Ask your small, random, track-related questions here
#1351
Bikes: road and track
A buddy of mine is lending a powertap wheel for my bike. I plan on using it during the offseason; I use a garmin edge 500 on my road bike. Any recommendations/suggestion on screens to use for training.
During the week, I either use the rollers or trainer.
#1353
Depends on the workout. I am usually just looking at straight power on the rollers/trainer(even on the road), or power, lap time, and possibly lap power for intervals. For most intervals and just riding I will use straight power, for longer intervals I use 3s. If you use it just riding around on the road then maybe do speed in there as well if you care but if you're structuring workouts off of power targets, speed and distance don't matter.
#1354
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
If you play it right, you'll come out of the winter with a decent spin. But if you spend the winter grinding away at 70RPM you may not.
There is a time for grinding and a time for spinning.
#1355
Bikes: Bianchi Pista, Bianchi Vigorelli
I've got power meters on all my bikes at this point- and after spending a lot of money to get there, I sort of feel that there is not a ton to gain for track racers- especially sprinters.
The key things for me are-
Being able to calibrate trainer efforts to track efforts based on power output and cadence. But to really dial that in you need power on your track bike and Trainer.
Keeping an eye on my output on sustained efforts on road rides so I don't detonate myself.
Beyond that you are typically just looking back at data.. And I'm as big a fan of that as anyone- but it honestly doesn't affect what I do next..
My best year on the track was before I had power- did it all with a $20 speedo and a $20 stopwatch..
#1356
Elitist
Liked 92 Times
I used a PM for several years as a (wannabe) sprinter and looking back, most of my decisions were made based on cadence vs speed as just about every effort was maximal. If you hit Xrpm, then your gear was too low. If you couldn't hit Yrpm then your gear was too high. Wattage was just an interesting byproduct.
A power meter is great for enduros and roadies who want to work on threshold stuff. It's also good for coaches to monitor an athlete's fitness. "She hit X watts...she's getting stronger." "He can't hit Y watts, he may be overtrained."
Just my humble opinion.
#1357
Occasionally people ask about home-building a start gate. Here's what we've got at Hellyer now.
.be
#1358
Bikes: T1, S2, P3
Quoted: 5 Post(s)
Im along the same lines as you Quinn, I haven't purchased power for the track yet but some days wish I had it just for the sake of 'I wonder how much power that was'.
I supposed you could compare times vs power to get a better understanding what you were doing, but really the times are all that matter, regardless of the power it took to get there. Because we are in a static environment (compared to road riding), speed is a pretty reliable gauge of power anyway.
#1359
I only have an old turbo, which doesn't add much resistance via the fly wheel. How else can I increase the resistance, if at all? I want to get a better turbo, when I can afford it. Are fixed wheel spin bikes a good alternative? I have access to them at the gym.
#1360
Quoted: 31 Post(s)
I would be concerned that lifting weights would make my legs feel heavy and slow...
#1362
Bikes: S-1 :-D
Quoted: 17 Post(s)
Elitist
Liked 92 Times
Yes, Fixed wheel spin bikes that use pads for resistance can work very well for starts, provided that the rest of the setup is decent (you can put track bars on it) and stable.
#1365
Mag trainers are sort of better than fluid or turbo trainers because you can turn on instant resistance.
#1366
Like Quinn I have SRM's on all my bikes. On the track bike I do find the data invaluable for Pursuit training. For other track training and racing no so much other than analysing the data post racing...
#1367
Speaking of power meters, what are your guys' thoughts on Power2Max Track powermeters? It goes up to 2999W and is relatively cheap.
I need a new set of cranks for my track bike anyway and figured I might as well spend an extra $1000 to get power data. My only concern is it's a BSA bottom bracket frame and would need a BSA to BB30 adapter, any gotchas with this as far as performance?
#1368
Bikes: T1, S2, P3
Quoted: 5 Post(s)
I noticed those lately too, I think an ad on facebook (amazing how 'not random' ads are these days). Im looking to get the rotor crank anyway and this would add about cost of adding stages to a DA crank.
Still $1000 though
Still $1000 though
#1369
#1370
VeloSIRraptor
I chatted with the guys that had them on their bikes, they were happy and had no complaints. Were I to go back to a track PM, I'd go that route over an SRM. YMMV
(source: had an SRM, spent time with guys using P2M & Powertaps)
#1372
Elitist
Liked 92 Times
Keep in mind that all wireless power meters need about 3 seconds or 2 pedal strokes to start recording data. This means that the initial crazy torque of sprint standing starts will be missed. Only the wired SRM can record that initial torque spike. Even the wireless SRM cannot record the initial torque spike.
#1373
Not true for the Stages Meter-
assuming you are using the high sample rate iPhone app
#1374
End up always doing held starts instead of wheeling these onto the track...
