Are galvanized steel spokes magnetic?
Quoted: 4236 Post(s)
Liked 2,949 Times
Probably a stupid question, but I'm wondering if galvanized steel spokes are magnetic (I'm assuming SS spokes are not because SS isn't typically). Not really a C&V question, but I figure most galvanized steel spokes are on C&V (or at least old, if not classic) wheels.
I'm asking because I'm building up some carbon wheels (gasp, I know) for a resto-mod bike and thought I'd try tubeless ready rims that don't have spoke access holes (because I want to make my life hard). The most common way to get nipples into the nipple holes in the rim is to screw something magnetizable into the nipple, put it into the rim through the valve hole and then use a magnet to pull it to the right location. I know I could take a nipple and a magnet to a hardware store and try to find a 2 mm steel screw of the correct thread pitch, but was thinking that looking for an old galvanized steel spoke (not sure if I have any in my old spokes bin, maybe not, so this might be a wasted question) that was designed to screw into the nipple and just cutting it down to ~1" or so would do the job as well.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Quoted: 4806 Post(s)
Liked 3,932 Times
Is that old galvanized spoke going to have the same thread? I used to use the galvanized Robergel Sport spokes but never tried them with modern nipples. Probably have one somewhere.
Liked 2,949 Times
Good point. Probably just smarter to take the magnet and nipple to the hardware store after all.
Quoted: 3464 Post(s)
Liked 2,831 Times
Robergel had two thread types, obviously unique in keeping with the French tradition
Likes For repechage:
Liked 2,831 Times
Liked 2,949 Times
Oh, I'm not planning on doing anything like French threading. Just a normal modern spoke and modern nipple. I was kind of considering alloy nipples and I hear about how soft and easy to round the corners are, so I was sort concerned about using something not designed for them could bung up the threading. I know alloy nipples and carbon rims are definitely not in the C&V era, but one of my other bikes has/had a carbon (threaded) fork on a lugged steel frame from the 80's, so I'm open to playing around with mixes of modern bits on vintage frames.
Liked 2,831 Times
Quoted: 887 Post(s)
Liked 335 Times
I am not sure I understand your question. If you have galvanised steel spokes, then they are attracted to a magnet.
Liked 3,932 Times
I believe he wants to cut a short piece of magnetic spoke (or whatever), thread it into the nipple, then use the magnet to drag the nipple through the rim to the spoke hole. Pull the nipple through via the attached piece of spoke, unscrew spoke piece, screw in real spoke. The presumption here is that a galvanized spoke would be common, magnetic steel and SS not. I'd take a magnet and test both spokes. Some SSs are magnetic.
Likes For 79pmooney:
Liked 2,949 Times
Liked 2,949 Times
I am amazed by this thread.
What are the supposed benefits of tubeless technology over the traditional C&V tubed technologies?
Metric threads are the same around the world, except for those pesky M3.5 screws that were used on some French assembly machines that I used to work on.
Señor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
I've heard that aluminum nipples do not play well with carbon rims.
Likes For USAZorro:
Liked 3,932 Times
I thought they played really well. Especially in the wet. So much fun they get to tossing electrons around. They coined a name for this. "Electrolysis" Kinda like Monopoly. One of the players always wins coming away with all the cash electrons.
Actually, no first hand knowledge here. (With either aluminum nipples or carbon rims let alone both together.)
Liked 2,949 Times
Honestly, I have a bunch of really nice tubed tires to use, so I may never ride these tubeless, but some of the tires are known to be hard to mount so doing the hard bit of putting spokes in without access holes now is mainly going to give me that little bit of extra leeway caused by not having tape on the rims.
You have to passivate one or the other or both or corrosion will start immediately.
Aluminum anodizing is not moisture-proof, so more effort may be needed.
What is running through my head is the zinc coating on the spokes. Is it a suitable corrsion inhibitor? Will it act as a sacrifical electrode?
Can anyone give a more comprehensive statement of supposed benefits of this "tubeless" technology?
Quoted: 1821 Post(s)
Liked 1,696 Times
I have been reading this thread and it makes my head hurt. If the OP has some galvanized spokes on hand why wouldn't' they simply take a magnet and test whether the magnet attracts them?
Liked 2,949 Times
I'm just trying new stuff that's different from how I usually do things. Doing something different this time is the end in and of itself. Maybe it'll be good, maybe it'll suck. If I just keep doing the same thing over and over again, I'll never know. It's kind of like going out to eat. My wife finds one thing she likes at a place and then that's all she ever orders. I'll try something different every time because maybe I'll find something better.
Likes For himespau:
Liked 2,949 Times
As I said above, I was at work at the time. Also, my box of used spokes is buried under a whole bunch of stuff I don't have easy access to (especially with the guests here) and I am not 100% sure there are galvanized spokes in there anyway. I was just idly wondering if galvanized spokes were magnetic and if it was worth digging the box out and thought I'd ask instead of just wondering.
This is correct. Also underlined the bit where I need to just get a magnet and go poke around with it in my used spoke box and see if it sticks to anything as you are correct about not all SS being equally unmagnetic. This is just something that occurred to me on a slow day at work while my parts closet is at home. Should have just waited to get home to check before posting (though I just found out that some guests have unexpectedly decided to extend their stay and will be there when I get home, not saying that's why I'm killing time at work rather than checking out early, but...).
Señor Member
Liked 1,096 Times
I think that some of us have become like Ents. We do not always approach the situation at hand directly.
Galvanized steel is steel with a zinc coating. So yes it is magnetic.
Some stainless steels are magnetic.
T-316 Stainless is the most corrosive resistant stainless steel and is non magnetic.
Likes For CJohn:
Likes For oneclick:
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times
tubeless tires are self sealing and can be used at very low pressures, they are ubiquitous for modern MTB and gravel wheels. I won't debate the pros or cons of road tubeless though
