Can an 8 speed shifter be made to work with a 7 speed cassette?
Quoted: 7 Post(s)
Howdy folks,
Please have patience with this newbie to the forum if my question seems like a "Duh!" one. I've been out of the saddle a looong time (mountain bikes were a new novelty when I started riding) and I've found the tech's changed dramatically since those days when I virtually lived on 2 wheels.
I've taken my 1995 GT Tequesta out of mothball and had to 86 the original Shimano STX rear/right hand shifter. I tried rehabing it by completely dismantling & degreasing out the tar/sand/crude that was not letting the cam engage. I cleaned it thoroughly with trichlorethylbadstuff, but found after rebuilding the unit and applying a light silicone lubricant to the metal parts, I could only get 6 shifts out of it and not the 7 that it used to do, hence, my decision to deep 6 it altogether.
Obviously the STX line's long discontinued & 7 speed units that are Shimano derailleur compatible are not easy to find as most units are now 8, 9, 10 or higher speeds. I'd like to avoid replacing the rear derailleur and/or cassette as both are still in good working order showing minimal wear and tear.
I've been told I can use an 8 speed shifter as long as it's Shimano derailleur compatible and simply limit the derailleur travel using the derailleurs limiting screws.
Is that true and/or are there other things I need to take into consideration?
Thanks in advance for reading and I look forward to hearing from anyone out there.
If it's a 7-speed shifter, it will have 6 clicks. If you don't believe me, count them on your fingers: 1 to 2 is 1, 2 to 3 is 2...
Quoted: 1438 Post(s)
Liked 1,092 Times
As KenCarlson stated you have the right number of shifts for a 7-speed shifter, but Amazon has many trigger, twist and brifter styles of shifters to choose from.
Quoted: 1944 Post(s)
Liked 2,164 Times
If, after heeding the advice given above, and if it turns you get 6 gears and 5 clicks, then the answer to your 8 speed shifter question is yes.
I started mountain bike riding late in life and when an LX 7 speed shifter was giving me problems, I went to look for a replacement. I found older 7 speed shifters so overpriced, and new ones were not very good, and I could get a better 8 speed shifter for less.
I took my 7 speed cassette apart. Sanded the plastic spacers from 3.15mm to 3.0mm. Put it together and ran 7 gears with 8 speed shifters and never looked back.
John
John
Likes For 70sSanO:
Quoted: 431 Post(s)
Liked 460 Times
You can use 8 speed shifter with a 7 speed cassette. Be sure to set the limit screws correctly on the RD. Obviously you will have 1 click in your shifter that will be blocked by the limit screw (you can pick high or low).
Quoted: 7 Post(s)
Understood, but the indicator only goes to "6" now. I haven't reinstalled the unit and attached the cable to it so could that have something to do with it only indicating 6? going
Constant tinkerer
You can also you 7 cogs of an 8-speed cassette. That will get you exactly the right shifting. Or measure the thickness of the 8-speed spacers, and use them with your 7-speed cassette. The differences between 7/8 are very minor and sometimes you can get away with mismatching, but not always.
Quoted: 7 Post(s)
Quoted: 7 Post(s)
Thanks
John
John
Update: I've tried it one last time and it seems the gear shift gods have decided to smile upon me: The shifter now is running through all shifts except the last two on the return. I'm suspecting that it will work properly once the new cable is installed and there's tension on the return.
Thx to all again
If you do end up needing a new shifter, it looks like you can get a set of Microshift ones for pretty cheap: https://www.amazon.com/MicroShift-Th...322857&sr=8-23
I haven't tried their 7 speed stuff, but I know from experience their 11 mountain bike shifter is solid.
Likes For bubish:
Bikes: Lemond Poprad, Cervelo Soloist, Cannondale F4, RANS Velocity Squared
Quoted: 42 Post(s)
Liked 67 Times
John
John
Likes For BobsPoprad:
