Deer Head derailleur without barrel adjuster?
So I have this Shimano deer head rear derailleur. It doesn't have a barrel adjuster to adjust the trim. I looked online at other photos and the ones I saw had a barrel adjuster threaded in. However, mine doesn't even have any threads. Is the cable supposed to go directly into it and rely on the adjuster at the shifter end instead?
Quoted: 5793 Post(s)
Liked 2,593 Times
Yes, that derailleur is intended to be used with flat bar levers that have adjusters, so there was no reason to have them on then RD. The cable goes to the fitting but will need a ferrule.
FB
Chain-L site
FB
Chain-L site
Quoted: 4211 Post(s)
Liked 3,881 Times
Actually any friction shift lever will trim this der, not only flat bar ones. One could also add a cable tension adjuster to the system. Like an in line style placed along the cable casing at some spot. Andy.
Quoted: 1438 Post(s)
Liked 1,092 Times
Excellent. All great ideas. It is going to be used on a Specialized mountain bike though with new grip shifters and yes, they have adjusters.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
(Assuming you are using the Shimano-compatible Grip Shifts. If you have the SRAM-compatible Grip Shifts, only SRAM derailleurs will work. )
Jeff Wills
Jeff Wills
Super Moderator
Quoted: 1173 Post(s)
Liked 929 Times
That derailleur was made before index shifting, and thus might not work well with Grip Shifts. You would be better off installing a newer index-compatible rear derailleur and selling the "Deer Head" derailleur on the Classic & Vintage For Sale subforum.
"friction" derailleurs don't need an adjuster. You just set the limit screws and ride.
I did notice that when I reistalled it. I substituted an indexed derailleur, Sora long cage, it it worked great. So why is that? If the indexing works at the shifter end why does the rear derailleur matter as long as I am not mixing Suntour and Shimano?
Quoted: 1944 Post(s)
Liked 2,164 Times
Without getting into the slant parallelogram design geometry of pre-index to post index, the basic reason is that the rear derailleur moves a certain amount as the shift cable is pulled. Prior to indexing there was no need to design a derailleur that moved a precise amount between the first and 5/6 cogs. With friction you just moved the lever what was needed to make a good shift. Index derailleurs have a specific throw ratio that moves the derailleur a specific amount for the amount of cable pulled. There are those who can give you a lot better information.
If you really want an interesting history lesson research Suntour and Shimano's Centeron pulley.
John
John
I figued the term "slant paralellogram" was going to be used, however, I figured, erroneously, that the new and old style derailleurs from Shimano still all followed the same arc of motion. Therefore, one with indexing would just have specific stops along the way and the other being infinetly adjustable. I could be more specific in my thinking however that would require a marker, a large tablet of paper, and an easel.
Quoted: 809 Post(s)
Liked 712 Times
I figued the term "slant paralellogram" was going to be used, however, I figured, erroneously, that the new and old style derailleurs from Shimano still all followed the same arc of motion. Therefore, one with indexing would just have specific stops along the way and the other being infinitely adjustable. I could be more specific in my thinking however that would require a marker, a large tablet of paper, and an easel.
You can use almost any index-compatible rear derailleur made in the last 30 years on that bike. (Even non-Shimano.) Pre-indexing, though, all bets are off. It could work, but that's a whole 'nother kettle of monkeys.
Jeff Wills
Jeff Wills
hcgaloi
Bicycle Mechanics
24
09-29-21 04:14 AM
kalash74
Bicycle Mechanics
5
02-06-17 02:17 PM
clones2
Bicycle Mechanics
3
04-23-14 03:35 PM
