Cursed BB90 on its way out?
Quoted: 31 Post(s)
Liked 13 Times
If the article is to be believed, Trek is likely to ditch the much-hated BB90 in favor of the threaded T47.
I have too few posts to insert a link, bu the article is on the Cycling Tips website with the title "Trek rumored to be switching to T47 threaded bottom brackets"
Since all forms of press-fit BBs seem to be a royal PITA, this seems like a wise move.
Kinda-link: cyclingtips.com<SLASH>2019/05/trek-rumored-to-be-switching-to-t47-threaded-bottom-brackets/
Link: https://cyclingtips.com/2019/05/trek...ttom-brackets/
I have no idea what that means (I know what those are, just not he significance) but I'm pretending to be helpful.
Quoted: 1303 Post(s)
Liked 1,911 Times
Road 292,
It is likely a good move on their part. I remember the early Garry Fischer bikes with pressed in sealed bottom brackets and I got one with the wrong spindle. It went across the country twice before the customer got his bike. With a threaded BB I could have done it in an hour. Smiles, MH
Quoted: 31 Post(s)
Liked 13 Times
Thanks for the link fix. Working on my post count...
A few years ago Trek switched to a proprietary bottom bracket format they call BB90. They claimed it was awesome because it saved a few grams of weight by doing away with pretty much every part of the bottom bracket except the part that contains the bearings, which is pressed directly into the bottom bracket shell in the frame. The BB90 has been plagued by creaking issues, and the lack of bottom bracket support structure means the bottom bracket shell of the (carbon) frame slowly deforms or cracks. Trek's main motivation with BB90 seems to have been to save a few dollars and not a few grams. It's good (IMHO) that they seem to be considering moving back to a threaded design.
My Domane had creaking issues since new in late 2017. Replaced the BB with a Token BB3724. Night and day difference. At my weight the difference in bottom bracket weight is negligible
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
i have had external bb creak worse than my BB90 , hey what ever they choose as long as it add some performance to the frame ,
its definitely more user friendly ,
but you can still strip threads , crack your carbon bb shell area , and all sorts of other issues ,
no one system is a really better ,
external on alu frames are a good choice , but maybe when they switch we will see even more problems arise ,
with bikes its best to stick with what works ,
people have created all sorts of ways to make the problems of the bb90 easy to fix ,
simple solutions make these BBs easier to use , my tolken bb still creaks and makes wierd noises ,
but its smooth ,
and im really not worried too much
but its smooth ,
Also, there are certain manufacturers that seem to have fewer problems than others, likely due to differences in tolerances. Cannondale, Trek and Niner do not have good reputations while Giant, Look and Specialized are generally seen as less problematic. Of course there are exceptions.
I will say that of the 5 guys in my group who have either brand new or 1-2 year old Madones, 4 have had persistent BB reliability issues. Not a good sign, especially since these are very expensive bikes.
Quoted: 31 Post(s)
Liked 13 Times
If I understand correctly, the T47 supports the same 86.5mm bottom bracket shell width as the BB86 and BB90 (and maybe there also is a 92mm version for MTB; not sure). That seems to be one of its attractions, as it would require only minimal frame changes for manufacturers such as Trek that already have frames designed for 86.5mm bottom brackets.
