Is ordinary engine oil considered a wet lube?
I am eventually going to scare up some bike dedicated wet lube.
Until then I was wondering if engine oil would do to seal out the winter nasties.
Non omnino gravis
Anything will work as a chain lubricant, over a short enough timeframe. Sure, single/multi-weight motor oil will work, but it's absolutely not what it was designed for. It will make the chain a jet black, filthy mess rather quickly, but it will stop rust from forming and probably keep things squeak-free.
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
I've certainly used motor oil for chain lube when I've had nothing else on hand. If it wasn't for the fact that motor oil will sling all over your rear wheel, rim brake surface, and tire, I'd be okay with it.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
That's why you wipe off the chain thoroughly after applying. Motor oil (not used, please) has a long history of being a perfectly acceptable chain lube.
Likes For ThermionicScott:
Quoted: 4745 Post(s)
Liked 3,861 Times
I suspect if you apply the motor oil as carefully as you would very expensive bike chain lube, that the mess would be quite tolerable. Maybe use a Q-tip? Or a pocket knife. Dip blade into oil then along the inner-outer interface on each side of each link. Slow, But a careful job should work just fine and not be too messy and not throw oil. (And yes, motor oil is formulated for different challenges. Bike chains and normal riding are so un-demanding lubrication-wise that simple 3-1 oil works just fine. That motor oil will still be working when you get your pedal RPM up to 5000.
Ben
Ben
Likes For 79pmooney:
Jedi Master
I use motor oil on the bike I ride to the train station. Not a lot of miles, but I leave it outside a lot in all kinds of weather. The chain is almost 30 years old and still going strong.
Likes For kingston:
I don't ride quickly especially in the winter.
That means oil wouldn't get flung around much nor debris get picked up.
But oil on my nice Schwalbés is a no-no.
Thanks
I'm the anecdote.
Liked 1,176 Times
Lube slung from a chain or an internal gear hub is why I really don't like having cream colored tires on bicycles. Brown or tan sidewall, might be more tolerable for me, but black tires are my first choice.
Likes For dougiet:
Quoted: 2965 Post(s)
Liked 1,167 Times
https://www.amazon.com/s?k=bike+chai...f=nb_sb_noss_2
Chain lube, tire psi, pedals and such, some have very strong opinions. Try this. Mobil syn lube, 0W20, with 2 parts mineral spirits. Apply lightly, wipe off before riding. You want a thin coat, not dripping off.
Liked 1,167 Times
Sigh...
Just spend $5-$10 and get some chain lube. Motor oil is not meant for chains.
Lubricants Not to Use!
While it's hard to say which lubricants are best for chains, some lubricants are real no-nos:- Automotive motor oil contains detergent, to wash away combustion products, and is made to be renewed constantly under pressure from the motor's oil pump. I [John Allen] rode once with someone who had used it the day before, and her chain was already squeaking.
Quoted: 1591 Post(s)
Liked 1,015 Times
I wouldn't use it now, but rode thousands of miles using it in my youth. I'm sure there was bike chain oil, but we weren't really hip to it. Every household had a squirt can filled with motor oil that was used for many general lubrication purposes, including bike chains.
Likes For jon c.:
Quoted: 1324 Post(s)
Liked 927 Times
Ben
Ben
Cheers
Likes For Miele Man:
Quoted: 2236 Post(s)
Liked 1,313 Times
It's only cold pressed, extra virgin, locally sourced, ethical, non gmo olive oil for my bike but you do what you want.
Unrelated, but does anybody know where I can pick up a set of virtue signals for my bike? I like to be noticed in traffic.
Likes For Happy Feet:
Non omnino gravis
It really wouldn't. Motor oil is designed to be operated under pressure in a sealed environment. Oil is kept inside an engine mechanically. Take an exposed chain drive to 5,000rpm, and the centrifugal motion and generated heat would have the chain almost completely clean within minutes. This is precisely why exposed chain drives in industrial applications use grease. Motor oil will work in the short term for as I said before, virtually anything will work in the short term. I don't eschew motor oil as a chain lubricant because I'm some kind of lubricant snob. I don't use it because it's absolutely the wrong material for the application.
Non omnino gravis
Myself, I use motorcycle chain spray "wax". Works great and stays lubricated with no mess. Plus cheaper than bike chain specific lube.
Likes For masonv45:
Liked 927 Times
