Question Regarding Cross Training/Weight Lifting
Quoted: 81 Post(s)
Liked 7 Times
I've been turning to the gym to do some cross training/weight training in my off season and I had a question regarding something that happens to my left knee whenever I squat: On my way down, the large tendon on the outside of my knee (I believe it's the hamstring tendon), feels like it rubs over a bone, moving its position, and on my way up it snaps back to its original position. It's not painful at all when it happens, but I don't want to cause issues further down the line - this only occurs when I squat, and doesn't occur any other time (lunging, DL, cycling, running, etc). I'm a fairly experienced weightlifter, having exercised for around 15 years but never fully explored my squat because A) don't have a spotter and B) I never wanted to press the issue with my knee. I don't remember always having this issue but can't pinpoint exactly when it started happening. If I turn my knees slightly inwards, I loose strength but the tendon does not snap back and forth.
Anyone have any idea why this occurs and how to fix it? I'd really like to start squatting heavy to build leg strength but don't want to cause bursitis or tendonitis.
Appreciate any input from other experienced weightlifters.
Quoted: 1027 Post(s)
Liked 325 Times
No idea why that is happening, but please note that squats, while a very good exercise, are not necessary to build leg strength. Lunges, deadlifts, and even the leg press are all decent alternatives.
Perhaps try squatting with your toes pointed more forward and your knees tracking along your toes? If sticking your knees out wide is causing the problem, don't do this.
Quoted: 81 Post(s)
Liked 7 Times
When I squat, I hold what is considered "good" form, with the knees tracking directly over the toes, weight in the heels, and no lateral movement in the knees. The exception is when I experimented and moved my knees inwards about 1/2-1" each which eliminated the snap, but kept my feet in the same position. Might try to squat sumo style, with my toes pointed out and see if that makes any difference.
Liked 325 Times
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
I assume you're talking about the back squat. Have you tried the front squat? You won't be able to lift quite as much, but it will force to keep strict form. Might help with the knee.
Quoted: 4227 Post(s)
Liked 2,488 Times
If one exercise is causing any type of problem, then find a safer alternative. In your case if the squat is an issue, find another exercise. There are a lot of leg exercises which don't involve a barbell.
Liked 2,488 Times
Make sure your form is spot on. Don't use your knees to initiate the squat... Initiate the squat movement with your hips/glutes and sit back when going down and then coming back up.
just another gosling
Quoted: 3888 Post(s)
Liked 1,938 Times
Using this position takes a little getting used to. Your inner hammies will get sore - careful not to pull one. Increase the weight slowly. Sumo is for deadlifts and the guys who go really heavy don't use that style. Snatch, yes. If you want to have fun with weights, the snatch is more fun than anything.
Results matter
Results matter
Liked 325 Times
Oh wow. Totally do not do that. I'm 5'6", heels maybe 15" apart, toes pointed out ~30°, knees tracking directly over toes, knees never extending past toes, weight on heels, back straight except for a little butt wink at the bottom if I go down all the way. A powerlifter who's been in the top 5 several times, nationally and internationally, helped me get my position just right. Mirrors help a lot if you don't have an expert coach. Here he is:
https://www.youtube.com/watch?v=gyc1MB7ei5Y
As for the rest of it, yeah that's pretty much the default for how to squat, but everyone is a bit different. I agree about the "sumo" style squat. It's good for lifting maximum weight while wearing a multi-ply squat suit and using a monolift so you don't have to walk it out... but that's about it IMO.
Likes For OBoile:
Quoted: 81 Post(s)
Liked 7 Times
I think this is my biggest takeaway - I want to keep cycling for the next 60 years, so I will stay away from exercises that my body doesn't seem to like and find others that suit it fine. I've always struggled with the squat, I wonder if my lower body is just poorly set up for it.
