Ultegra Di2 6870 and Garmin Edge 520 Controls
Old 04-14-18, 06:30 PM
Orion12521
Orion12521's Avatar
Liked 2 Times in 1 Post
Searched the forum and the internet and not really getting a clear answer on this. Can you control a Garmin Edge 520 using 6870 shifters? I currently have the 1st Gen D-Fly, SM EWW01. What is the minimum I need to make this happen? My current setup uses full Synchro Shift and if possible, I'd like to use the forward buttons on the Di2 levers to control the Garmin. 6870 group set, with a SM EWW01 D-Fly and the battery has been upgraded to BT-DN110.
Orion12521 is offline
Old 04-16-18, 10:43 PM
sirkaos
sirkaos's Avatar
Bikes: 2017 Specialized Roubaix Expert, Surley Karate Monkey 29er hard tail
Quoted: 77 Post(s)
I have the same set up. The short answer... no can do. Of course you will get the bluetooth displays like gear ratio or when you are full synchro you will get the little message when you change front chain rings. To me, it is not worth the cost of upgrading to 8000 shifters for the buttons. Do you really need to look down so much? Paging through all the info?
sirkaos is offline
Old 04-17-18, 04:04 AM
Orion12521
Orion12521's Avatar
No, not critical, but if I were able to... Thank you for the feedback.
Old 08-07-19, 06:44 AM
Orion12521
Orion12521's Avatar
Update: This is possible with EW-WU111 DFly unit. 1st Gen DFly does not work.
JonnyHK
Foo
10
03-26-12 02:14 PM
larwyn
Classic & Vintage
1
05-26-11 09:48 PM
geej
Singlespeed & Fixed Gear
2
03-30-11 06:11 AM
buelito
Fifty Plus (50+)
4
10-28-10 07:47 AM
scrapmetal
2
10-09-08 06:06 PM
