Raleigh to fixed gear
Stripping down a rusty, weathered old Raleigh Pursuit with the goal of creating a fixed gear/single speed. Needs tires and to have brakes re-routed and installed. I am wondering how big a headache I am getting myself into? I have done some reading up on the process. I am a real newbie so direction to other sites or posts is appreciated. It seems much of this will require a tech....any help appreciated!
Quoted: 586 Post(s)
Liked 612 Times
Projects like this can take a number of directions depending upon how much work you want to put into it. If you want to, you can use the existing rear wheel but if you want to go with the option of switching from fixed to freewheel, then you will want a flip-flop hub.
I ride a Miyata conversion. It is absolutely wonderful. I have zero issues with chainline, chain taughtness or anything. It is full-time fixed, no freewheel at all. When I want to ride SS with a freewheel I have two other bikes for that. If the wife said I had to narrow down my herd to two bikes, the Miyata would be one of them. If she said one it might be a close call.
Go visit Sheldon Brown's site. He gives advice on converting a geared bike to fixed. He also has a handy gear calculator. Check out his "gain ratio" calculator too where he takes into account other variables.
https://sheldonbrown.com/fixed-conversion.html
Good luck.
Good luck.
Likes For TugaDude:
Good luck.
Good luck.
Bikes: Mongoose Maurice FS 2011 fixed gear, custom 2017 Haro Master Flatland bmx, Contrast FL475 mid school flatland bmx
Quoted: 15 Post(s)
Liked 11 Times
GCN & RJ thebikeguy posted vids on the topic, chk it out on youtube! I kinda enjoy listening to them
Well, since it looks like someone already cut off the derailleur hangar...
I actually have a steel Raleigh that I run fixed. Works great. The bars and brakes are just regular road bike stuff. Even the crank arms are original, I just swapped in a 1/8" chainring. I actually ran one of the original rings for a long time, but the wider ring is quieter with 1/8" chain. Of course, I have been working on bikes for years and have plenty of tools so you may need to pick up a few tools and watch some YouTube.
On the older bikes with semi-horizontal dropouts, all you REALLY need to run fixed is a new rear wheel and to remove all the shifty parts. The other parts swaps after that are more about optimizing and upgrading.
BTW, it may be the angle of the photo, but is your fork bent?
I think the fork is OK. I am wondering if I can keep the chainring and swap in a new gear on the rear hub? I want to do this baby cheap but I am a little lacking in expertise and tools. I have all the original equipment in a bag, though the chain was rust-welded in a distorted mess. Even on the cheap I can see this getting a little pricey!
Not sure about the chainring. It's possible, but we would have to see the back side and how they attach.
The original handlebars, brakes and brake levers will work 100% as long as they aren't broken. 99% chance you will want new brake pads though!
You may be able to get by with a set of sockets and allen wrenches. Reusing that wheel would require a freewheel remover though.
Honestly, if lowest price is a priority, Bikes Direct may end up cheaper. It wouldn't have the same style and you would learn some mechanical skills converting this one but in fairness, keep BD as a price point when you start adding up everything.
So, with that hub you'll only be able to run single speed, not fixed. Fixed requires a lock ring that is reverse threaded so a new hub.
The wheel on that bike just has one set of threads. Because there is a freewheel, there is never any reverse torque to unscrew it. You could run a single speed freewheel on the bike safely.
Unfortunately, those chainrings look riveted on. It's not uncommon on older entry level bikes. It also means you can't really change the chainrings.
So, absolute cheapest option is to have a 3/32 singlespeed freewheel installed on the back and put on a 3/32 chain. Just use the existing chainrings and ignore that there's an extra one... it's a bit weird but it gets you to a singlespeed.
To get to fixed gear you will need a new rear wheel. You might look around on CL or FB marketplace and see if someone is selling one. The other issue here is that your bike will likely have 27" rims. Anything modern will use 700c rims that are about 4mm smaller in radius. If your brake calipers have room to move the pads down then that's fine. If not... new calipers also. Used calipers off Ebay can be quite affordable
TBH, none of this is hard to do, unless it's all new to you... are there any local bike clubs near you? I'm kinda across the state, south of Flint...
Thanks for all the information, very helpful!! And yes I am brand new to this. Haven't looked into a bike club yet...
^that guy^
Velomine.com sells single 27" rear wheels with track hub.. might wanna look into it
Quoted: 399 Post(s)
Liked 274 Times
Guess we're not in 2006 any more, hmmm? You did say you want fixed gear, right? Did all the conversion experts here telling you its impossible without a new wheel or hub forget about the good old Suicide Hub method? Look it up - by far the absolute cheapest way to convert an old freewheel hub bike to fixed.
Have fun & good luck...
Quoted: 823 Post(s)
Liked 1,395 Times
Though, it must be noted - the Gitane Track Standard you also have blows this out of the water. Were I in your shoes, I would convert this one as quickly and cheaply as possible, because the Gitane is soooo vastly superior.
Earlier, Tugadude cited the late, much-missed Sheldon Brown's very helpful, illustrated and handy synopsis. That would be <https://sheldonbrown.com/fixed-conversion.html>, which is probably the UR-site for fixed-conversions and could be considered ground-zero for the whole fixed-gear boom earlier this century. Sheldon's writings launched who knows how many fixed conversions - and it's still good and relevant information to this day. There is a passage on using conventional freewheel hubs by redishing the wheel and simply threading on a fixed cog that explains the process nicely. Good luck and Godspeed.
Decided to scrap the Raleigh. I have the Gitane project track bike, the Nashbar road bike and I am picking up a Guaranty Quality Supreme 3 speed for a $20. I will be all set especially with apartment living. I hate to throw it out but what can I do?
Not lost wanderer.
Quoted: 885 Post(s)
Liked 989 Times
This is an easy conversion to Single speed and would be a fun bike.
First thing, remove the freewheel from the hub then
Center the axle in the hub
1, remove the outer locknuts from both sides of the axle
2, loosen the cones from both sides and remove the bearings
3, clean and inspect bearings and races and replace while centering the axle in the hub.
4. replace the spacers making sure they are the same on both sides.
5. snug up the bearing cone lock nuts making sure the wheel spins smoothly.
Recenter the wheel
1. Put the wheel with the centered axle in the bike and snug the wheel nuts or QR skewers.
2. use the brakes as a gauge to center the rim in the frame by loosening the spoke nipples on the side closest to the frame and tighten the spoke nipples
install a single speed freewheel.
Buy a cheap single speed crankset and install it
put on a chain and ride.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Ok got the bike but only one speed (3rd) is working so needs some adjustments.
