Schwinn one-piece crank lengths?
Quoted: 790 Post(s)
Liked 348 Times
Hello, I pulled a crank out of a Schwinn Breeze single-speed bike and it looks to be 165mm from the centers of the bottom bracket and pedals. Does anyone know if Schwinn made a variety of crank arm lengths? I have three one-piece cranks out of non-Schwinn bikes and they all measure the same, about 6.5", or 165mm. Seems to be an industry standard. Since I am tall and put a lot of miles on a bike with a one-piece crank, I thought it might be nice to try a longer crank. If one is not easily available, I will just cut a few spare cranks up and weld them together to make a 170-180mm length.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Yes, but it's 6 1/2 inches. Not metric! Just like a "559 mm" rim is 22 inch diameter so a 2 inch tall balloon tire comes out 26 inches. Unlike "Schwinn Approved" lightweight stuff with Euro and Taiwan components, this was a US part, and cruisers were for adolescents.
There are bigger sizes. 180 is probably hard to find, though. Try to find one that's chromoly. There are Walmart-quality ones on Amazon that I'm sure would be easy to weld but then what do you have when you are done?
There are also tubular steel arms that go in the same bottom bracket shell
https://www.amazon.com/Alta-Chromoly.../dp/B07MLHFY8X
and conversion kits to put a threaded bottom bracket in the 1-piece shell
https://www.amazon.com/Truvativ-00-6.../dp/B000VT550K
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Quoted: 811 Post(s)
Liked 1,024 Times
The one from a Schwinn Varsity, Continental or Suburban is longer. This on has a diamond cross-section crank. I don't know exactly how long, but it is longer. @Vintage Schwinn might know.
Looking over my Schwinn bike collection, it appears that cranks from female bicycles measure 6.5inch ( I have Suburbans, Continentals, Collegiate, Breesze) all male versions have a 7" crank. So you should be able to pick up any old Schwinn for cheap and try it out
Quoted: 790 Post(s)
Liked 348 Times
That is amazing they would put that long a crank arm into those bikes, that is like 177 or 178mm. Most all road bikes don't come with anything longer than 170mm, a lot of mountain-bikes came with 175s, the only time I ever saw anything longer than 175 was a set of 180mm Dura-Ace cranks on an old Motobecane I raced with a long time ago. But I hope that is true, that they are that long. My old man who is 85 has a Continental hanging in his barn, but it is a very small framed bike for a short person, and again, that makes it very surprising it would have cranks longer than 6.5".
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
I just measured 2 of my 1973 Schwinn Super Sports, as I knew they were nowhere near 7 inches. 6 5/8” as close as I could get. That is the diamond shaped arm. That comes out to a bit over 168mm.
Likes For sd5782:
mycocyclist
Quoted: 910 Post(s)
Liked 822 Times
Measured my '64 and '73 "24 inch" Super Sport's cranks, and both are 6 3/4" Center to Center, so ~172 mm.
Likes For machinist42:
Quoted: 790 Post(s)
Liked 348 Times
That makes sense. I guess I will be cutting some cranks up and welding them into a 175-180 length. One thing I did notice is that the Schwinn cranks are narrower than the cranks I have from other USA brands, so that may give some advantage as long as it will clear the frame of a non-Schwinn bike.
Quoted: 811 Post(s)
Liked 1,024 Times
There were longer one piece cranks made for BMX back in the day. Some seem to still be available. I did a quick search and came up with these at 175mm and chrome moly.
Chrome moly one piece crank 175mm
You will also need new cones and a nut with this crank because the thread pitch is different from Schwinn.
Last edited by Velo Mule; 04-27-22 at 01:29 PM. Reason: Thread difference information
Likes For Velo Mule:
Quoted: 790 Post(s)
Liked 348 Times
Quoted: 90 Post(s)
Liked 137 Times
Since I live in a Beach Cruiser area and build 20 to 30 bikes a season I can say that 175 one piece cranks are everywhere, I have had some 180's but they are not common. Any one piece crank will fit the Schwinn but you need the BB to go with them just because of the threading Schwinn used. BMX Cranks are where I would look for Cromo and 180's. While the bearings may differ it's just the count, 9 ball, 10 ball are most common.
Glenn
Glenn
