Modern touring wheelset with dyno hub - what can you recommend?
Quoted: 838 Post(s)
Liked 1,080 Times
Looking to invest in a modern wheelset to use on a few different frames, but will go on my Voyageur first. Much of my daily riding is done at night, and so a dynamo light makes sense to me for various reasons (quality of light, the issue of always having to charge, front bag blocking light if light is mounted on bars etc). More camping and light touring are also in my future this year.
For the light, based on aesthetics and reading lots of reviews the SON Edelux II makes sense to me. For rims, CR18 36 spoke (I'm assuming the advent of newer wheel technology renders needing 40 spokes obsolete?) also seem to fit the bill for price/quality/aesthetics but I'm open to anything else. Where I'm stuck is front and rear hubs. Dyno hubs seem to vary wildly in price and I'm not sure on how they do or don't interface with various lights and what to look out for.
Last thing, no way I'm building these myself, so hoping to find a solution where the whole wheelset can be purchased ready to go, but will have a LBS build them for me if need be.
Any insight is appreciated, thanks!
Quoted: 1829 Post(s)
Liked 3,375 Times
I've got two SON dynamos... one purchased in 1999 (first generation), and then a newer one purchased in 2008. Both have served me very well.
I build my own wheels, so can't comment on who builds wheelsets.
Both wheels are built with CR-18 rims and have been used for commuting and general abuse. 36 spokes on the 700C wheel, and 32 spokes on the 26" wheel.
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
Quoted: 838 Post(s)
Liked 1,080 Times
Steve in Peoria
Steve in Peoria
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,796 Times
SON if price is no object
SP if you're looking for value
Sanyo or Shimano for pure functionality
I have all of the above, they all work just fine. SON and SP have least turning resistance. SON widebody makes the strongest wheel and may be more durable.
Likes For gugie:
My understanding is that SP hubs, while lighter than Shimano hubs, have more drag and provide less power than Shimano hubs. Source SON hubs are the best-performing by all accounts. I've had a Shimano DH-3N80 on my main bike for five years and it's served me well. I've repacked the bearings a couple times, and when a bungee cord got stuck in the spokes and wrecked the electrical connector, I was able to replace the part with something scrounged from a cheap Nexus dynamo hub.
Likes For eeuuugh:
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I have a SON and a 3N80 the SON is prettier but on the bike I can’t tell the difference.
Quoted: 1188 Post(s)
Liked 1,154 Times
Figure out what you want to pay and get a hub at that price point. Germany is the cheapest for dynamo hubs but Shimano is now out from there due to geoblocking.
I rode through 3ft of water with a Shimano 3N80 and didn't get a drop inside, so the sealing is pretty good on those.
Got a SON on my tourer, SP on my partners, can't tell the difference really, even with a forumslader doing USB charging. Shimano have a new hub, the DH-UR700, supposed to be way less drag and more efficient than previous models.
Spokes DT Swiss Alpine III the pro nipples with hemispherical seat.
Rims, I like rhynolite XL, they're cheap, super strong and have eyelets. They'll work tubeless with Joe's Rim Strips.
The building is the most important factor! You need somebody who knows how to set bends and stress relieve properly, while getting spoke tensions even. You can have the best components, but if it's built poorly you'll have problems.
Likes For Trevtassie:
Bikes: Numerous
Quoted: 1677 Post(s)
Liked 3,095 Times
I have a Shimano 3N72 laced to VO rim on my tourer. It works fine but have found that I can feel the vibration of the hub up through the handlebars, so kind of annoying. I have a SONdelux wide en route from Germany and I plan on building it onto a TB14 rim for my tourer and move the Shimano wheel to a city/errand bike I’m putting together..
I recently found that Handsome Cycles sells built dynamo wheels at decent prices
https://handsomecycles.com/collections/dynamo-lighting
Peter White cycles is also one of the few US distributors of SON hubs and also a great resource for all things dynamo.
https://www.peterwhitecycles.com
Likes For Spaghetti Legs:
Quoted: 3810 Post(s)
Liked 6,690 Times
As is usually the case, Velomine can set you up for a very reasonable price:
https://www.velomine.com/index.php?m...pl9gfbo9squq14
For me, I’ve been running SP hubs since they first came out and have been very happy with them. Half the price of SON but more than half the performance!
Likes For nlerner:
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times
If you just want generated light vs battery light, the SA Dynohub is a cheap alternative and still out there. Not nearly as bright as modern lights thouht. 20 years ago, I picked up 2 for cheap $, found the original headlight produced weak, but reliable, light for the country roads of my commute. Later replaced SA headlight with a Busch & Mueller Lumotec Halogen headlight which cost around $80 from my LBS back then. It produced adequate light. At the time, was concerned that I might build a wheel, then find the Dynohub didn't function. A trusted tech at our LBS re-assured me. Said he had never seen 1 that didn't work. Just did a search and surprised that those old Lumotec Oval headlights go for around $100 now, so if you want to go cheap, look for a good bottle generator setup, still available on the Bay for not too much $$. Don (edit: reminder, Dynohubs are chrome plated steel, not aluminum, so heavy as sin but they are durable)
Likes For ollo_ollo:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I've been looking at prowheelbuilder.com but haven't pulled the trigger yet. They have SP and Son dynamo hubs and a wide variety of rims (including Velocity and VO for retro types). One item that source seems to be missing is triple butted spokes, but they do have some double butted options. The website has a nice tool to let you "build" your wheels and see the price and weight. Prices seem very good to me - you could build a decent wheelset with an SP dynamo for around $500. Maybe $700 if you went with a Son dynamo.
Likes For tyrion:
Quoted: 838 Post(s)
Liked 1,080 Times
Likes For polymorphself:
Quoted: 964 Post(s)
Liked 1,451 Times
I commute on Shimano DH-3N30 laced to a Mavic A319 rim. I bought it used and have been commuting on it for the past 3 and a half years through snow, ice, rain, grit, and salt. Been taking the bike regularly in and out of cold and warm places, so I'm sure it's had plenty of moist air go inside the hub, as it has none of the fancy Schmidt pressure compensating technology. I've had to replace a cone after 3 years because the bearings got real grumbly. Took 45 minutes. That's the only maintenance I've had to perform. They say you can't change the connector-side cone, but I did it (with two wrenches, sitting in an office chair) so anybody with two wrenches and a brain can do it.
The trade-off, I think, is between weight and serviceability and price. Certain Shimano hubs are efficient as Schmidt ones, or at least one BQ test said they were, and unlike Schmidt, the bearings can be serviced without unlacing the wheel. But they're heavy. The few SP hubs that have been tested for efficiency are less efficient than their Schmidt and Shimano counterparts. However, they're cheap and lightweight (but also can't be disassembled to change the bearings unless you take apart the wheel).
I'd be interested in the resistance stats for the SP SV-9 versus a Schmidt SONdelux. Has anybody checked the SV-9? I know the PV-8 has a bit more drag than the SON28 and SONdelux, and the PD-8 is the same (more nuanced analysis with different lights), but what about the small ultralight SV-9? I have heard promising things, but no real data.
The front wheel is under much less stress than the rear no matter how you slice it. Less weight overall, and symmetry means all the spokes share equally in the load, so you're probably fine with almost any rim you choose. I toured on a Nashbar-branded MA40 copy (they look identical) for six months. Broke all manner of stuff, including a front racks and two rear wheels during that time, but the rim was fine - and it's a pretty lightweight thing.
For the rear rim, since you say "wheel-set", I suggest the heaviest thing out there if you are planning on carrying much load touring for a long time. I like the Mavic A319, Ryde Sputnik, or Ryde Andra.
I don't think 40 or 48 spoke wheels have been made obsolete, but the market has deemed them unnecessary. No idea why, but I'm confident it's what an economist would call a "market failure". They didn't stop being stronger or more durable over long distances. They just stopped being profitable. I am unhappy about this, but that's the way it is.
Sunshine
Quoted: 10956 Post(s)
Liked 7,487 Times
Contact them- call or email- and talk options if the site is too confusing due to all the options.
Sapim double butted spokes and brass nipples are good value from them too, though they may only allow plain gauge spokes with a dynamo hub.
As for rim- the cr18 is fine, I have a set, but there are much nicer options for not much more $.
H Plus Son Archetype is a really good rim thst comes in 32 and 36h. You don't need more spokes than that for a front wheel on a modern rim like this. The front wheel with 36h is simply overbuilt(I have one) in all situations except the most extreme examples.
I've bought 2 wheelsets from prowheelbuilder and cant say anything negative about either experiences.
An Archetype rim, sapim strong butted spokes, and a son 28 hub habdbuilt costs $418 before discount. Shimano dynamo hub would be less.
Likes For mstateglfr:
Likes For RobbieTunes:
Quoted: 378 Post(s)
Liked 1,409 Times
Quoted: 964 Post(s)
Liked 1,451 Times
Is this based on your personal experience, or some published source?
According to the sources I have read (here and also here), the SP hubs have more drag above 20km/h, with the lights on. And some old Shimanos (3N30, 3N70) have the same drag as the old SON28 (BQ Vol. 3 #4).
I've got a bunch of different Shimanos, old (3N30) and new (S500), and a Sturmey (XL-FDD) and I can't feel a difference between any of them, lights on or off. Some resonate with some frames and make a slight buzzing when the lights are on, but that's all I notice.
Telling the difference between dynamo hubs' resistance by riding them seems a bit like that old fairy tale, "the princess and the pea" to me.
Likes For scarlson:
Liked 5,796 Times
Coulda sworn I saw data awhile back claiming SON and SP are about the same, your sources show differently.
Likes For gugie:
Quoted: 7348 Post(s)
Liked 2,465 Times
Modern lights need so little power that you can power them with any dynamo hub. The more you spend, the less drag the hub has. I've been riding on Sanyo hubs for a few years. They are the cheapest and draggiest, and I don't mind, and they fully power my lights. It sounds like SP is the best compromise between performance and price.
Buy the fanciest headlight you can afford.
You'll be glad you did this.
Likes For noglider:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
I'm with @noglider on this. Get the best headlight you can afford. And don't worry too much about the particular dynamo.
I have had a Shimano DH-3N30 for well over 10 years and have run the Shimano Nexus 8 into the ground while the dynamo is still spinning smoothly. In fact that whole bike is falling apart but the dynamo is still running.
There is a reason why most cheap companies don't survive entering the Dutch bicycle marketspace. Dutch people are HARD on their bikes. (read: downright neglectfully so)
My current daily commuter runs a Sturmey Archer XL-FDD, my rando bike a Shutter Precision PL8 and my girlfriend rides a Shimano DH-3N80 but just because I liked the way it looked better than the Shimano DH-3N72 at the time.
And just like @scarlson I do not notice any difference in drag but the SP does tend to vibrate a bit around the 22 kph (13 mph) mark for me. Then again, I have heard the same for the SON but at slightly different speeds depending on the bike. Some frequencies just resonate.
My guess is the Sturmey Archer makes it less noticeable because it's a dynohub with integrated drum brakes. All that weight must dampen it somewhat.
On my new project I plan to use a Son 28 disc center lock but only because I like using 36H wheels. The SONdelux disc center lock only comes in 32H.
Curious to see what the hype is about and they do make some really nice over-engineered hubs.
These are all good hubs. Unlikely to fail and the drag is negligible.
CyclingAbout has a blog post that gives you some calculations on how much they slow you down:
How Much Do Hub Dynamos Really Slow You Down? - CyclingAbout,com
EDIT: A really affordable way is to buy a pre-made wheel from German places like Bike24.com. Starting at €75 + shipping ($91) you get a cheap Shimano + Mavic wheel or spend some more for a SONdelux + DT Swiss R460 rim at €259 + shipping ($314).
Though personally I would go for a different rim for touring.
The most-efficient hub will slow you down:
10-30 seconds per hour with no lights or chargers attached
1-2 minutes per hour with a USB charger
1.5-2.5 minutes per hour with a bright light
The least-efficient hub will slow you down:
0.5-1 minute per hour with no lights or chargers attached
2.5-3 minutes per hour with a USB charger
2.5-4 minutes per hour with a bright light
Likes For JaccoW:
Liked 6,690 Times
I have had a couple of dynohubs fail on me over the years. One was a cheap model that V-O sold at one point (maybe a re-labeled Sanyo?), which stopped working after a season of deep winter commuting. Another was a Kasei, which seemed to replace SP for a short time. It would emit a horrible noise every now and then, which went away when I disengaged the lamp, but would eventually come back after another few hundred miles. Relaced that wheel with an SP and no problems since.
Clark W. Griswold
Quoted: 4352 Post(s)
Liked 3,989 Times
Huge +1 on the SON hubs but if you are looking for a more budget option that is still decent SP hubs are actually pretty solid. If you are doing something with a cassette in the back, White Industries would be my pick if freewheel Phil Wood of course. If you need a heavier duty wheel set 36 would probably be the sweet spot but a 32 will work as well.
Likes For veganbikes:
jj
Quoted: 140 Post(s)
Liked 110 Times
For commuting and weekend tours I wouldn’t bother with the expense of a dynamo system over modern usb-lights- even if the expense is just a CR rim and a Sanyo hub strung up with non-butted spokes.
Bikes: Numerous
Liked 3,095 Times
I would disagree and say daily commuting is one of the better reasons for a dynamo. Charging lights on a regular basis is a big annoyance for me and then on top of that, if you don’t charge your lights every day, then guesstimating if you can get one more ride out of the charge. Knowing your lights are ready to go, anytime, anywhere is a wonderful luxury.
