Tire overall diameter vs width
Quoted: 15 Post(s)
Lets say a 700x28c tire has 6mm clearance between seatstays and chainstays, but only 4mm clearance to the seattube. If one chooses a 32c tire, that should add 2mm to each side, still giving 4mm clearance. But, does the overall diameter increase by 4mm, or is it more like half just like each side so increase by 2mm? Would it theoretically touch the seattube?
Thanks.
Thanks.
Quoted: 630 Post(s)
Liked 369 Times
There is no definite answer as it depends on the tire, rim, and air pressure. But here's a general rule of thumb:
https://www.bikecalc.com/wheel_size_math
Based on that, 700x28 is 678mm diameter, 700x32 is 786mm diameter. The increase is 8mm diameter or 4mm radius so it will be very tight
Quoted: 18883 Post(s)
Liked 10,646 Times
You won't really know for sure until you try it. Some tires measure big for their size, some small, and then the rims you put them on have a big effect too.
Quoted: 6195 Post(s)
Liked 4,810 Times
Over all diameter increases by 8mm. But different makes and models of tire YMMV. It's just an estimate. You do only get roughly 4mm closer to the seat post, brake caliper or whatever is of the most concern on your bike.
The formula to estimate tire diameter is Wheel diameter = rim bsd + tire width * 2
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Only way to tell is to borrow or buy a candidate tire. Issue with really tight to the fork is that bits of gravel etc. picked up by the tire will scar the fork's crown. No big deal if alu, but not so good if carbon. Seen that happen.
Results matter
Results matter
Quoted: 20810 Post(s)
Liked 9,456 Times
Your direct question has been answered, so to chip in I'll add this: when most manufacturers specify that a frame will clear a certain tire size, it's typically with ~4mm clearance on all sides - that's generally the minimum that they want for clearing debris and whatnot. With that in mind, you may want to ask yourself why manufacturers want that clearance and whether or not you're comfortable going with a thinner margin for error.
If your clearance is tight, you might find it gets tighter as your tire gets older and thinner as the tire will balloon out as it gets more flexible.
Liked 4,810 Times
(the wheelset has an inner width of 15mm)
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
