Hoses and suction, strange occurrence.
Old 03-05-19, 11:02 AM
u235
u235's Avatar
Quoted: 332 Post(s)
Liked 31 Times in 24 Posts
An interesting engineering dilemma I think I have the answer too.
I have a hose sitting on top of my pool cover down in the collected water. That hose is stretched out and the end is down hill. The hose is about 25 feet long, 1.5 diameter, and the ends are about 4 feet difference in height. Roughly 5 feet in the pool, 20 foot out of the pool. I always lean the distant end up against the fence about 8-10 inches to keep some water in the end of the hose so the hose never drains completely to keep air from going back up the hose. I leave it like this all winter. When I want to drain the pool top and assuming the hose stayed with the end up.. I walk out the hose starting at the pool towards the end and it burps and starts flowing and the cover drains. There is always enough water in the end to start the flow with some assistance. Last night about 3am I went out outside to check on something unrelated but I heard water running. Sure enough, the pool cover was draining itself. Although at a much slower pace than normal, it was coming out. I have no idea how this started on its own. It hadn't rained in 24 hours but there was a build up of water on the cover because I hadn't drained it in a while. I know it was not draining earlier in the day. The only thing that happened is it got extremely cold last night, down in the teens. hmmmm.. It seems the natural convection caused by the difference in pool cover water temperature and the end of the hose was was just enough. As the water left the pool, it cooled and became more dense and was the driving factor. Makes sense but not sure how it originally started unless the rapid cooling of the water in the end drew a slight vaccuum.
u235 is offline
Old 03-05-19, 12:37 PM
roadfix
hello
roadfix's Avatar
Quoted: 154 Post(s)
Liked 4 Times in 3 Posts
A large animal stepped on the hose.
roadfix is offline
Old 03-05-19, 07:45 PM
. Cranky .
Unfluoridated Member
. Cranky .'s Avatar
Bikes: Road
Quoted: 12 Post(s)
Liked 13 Times in 7 Posts
Was there any ice on the surface of the pool?
. Cranky . is offline
Old 03-05-19, 08:16 PM
MontgomeryMeigs
Quoted: 5 Post(s)
Liked 4 Times in 2 Posts
3am?
There is a slight possibility you were sleepwalking and not in the backyard at all, but in the bathroom hearing the water drain from a different hose.
MontgomeryMeigs is offline
Old 03-05-19, 08:57 PM
canklecat
canklecat's Avatar
Quoted: 2910 Post(s)
Liked 243 Times in 185 Posts
Change in surface tension? Barometric pressure? There's a PubMed paper that touches on the effects but I don't have the patience to wade through it.
canklecat is offline
Old 03-05-19, 11:58 PM
u235
u235's Avatar
Quoted: 332 Post(s)
Yes. Started forming when the temp dropped. Tonight.. It's back down to the teens again, a thin layer of ice is there now and the remaining water was slowly coming out again.
u235 is offline
Old 03-06-19, 12:40 AM
genec
genec
genec's Avatar
Quoted: 6689 Post(s)
Liked 131 Times in 87 Posts
Remember, water expands when it freezes... might be enough to start that "push."
genec is offline
Old 03-06-19, 01:09 AM
canklecat
canklecat's Avatar
Water expands when it freezes, when it's heated... it's always expanding. It's gonna take over everything. We'd better drink it all before it gets any bright ideas.
Old 03-06-19, 02:02 PM
. Cranky .
. Cranky .'s Avatar
Bikes: Road
Quoted: 12 Post(s)
The pool and hose constitute the basis of a hydraulic lift. If you apply a weight over the surface of one side, then the water level on the other side will go up. I bet the weight of the ice on the pool was sufficient to push the water beyond the end of the hose and start the siphon.
pedsrider
Introductions
1
07-29-08 07:55 PM
damnlove
Introductions
2
04-29-08 07:52 AM
simplyred
Road Cycling
16
04-09-07 07:54 AM
