Help me solve the mystery frame . . .
Bikes: Gazelle Toer Populair T3, Trek 460 Classic, Mystery frame commuter (in work)
I purchased this bike as what appeared to be a converted fixie, and the previous owner said it was a Schwinn. Now that I have all the paint stripped off, I'm having my doubts. I'm pretty sure it's not anything rare or valuable, but I'm sure curious what it is. Any experts out there that think they can help identify it?
Frame Weight: 5.7 lbs
Fork Weight: 1.75 lbs
The only number visible on the frame appears to be (a poorly stamped) "D399" on the seat tube, and the fork is stamped with a "3|G" . . .
Huh.....That's an elaborate steerer marking.
Quoted: 3814 Post(s)
Liked 3,345 Times
One would think the only Schwinn possibility would be a Schwinn World manufactured by Giant of Taiwan.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Looks kinda french/UO-8 to me.
Quoted: 1627 Post(s)
Liked 630 Times
Wouldn't a UO-8 have the serial # stamped on the NDS dropout? Or did they move them around from year to year?
To my eyes, the lug work and dropouts hint at late 70's mid-low range Japanese (Apollo?)
Although the arrangement (and low number) of the serial number on the seat tube kinda throws that idea out.
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
If that were the case, the number would be on the DS rear dropout, and it would start with a G. I have one sitting out on the porch, a 78, and it looks nothing like this.
Fork is Tange. Marks like that can be found on Sekine models. 3 might correspondent to the year 73 or 83
Not saying at all that this is a Sekine, just the forks manufacturer.
Phyllo-buster
Liked 2,055 Times
It's just the rake of the fork and the stamped rear drops remind me of those franco-boom bikes. I've probably owned 4 or 5 but I never cared enough to pay attention to their minutia. Those fork ends remind me of a German bike I had.
Quoted: 4722 Post(s)
Liked 3,039 Times
The bicycle is not a Sekine. The serial number format and location are incorrect. Based on the serial number, it is also not a Kuwahara manufactured Apollo or a Giant product.
The serial number format and location matches that of the (unknown) Japanese manufacturer of the boom era, entry level Centurion. The fork date code indicates a 1973 or 1974 model. The rear dropouts are also typical of this manufacturer during this era. However, the stay cap treatment does match that typically seen on the Centurion (LeMans) of this era. I also can't see any brake cable stops generally found on the entry level models. I'd like to see a good picture of the head lugs. I'd also like to know the required seat post size. I don't think it is Centurion, but it may be another brand from the same manufacturer.
Liked 3,039 Times
I went back and looked at my Centurion serial number database and there were about a dozen entries with this serial number format. Linking back to the photos (where available) it looks like the the entry models from the very early 1970s used cable clips and that they went to stops circa 1974. However, none had the flat, beveled, stay caps. They all used rounded caps.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Early 70's Japanese "gas pipe" carbon steel frame... Lightweight derailleur bikes were never very common in Japan. There were only a handful of bike manufacturers making them and most were for export with a multitude of brand names created by the importers in the target countries.
The stamped steel fork crown and stamped rear dropouts are the giveaways. Those early Japanese frames also tended to have the seat stays attached low on the seat lugs,
7.45 Lb. is pretty heavy for a frame that size. For example a standard production model alloy steel fork and frame would probably weigh around 6.5 Lbs. or less (Reynolds 531, Columbus, Tange, etc.).
It's going to have a pretty clunky ride because of the frame size combined with the heavy gage tubing.
verktyg
Chas.
verktyg
Chas.
Chas. ;-)
Chas. ;-)
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 241 Post(s)
Liked 187 Times
Hello unclefalcon,
welcome to the forum.
I am like you. When I find a bicycle I am curious to know more about it, even if it is of no particular value or quality.
It is difficult to see the detail in the lugs and if there are any brazed on pieces to the frame. Also is there any indication of a headbadge?
Without more detailed pictures of the frame the best clue to identifying a brand name is the serial number and its location and comparing this to other bicycle frames with similar serial numbers.
There are more than one brand names that had this format of serial number and location.
As stated by @T-Mar Centurion is one possibility. I have a 1974 Centurion LeMans, with the same serial number format and location. Your frame does not match my LeMans. As noted by T-Mar the seat stay caps are incorrect, among other differences.
Centurion had a Sport 5 model with this type of seat stay cap. But the only example of this that I have seen is a juvenile bike with24 inch wheels. It also has several brazed on pieces.
As you are in Washington state there are a couple of other possibilities, again based on the serial number.
Boyes and Rosser Ltd (BRC) of New Westmister, BC. The Alpine Sport model sometimes had the same seat stay caps. Again it had pieces brazed onto the frame.
Monshee and Eliminator brand names by Norco (originally from Burnaby, BC).
The fork. Most or all of the above bicycles had a fork with a chrome cap on the crown. Your fork does not have this, but it looks like there is the shadow of a cap that is no longer there.
Anyway, enjoy the project.
Hello unclefalcon,
I removed a ring from the fork before I had it chemically stripped, that might be the cap you're talking about. I'll take some more pics and post them shortly.
Rider
Bikes: 1961 Mercier, 1968 Chiorda, 1992 KHS Summit
The frame is likely mid 70s given that it has stamped dropouts on a lugged frame, but it's interesting... The rear dropouts remind me of the varsity with the flared eyelets, but the fork crown and seatpost lug reminds me of a 'schwinn approved'
Volare...
So idk. Schwinn is a solid contender here, but it could be something else. What color was it originally? Do you have any pictures from before it was stripped? What components were on it that could be original? Could you post a few clear shots of the lugs and check the seatpost size and what the BB threading is? I think we can ID this with a little more info.
Volare...
More pictures:
This was in the frame, but I have no idea if it was original. Maybe you can tell the thread from this?
I believe these are the original rims: ARAYA 27x1 1/4 w/o HP.
Rider
the sealed BB is definitely not original, but if it fits it does tell us the BB is 68mm BSA (English). a 1" seat tube suggests this came with a 1 piece crankset originally, reinforcing the 70s vibe. Araya rims were not uncommon on other brands like Nishiki and Raleigh, but a lot of 70s
and 80s Schwinns are known to have come with them. The models I'd look into are the traveler, sport, spirit, le tour, paramount, tourist, supersport, varsity, and the voyageur, along with the 'world' editions, 2nd and 3rd editions, etc. at a glace all of those models can be found with a very similar fork crown, BB, and dropouts, but I haven't found an exact match to the headset yet.
Whatever it is, make it beautiful again!
Liked 3,039 Times
I believe we are pretty safe in saying that this is not a Schwinn, Nishiki or Raleigh, as the serial number format and location does not match any of their known manufacturers.
Liked 3,039 Times
