For the love of English 3 speeds...
#8401
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
@gster - great looking bikes!
I have a photo of him doing some final grinding but don't want to post without his permission.
edit: looking at the photos, if I knew my work was going to be in close ups, I woulda polished it up through 240 grit!
#8402
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
So @gugie agreed to do some welding work for me on my 1971 Raleigh Twenty. I'm using modern brakes and the rear one wouldn't reach the rim (Tektro R559), so wanted the rear brake bridge plate moved down. The plate serves 3 purposes; brake bridge, fender mount and original rack mount. I am using a modern rack, so he suggested using those eyelets for mounting racks on the seat stays, then using a normal piece for the brake bridge. I also had him remove the chain guard attatchment piece since I am not using the chain guard. Of course now it will really need painting.
Raleigh Twenty Brake Bridge by velocivixen, on Flickr
R20 New Bridge by velocivixen, on Flickr
Rack Eyelets R20 by velocivixen, on Flickr
Looking forward to seeing this one finished.
g
#8403
Liked 5,795 Times
Here's a photo of @gugie doing the final touches.
Mark's Final Touches by velocivixen, on Flickr
#8404
Bicycle Repair Man !!!
I opted for V brakes when I modded my P20 and have added V brake bosses to a number of frames... if a 20 is going to get a new coat of powder or paint it is worthwhile to add bosses or bridges for better brakes.
Your work looks great btw.
#8405
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
Happy belated birthday, @Sixty Fiver!
#8406
@Sixty Fiver - Your R20's have been an inspiration. They are all quite unique.
#8407
Am presently building a number of SA coaster hubs for customers, this solves the rear brake issue nicely.
#8408
Liked 5,795 Times
Thanks for the compliment! For small wheeled bikes, V brakes are good choices. Velocivixen is lithe and lean, the Tektros are more than adequate for her needs, IMO.
#8409
I have to warn people about the brakes on my P20... it stops on a dime and gives back a nickel in change.
#8410
@ Sixty Fiver - I searched this and can't find specific info so please bear with me when I ask. My Raleigh chain wheel has 46 teeth. When I tried a 48 tooth it rubbed the chainstay. So my question is: if I were to have the bottom bracket cut down to 73 & rethreaded to standard would I be able to get a bb with a long enough spindle (square taper) so the teeth would not scratch the frame? Longest is usually about 127.5 or so.
#8411
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Wouldn't it be easier to get a larger rear cog? That would prevent a lot of work.
#8412
Liked 2,446 Times
Meant "smaller." Can't edit or do much else these days in this forum.
#8413
The issue is the current cottered crankset is fine, but I may want to go cotterless using a square taper bottom bracket. The issue isn't gear inches or anything. With a modern chainring I would maybe go as low as 46t.
#8414
#8415
Quoted: 1299 Post(s)
Liked 103 Times
I've noticed, not on 20s but on the Sports models is that sometimes there's a flat hammered into the right chainstay for added clearance behind the chainwheel and sometimes there isn't. I think this was done at the factory because the paint is undisturbed. A fudge factor sort of thing. Anyway, setting the chainstay against an anvil and hammering it a bit flatter seems to be one way to keep the chainwheel from rubbing on the frame.
Have you decided on a color yet?
#8416
#8417
Liked 103 Times
I can see that. One thing I know for sure is that this low carbon steel can be heated and not become hard and brittle. It can also take plenty of cold forging without weakening. I think that if modifying the BB and crank caused clearance problems, forging a flat on the chainsay would be a legit way to go.
#8418
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
#8419
More photos of @gugie at work. Note the wild sparks! I thought my tires were gonna melt!
Sparks Fly on R20 Modification by velocivixen, on Flickr
1971 R20 Modification Progress by velocivixen, on Flickr
Grinding Chain Guard Mount by velocivixen, on Flickr
Again, I am really appreciative and happy that @gugie was willing to help me out on this. I'm very happy with the results.
#8420
#8421
Bikes: 2014 Cannondale Synapse Carbon 4 Rival; 2014 Cannondale Trail 7 29; 1972 Schwinn Suburban, 1996 Proflex 756, 1987(?) Peugeot, Dahon Speed P8; 1979 Raleigh Competition GS; 1995 Stumpjumper M2 FS, 1978 Raleigh Sports, Schwinn Prologue
Quoted: 213 Post(s)
I hope to be joining this club tomorrow! A Raleigh Sport for an actual reasonable price has been spotted on my radar, and IMO is worth the 2.5 hour drive. 3 speeds don't come up too often where I am, and if they do you are looking at somethign way overpriced, or completely roached.
#8422
Liked 103 Times
#8423
Liked 443 Times
#8424
Liked 443 Times
#8425
Quoted: 213 Post(s)
