sticker removal best way
raised by a cup of coffee
Bought a frame with a ton of stickers on it, was looking for best way to remove them. What is the best way.
Thanks,
Gregg-o
Thanks,
Gregg-o
chicks love scars, and bones heal.
N+1
Bikes: A few
Liked 5 Times
A hair dryer works well too. I remove all of my rim stickers that way. Heat up sticker and peel away with fingernail. Touch up with a little goo gone to get rid of glue residue
out of shape
porous stickers you can saturate with acetone, slide off, then clean up with more acetone or goo gone. nonporous stickers benefit most from heat and a steady hand with a straight razor, and then cleanup with goo gone. remember that if you're using a razor blade to keep it tangent to the frame tubing.
Bikes: Trek Domane, Soma Smoothie, Surly Big Dummy/Pacer/KM/Ogre, and a revolving collection of vintage stuff
Goo gone fumes? Smells of oranges.
moar wine!!!
Bikes: Brigdestone RB-2 : Gunnar Roadie : Masi Gran Corsa : Gunnar Crosshairs : Specialized Stumpjumper (overseas)
Originally Posted by operator
Hairdryer + peel. Use goo gone to clean up residue.
Bikes: 1996 Bianchi Reparto Corse Cyclocross steel, 1985 Bridgestone 400, 1986 Trek Elance 400, 2007 Cannondale Synapse carbon, 1992 Cannondale R400
sticker glue removal
I purchased a nice rebuilt set of wheels for a song. However, the previous owner removed the rim stickers without first using a hair dryer to soften the glue. As a result, a thick coat of glue was left on the black rim. I researched this forum and others for a glue removal solution. I also asked at a couple of LBSs.
I wanted to do the job indoors while watching the Tour de Georgia nightly updates. But first, I tried lighter fluid, acetone, and Goof Off outside. The results of all 3 barely softened the glue. Light fluid/acetone/other petrochems all evaporate too quickly to really soften the glue. I don't want to sit there and scrub the rim for 30 min. on one sticker while breathing toxic fumes (carcinogens - and I worked for Chevron for 20 years!).
So, back to the hardware store. They had a citrus-based gel made for varnish and glue removal. The guy said to test it first to make sure it doesn't take the paint off the rim. I was pretty sure that rim paint is epoxy based (anything else would scratch too easily), but I tested to be sure.
No problem. The citrus gel worked without affecting the paint at all. I experimented, and found that leaving the gel applied over the glue for 30 min. was effective. I used a plastic scraper to get the thicker portion off. I then re-applied the gel, let it sit for 15-20 min., then scrubbed with an old wash cloth. All the glue residue was gone! I'll wash the rim with Simple Green afterwards to remove any citrus gel residue and to clean the brake track.
The citrus get is about the same price as the Goo Gone plus (or whatever they call the up-brand), is not toxic to breath or get on your skin. I'm working over a tile floor, and the drops of gel don't affect the tile at all.
In the end, the citrus gel is effective at removing heavy glue residue wihout a lot of muscle work, and it's also environmentally friendly.
Razor blades? Acetone? Only if you don't care about the underlying paint.
On new stickers, heat and patience will often allow you to peel from a corner and have the entire sticker come off clean. Don't go with the solvents until you get as much as possible without them, as they make a gooey mess. On solvents, I start with alcohol, then escalate to WD40, citrus goo gone, then the nastier goo gone stuff. Acetone will work, but it is a rare clear coat paint job that can hold up to acetone.
A hard plastic scraper (like an car ice scraper) is the best tool. NEVER use anything metal.
- Mark
- Mark
stay free.
Bikes: EAI Bare Knuckle, 1980's Ross Signature 292s 12 speed
I use the hairdryer and peel back method, just go slow and heat the bit you are peeling with the hairdryer as you're pulling it off.
SWAAAAAAAAAAAT
Bikes: masi speciale fixed (urrringe), haro f1 (black), haro x2 (red)
brake cleaner will take anything off. watch out for your paint though.
Lamb of God
