likes For Rollfast:
Old 08-11-19, 06:42 AM
ksryder
Bikes: yes
Of course they also censor r e d d d i i but that's just because they're about 15 years behind the rest of the internet.
ksryder is offline
Old 08-11-19, 08:28 AM
Rollfast
What happened?
Rollfast's Avatar
If Miley Cyrus' marriage didn't work out then there's no way in the opposite of Heaven we're going to deal with their cold soup.
If you wanna be there, be there. Please.
Rollfast is offline
