Road Endurance or Gravel
Road Cycling ďIt is by riding a bicycle that you learn the contours of a country best, since you have to sweat up the hills and coast down them. Thus you remember them as they actually are, while in a motor car only a high hill impresses you, and you have no such accurate remembrance of country you have driven through as you gain by riding a bicycle.Ē -- Ernest Hemingway
Old 06-27-19, 10:13 PM
Choocharoo
hi everyone.
I have been riding for years in mountain bikes mostly. Right now I have a giant Roam XR and am looking to go to road biking. Iím 6í2 to 6í3 and weigh 265. When I check out giant, trek and specialized most donít say much for weight but some guess in the 275 bike+rider; and some 300. Iíve read about mostly avoiding carbon and making sure I go 28 or more spokes. Outside of that I have a budget of about 1500 ish cdn and been debating on a contend disc. I donít have any 1st hand experience with specialiZed or trek so just looking for input. Even cannondale synapse would be a option. Ultimately just wanna get back doing more road riding with the occasional dip down a hard gravel path.
thanks for any input you might provide and a good bike considering my overall size.
Ciao.
Choocharoo is offline
Old 06-27-19, 11:03 PM
daoswald
Quoted: 179 Post(s)
Liked 28 Times in 16 Posts
Looking at the spec sheet for Cannondale Synapse bikes, the weight limit is a 300 pound rider, regardless of whether it's a carbon fiber or aluminum frame. I've seen some pedals with weight limits under 190 pounds, though I suspect most mainstream pedals can probably stand up to riders of 300 pounds and more. By main line I mean like Shimano 105 level, or a notch on either side of it.
Seat posts may have rider weight limits. But again if your bike is rated to 300 as purchased with its stock wheels, the seat post that came with the bike wouldn't be rated lower. Pedals are the only thing you have to add to the bike to ride it, so just take care not to purchase ones that are rated to lower weight specs than the bike.
daoswald is offline
Old 06-28-19, 06:52 AM
WhyFi
WhyFi's Avatar
Quoted: 9267 Post(s)
Liked 320 Times in 196 Posts
Gravel is kind of an ambiguous term. If you're talking about riding primarily on pavement with the occasional jaunt on some relatively smooth, crushed limestone, 28-32mm tires would be great (that's what I run most of the time). If you're looking at longer periods on more chunky, loose stuff, then you'd probably want 35mm+.
The other consideration with regard to tire size is your weight. Larger volume tires will allow you to get away with lower pressure (without pinch-flatting), which will be more comfortable over bumps, crack, and seams. When I was 220, I could pretty easily run my 30mm tires at 70psi, which I find to be comfy on pavement. At 265, you'd either need to run 30mm tires a little harder or you'd need to go slightly larger, to 32s or even 35s.
WhyFi is offline
Old 06-28-19, 10:17 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 8498 Post(s)
Liked 438 Times in 263 Posts
You don't have to avoid carbon because of your weight. I wouldn't buy a used carbon bike from a stranger personally, and your budget might have you on a metal frame. But if it has some carbon parts, they won't asplode on you.
Seattle Forrest is offline
