Disc brake compatible front hub motors
Are there 500w hub motors available that take disc brake on the same hub?
I want to run a front hub motor, and uprate the front brake to disc.
Currently I have a Cell aluminium-framed mountain bike. It's an MTX-2 hardtail model with RST Kapa suspension forks, modified with handlebars that rise an extra 10cm, mudguards, rack, slightly wider seat and skinnier road tyres ( 26 x 1.9). The front forks have the early style posts for a disc caliper, where the bolt holes are parallel to the axle. I'm guessing adapters are commonly available for employing current model calipers.
All suggestions, pointers and tips appreciated.
Quoted: 1074 Post(s)
Liked 295 Times
Never seen one. Has always seemed strange to me. More weight, more speed - and rim brakes.
Maybe they're waiting for regenerative braking to catch on?
IS mount to Post mount adapters are still readily available.
Meanwhile, best braking from a motor hub is probably with a ceramic coated rim and Magura hydraulic rim brakes.
Quoted: 2338 Post(s)
Liked 2,827 Times
you may want to check in the electric bike section
