Bontrager Aeolus Comp 5 TLR: hit or miss?
Quoted: 8 Post(s)
I recently bought an Emonda SLR frameset from my local Trek dealer and the shop made me an offer: 50% off a brand new Bontrager Aeolus Comp 5 TLR wheelset, which is 300£. Should I take it?
P.S. The Comp 5 is the wheelset with a carbon fairing attatched to an aluminium rim, with a depth of 50mm. My current wheels are Campag Khamsins and the Bontragers are only 50g heavier yet much more aerodynamic than the Campags.
Quoted: 608 Post(s)
Liked 352 Times
If you can afford it, I say yes.
At worse you have a back up set of wheels or you could sell them to a friend at the price you paid.
Fifty percent is a screaming deal.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I think the 1/2 off price probably makes it a valid pricepoint but not a great deal from objective standpoint. This I think is an 1,860 gram wheelset, which is no lightweight. I wouldn't pay this myself for this theoretical upgrade. Eg. compare to some Fulcrum Racing 4s at also about a $300 pricepoint. 150 grams or thereabouts less in weight, but still get a 35mm rim depth.
Quoted: 850 Post(s)
Liked 344 Times
I’d also agree that at 50% it’s a maybe. There aren’t many good wheelsets available at that price, so it’s hard to say no.
But, Aeolus Comps are quite narrow, which, with 25 or 28mm tires, will cause inefficiency and instability. If you plan to use narrow 23s (ie not the gp4k) it will be better.
I also notice that the spoke entry holes in the fairing are not airtight (similar to FLO, HED), which probably causes you to give up a couple watts relative to a full carbon clincher of the same depth. This is what the dispute between FLO and Hambini was about. Even the revered HED Jet 6+ seems to perform like it’s 10mm shallower than it is.
I’m not saying that the alloy + carbon fairing wheels are bad. I would recommend the Jet 6+, actually. But that’s a wide, slightly lighter (1760g) and aerodynamically proven wheelset. Alloy/carbon rims also have braking and responsiveness advantages relative to full carbon clinchers imo.
The main question I’d ask is, why do you want an aero wheelset? Are you racing? It’s not gonna be a whole lotta watts you’re saving. Especially not over something like a Boyd Altamont, which is wide, 30mm deep and weighs 1550g. Of course, that wheelset is nearly twice the price... but I wouldn’t fall into the trap of buying things simply because they’re cheap. The cheapest wheelset is the one you already have.
EDIT: on Prowheelbuilder, where I ordered my Altamont, you can lace a set of altamonts to Bitex hubs (which are decent enough imo, especially if you ever get around to replacing the bearings) for $576 and the weight comes out to 1470g quoted. Not sure how much a similar build would cost in the UK.
Quoted: 696 Post(s)
Liked 910 Times
I’d pass. Carbon wheel looks with entry level alloy wheel weight.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Quoted: 8 Post(s)
Thanks for your replies everyone! The reason why I want an aero wheelset is because I live in an area with many flats and my current wheelset is better for hills. My average speed is around 25 mph so the aero benefits will help me save some useful watts and I plan to do some time trials with the bike.
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
Given that you are a strong rider, i think you'd get the most out of nicer wheels than relatively heavy wheels like the Comp 5 TLRs.
Quoted: 850 Post(s)
Liked 344 Times
Likes For BluFalconActual:
Quoted: 850 Post(s)
Liked 344 Times
I’d say, in the interest of catering to your budget, you should look to novatec or bitex hubs. The hubs that LB lists on their website are the weight weenie models with less bearing durability. I have the bitex RAR12 (the robust one) and it’s been just as good as my DT350 hub.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Save for full carbon wheels like Pro or better. Get the carbon ride.
Edit: Ask for 50% off Pro 5s or 3s. I have 5s. Not too bad in the wind but the 3s would have been good.
The COMP are the fairing over the AL wheelset. They're not light, they're not wide, but they are deep. With the narrow width and depth, I'd be worried about crosswinds. I'd pass.
Disc or Rim brake?
Disc or Rim brake?
Quoted: 8 Post(s)
I second LB. After I got my wheelset, 4 of my teammates followed (though they were all disc brake users).
Carbon-Ti hubs though since they have the Campagnolo option and they seem to be worth the extra money. The AR56 rims laced to Carbon-Ti hubs with Sapim CX Ray spokes weigh around 1410g for around £1000 so that seems to be the best option out there IMHO.
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
I'm also very interested in the Lightbicycle wheels now. I think I'm going to go with
I'll likely get a gravel-oriented wheelset from them but with the light Novatec hubs.
Advocatus Diaboli
Liked 1,532 Times
Just came across these also.. anyone have experience with this company's wheelsets (Scribe) ? About the same price range and weight as LB
https://scribecycling.com/collection...wide-50-1-434g
Quoted: 850 Post(s)
Liked 344 Times
Quoted: 8 Post(s)
Sadly there's not space (recommended maximum is 25c for rim brakes) so I'll go for the R55s or build a custom one in the LB wheel builder.
Quoted: 1067 Post(s)
Liked 259 Times
Emonda with direct mount rim brakes will take any 25mm tyre on any rim.
Not sure why you didn't get a more aero frame though for riding at those speeds an flat roads with the possibility of doing time trials?
Quoted: 8 Post(s)
The H1 Emonda is the best option according to my fitter. It's also extremely light (my 47cm frame came at 600g) and it had a stunning paint job.
Quoted: 850 Post(s)
Liked 344 Times
https://www.bikeforums.net/road-cycl...le-wheels.html
