Floor pump for tubeless
Old 08-16-19, 08:40 AM
Steepndeep
Bikes: too many bikes
Quoted: 10 Post(s)
Any recommendations for a reasonable floor pump that will seat up tubeless tires? Joe Blow Booster and Topeak Pressure Overdrive seem like possibilities.
Steepndeep is offline
Old 08-16-19, 08:42 AM
Leebo
Bikes: Kona Dawg, Surly 1x1, Karate Monkey, Rockhopper, Crosscheck , Burley Runabout,
Quoted: 854 Post(s)
Liked 111 Times in 66 Posts
Take out the valve core, use a compressor. Much easier.
Leebo is offline
Old 08-16-19, 09:12 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Joe Blow Booster is $150
Lezyne Pressure Overdrive is $140
I use the Joe Blow Mountain .....$50
trailangel is offline
Old 08-16-19, 09:36 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
The majority of modern mtb setups will seat fine with a standard floor pump. I've got a Serfas something-or-other than has worked for all my tubeless MTB setups over the past 9 years. If you already have a standard floor pump, I would see if that works first.
I think either of the ones you mention (It is the Lenzyne Pressure Overdrive, right?) will easily do any MTB tire setup out there. I did not even realize those sorts of pumps were available. They seem like a good idea, but.............
.....if you already have a floor pump, I think for the price those things go for I would invest in an air compressor which has a lot more uses. I mean, at that price unless you plan on doing tubeless setups in places with no power, I am not sure I see the advantage of one of those pumps over a compressor. Or heck, just get an air tank and use your floor pump to pressurize it. Again, more other uses than with the pumps you mention.
Kapusta is offline
Old 08-16-19, 09:45 AM
ksryder
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times in 329 Posts
Specialized makes one for $55: https://www.specialized.com/us/en/ai...=232984-156624
ksryder is offline
Old 08-16-19, 12:16 PM
commo_soulja
commo_soulja's Avatar
Bikes: are fun to ride
Quoted: 33 Post(s)
Liked 35 Times in 23 Posts
Topeak Joe Booster here.
commo_soulja is offline
Old 08-25-19, 02:09 PM
dagray
dagray's Avatar
Bikes: Orbea Orca,Raleigh Talus 29er, Centurion Le Mans 12 speed
Quoted: 164 Post(s)
Liked 84 Times in 42 Posts
Giant makes a reservoir that can be pumped up with a regular bike pump. I have one and use it to seat my tubeless road tires. I pump to 160 psi, then open the valve so all of the air rushes into the tire.
I have used this to re-inflate utility trailer tires (for automobile use) as it throws a whole bunch of air volume at once.
Cost from my local bike shop was $65.00
dagray is offline
Old 08-27-19, 10:06 AM
prj71
Quoted: 2975 Post(s)
Liked 1,182 Times in 771 Posts
Bontrager has one also.
https://www.trekbikes.com/us/en_US/e...-pump/p/11881/
prj71 is offline
Old 09-05-19, 05:47 PM
WannaGetGood
B*ck From Th* D**d
WannaGetGood's Avatar
Bikes: 2015 Kona Process 153
Quoted: 23 Post(s)
Liked 8 Times in 6 Posts
I have not needed to do any tires myself, however, a friend of mine who is very good with fixing bikes doesn't use any sort of fancy pump. With this said, it can take one long day or two days to get the tire completely sealed with your average 30$ floor pump.
WannaGetGood is offline
NoWhammies
Road Cycling
27
05-21-19 02:23 PM
Teamprovicycle
General Cycling Discussion
7
07-17-18 07:43 AM
bikebreak
13
12-31-15 10:49 AM
dalava
Road Cycling
29
10-06-14 11:59 PM
metz1295
Road Cycling
5
08-15-14 12:59 PM
