The best headlights under $50 thread
Old 10-08-08, 07:36 AM
  #126
ItsJustMe
Seņior Member
ItsJustMe's Avatar
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 442 Post(s)
I just got my UltraFire C3 Q5 last night, and rode in with it today. I went with a single 14500 cell for today's test. The light output was sufficient (not wonderful, but sufficient). The big problem was that it cut out at about 30 minutes. I could turn it back on again but it'd shut off again quickly. Then I put it on medium output instead of high, and it lasted the remaining 10 minutes of my ride.
Tomorrow I'm going to try it with two AA cells. The light output is a bit less but should still be acceptable, and two AA NiMHs have nearly twice the watt hour capacity of a single 14500, so it should have plenty of run time.
I'm not totally happy with using flashlights as headlights. From MY point of view, sure, they're great. But they have no cutoff and in my testing this little flashlight gave more glare to oncoming drivers as both low beams of a car. I think I may wind up going with an Ixon IQ primary and using this flashlight as a backup.
BTW, I did some beam comparisons last night, click here to view.
My 3-year-old, 13W TrailTech HID and the UltraFire with all 3 battery options.
Work: the 8 hours that separates bike rides.
ItsJustMe is offline
Old 10-08-08, 02:36 PM
  #127
dougmc
dougmc's Avatar
Bikes: Burly Canto
Originally Posted by prtyich View Post
I bought a Planet Bike Superflash for the rear, and a Planet Bike 1 W white Blaze headlight. Any opinions on these?
I've got them both. I'm very happy with them.
They're both very bright, and I've found both to be more than bright enough for my night road riding.
dougmc is offline
Old 10-09-08, 05:35 AM
  #128
ItsJustMe
Seņior Member
ItsJustMe's Avatar
Quoted: 442 Post(s)
Follow-up on the UltraFire C3 Q5. With 2x AA NiMH, it's still bright enough, and it lasts at least long enough for my 42 minute commute.
I did have some problems with the switch though. It seems erratic. I went over a bunch of gravel road, fairly rough, with minimal problems, but then it just kicked into strobe mode while riding on smooth pavement. Also at several points the output level dropped down a bit, and went back up when I whacked it. So, power is OK, but the switch, not so much. The build quality on my sample is otherwise excellent, but if that switch doesn't mend itself (I've seen switches get better after a little use) it's going to be a problem.
I bought the flashlights as an experiment, and they seem to be a good solution weight-wise. But IMHO if I were going to spend $50 on a headlight solution, I'd go with DIY halogen again. When my HID bulb dies, I'm putting my MR16 fixture back on the bike and using the flashlight as a backup.
Old 10-10-08, 04:28 AM
  #129
Jeesters
Jeesters's Avatar
Bikes: Scott Speedster S50
How are you guys mounting these flashlights to your helmets?
Jeesters is offline
Old 10-10-08, 04:41 AM
  #130
ItsJustMe
Seņior Member
ItsJustMe's Avatar
Quoted: 442 Post(s)
The UltraFire was OK for a 2nd day on the same set of AA NiMHs. However, the switch is quite erratic. I probably had to whack it 20 times on the 40 minute ride to get it back up to full brightness, and one time when I hit a bump it jumped about 3 modes.
I think the Q5 is an acceptable headlight, but I'd probably go for a single-mode, more durable switch model next time. But if I had to go with something like a Fenix at $60 to $70, well, I can buy a NiteRider MiNewt USB for about $80 and get a hell of a lot more runtime and better mounting options.
Old 10-10-08, 11:14 AM
  #131
beowulf7
World's Most Modest Man
beowulf7's Avatar
I wonder if Velcro would work well.
beowulf7 is offline
Old 10-15-08, 10:36 PM
  #132
fanta510
Does anyone know if the Romisen RC-N3 CREE Q5 LED torch is waterproof?
fanta510 is offline
Old 10-15-08, 11:51 PM
  #133
mechBgon
mechBgon's Avatar
Here's my method: fairly large O-rings. The photo below shows my Fenix L2D Q5 attached to the side, but I currently have a different light (Olight M20) attached to the top-center instead. Anyway, O-rings are one option to look at.
mechBgon is offline
Old 10-16-08, 07:17 AM
  #134
harleyfrog
An Army of Fred
harleyfrog's Avatar
Location: Lost South of Nowhere East of Edan On the Waterfront Far from the Madding Crowd (Biloxi, MS)
Bikes: 1992 Specialized Crossroads Trail
The description says "Water resistant design". By that, I take it that in rain: OK; deep sea diving: not so much.
harleyfrog is offline
Old 10-19-08, 08:17 AM
  #135
daredevil
cyclepath
daredevil's Avatar
Bikes: 2005 Trek Pilot 5.0, 2001 Specialized Sirrus Pro, Kona Lava Dome, Raleigh hardtail converted to commuter, 87 Takara steel road bike, 2008 Trek Soho
I just use rubber bands.
"Without music, life would be a mistake."
-- Friedrich Nietzsche
daredevil is offline
Old 10-20-08, 05:33 PM
  #136
pennypue
n00b
Bikes: Two
I got my two Fenix L2D's, a few days later I got my Romisen RC-N3 Q5, finally today I got my TwoFish lock blocks. Since I had the Fenix, and it gets dark at the end of my after work ride.....I had to 'engineer' my own mount. Just used two thick hairbands, they did a great job too!
Can't wait to try the lights out with fresh batteries. I had taken the only AA's I could find in the house from my BOB (for when the real one is out of town, which is far too often) The batteries were a little weak, but compared to my BF's MiniNewt I was very pleased. Now that I have TWO for my bars with new batteries AND the Romisen for my helmet....well, let's just say, I intend to be dragging some dead deer home every night.
Thanks for all the great advice in this and other threads. I'm thrilled with my purchases. Especially since they can double down for use dry caving.
pennypue is offline
Old 10-21-08, 06:54 PM
  #137
green814
Sneaky Fast....
Bikes: 2007 Specialized Epic Expert, 2005 Giant TCR C3, 1996 Specialized Stumpjumper M2Comp, 1986 Raleigh Capri 10spd, 1982 KHS Turbo 12spd, Wife's: 2010 Specialized Safire Comp Komen, 2007 Specialized Dolce Elite, 2005 Giant OCR3, 2000 Trek 6000 WSD
Just wondering if anyone has any direct comparisons between the following lights:
Ese AF2 Cree Q5
Ultrafire C3 CREE Q5
UltraFire WF-606A Cree Q5-WC 230-Lumen
Not looking to spend much more on a light, just trying to get the best for the money. I would like one that has a little more "floody" hot spot if possible.
Thank you,
Chris
green814 is offline
Old 10-21-08, 08:49 PM
  #138
pennypue
n00b
Bikes: Two
Rode with the Romisen tonight on a new cr123a battery. Loved it. So bright I nearly got a few deer too. Damn things just froze like a deer in a headlight........roflmao
Did notice that the RC-N3 has a nice hot spot in the center. I can see getting addicted to flashlights.
pennypue is offline
Old 10-22-08, 01:50 PM
  #139
stevemtbr
Creamy pack filling
stevemtbr's Avatar
Bikes: Trek 8000, Co-Motion tandem, Co-motion Espresso, Yeti Cross, 9Zero7 Fat Bike
I purchased and just recieved my Princeton Corona. It was on Amazon for 46.99 with free shipping. Will use it as a helmet light and I have an old Night rider 15W light that will be in the handle bar. Right out of the box I've been pretty impressed. Good quality construction and it even came with batteries! I played with it in my back yard last night and it throughs a good beam on high. When day light savings is over and I start commuting in the dark I will write again on my thoughts on this light.
stevemtbr is offline
Old 10-22-08, 07:24 PM
  #140
green814
Sneaky Fast....
Pennypue: What kind of run time (before any dimming) are you getting with the 2 x AA and the CR123a?
Thank you,
Chris
green814 is offline
Old 10-22-08, 08:18 PM
  #141
pennypue
n00b
Bikes: Two
Thank you,
Chris
Chris, I wish I could say. I've only gotten to ride with the new batteries once. Bout an hour on the cr123a. Didn't notice any dimming. The fenix on turbo with well loved batteries didn't seem to have faded, but once I dropped new batteries in, I could really see the difference.
I hope to get a better feel for battery life once we're riding in more dark after day light savings time hits. I ride mostly on a MUP, so blinding light isn't very important unless it's to startle the deer. (the possum was NOT impressed)
pennypue is offline
Old 10-30-08, 06:35 AM
  #142
dclaryjr
Gray Haired Commuter
First Ride with the Romisen RC-N3 CREE Q5
I placed my order with Shiningbeam on Friday--got it yesterday (with an LED keychain light thrown in-nice touch). I threw together a quick mount by using the bottom half of a cheap light. I used the clip on the flashlight and a zip-tie to secure it. My commute is seven miles mostly on an undivided four-lane with varying amounts of street/ambient light along the way. I was "ok" with a $12 AA halogen since my needs lean more towards being seen rather than needing the light to navigate; however, it was great to be able to see so much of the road surface on the darker sections. I ran it with two AAs--I'm going to pick up a CR123 just to compare.
Terrific "bang for the buck"--hard to beat for the price!!
I
dclaryjr is offline
Old 10-31-08, 02:28 PM
  #143
oakback
I received my Ultrafire C3 Cree Q5 today, shipping was pretty darn quick (a week from order day). Haven't had a chance to use it, I'll report back soon.
Also picked up a new bell and a Plant Bike blinky for the rear, holy crap that thing is bright, do not look directly into it!
oakback is offline
Old 11-01-08, 02:42 PM
  #144
ProsecutedBiker
The Broke Biker ;)
ProsecutedBiker's Avatar
Bikes: 1 Road Bike<-Won it =)
http://www.rei.com/product/750565
This is what I have at the moment. They were 25$ at REI.
The front light is bright enough to see with and to be seen with, and the way it attaches to the handlebars is great. It is tight enough, and it takes literaly, like 2 seconds to remove.
The cuberider in back is bright anough, and has the blinking option which is nice, but i dont really like the attaching method. There are rubber rings that im afraid will break/fall off. While i havn't had any problems yet, ill probably just get some good ol' duct tape and mount it using that
overall, a great buy!
ProsecutedBiker is offline
Old 11-03-08, 11:52 AM
  #145
thebeatcatcher
my legs are carbon
thebeatcatcher's Avatar
Originally Posted by Ziemas View Post
This light with a Two Fish holder would be great. You'd have enough money leftover for a charger and batteries too.
http://www.shiningbeam.com/servlet/t...CREE-Q5/Detail
+1
I took your advice and I'm loving mine. If you don't need batts/charger, you could almost get two for $50.
thebeatcatcher is offline
Old 11-04-08, 03:12 PM
  #146
stevemtbr
Creamy pack filling
stevemtbr's Avatar
First good ride with a helmut mounted Princeton Corona. With all 8 LED's on the trail was lit up pretty well. My 90min commute from work starts before the sun sets and it's nice to be able to choose how many LED's you want on either all 8, 4, 3 or 1 with dimming and blinking modes. I started my ride with one LED blinking then all 8 come on when I hit the woods. My main light was an old Nite Rider 5 D cell 15W handle bar mount that has served me well for many years died last night. I just ordered another Corona for the handle bar through Amazon, it was $52 with free shipping. It would be nice to have a Q/R mount and to be able to unplug the cord from the light. But over all I'm pleased.
Old 11-06-08, 07:30 PM
  #147
scoatw
scoatw's Avatar
Bikes: 96 gary fisher 'utopia' : 99 Softride 'Norwester'(for sale), 1972 Raleigh Twenty. Surly 1x1 converted to 1x8, 96 Turner Burner
After reading this thread. I went with the Romisen RC-N3 CREE Q5 LED Flashlight. I've had my eye on the Fenix L2D. But I went with the Romisen instead because of costs. Before, I had the Cateye Opticube HL-500 and the flashlight is like night and day. It lights up the road ahead of me like I've never seen before. I'm extremely happy I bought it thanks to you guys. I'm still in the process of reviewing it to see how the runtime is. So far I've used it for three days on my 45 min morning commute using Ray-O-Vac Hybrids and its still going strong. I would recharge the batteries in the Opticube about every 5 or 6 days. So if the Romisen last that long then I'll be satisfied. The best part is the wide flood and the bright spot on it. The spot does'nt get washed out in streetlights. I've ordered the mount featured on DealExtreme. But for now I've used this. http://www.youtube.com/watch?v=HrfZhEzjWwg So far, so good.
scoatw is offline
Old 11-06-08, 07:56 PM
  #148
dclaryjr
Yep, great bang for the buck!! If you're concerned about cost, this DIY mount will cost pocket change and I think is actually better than many/most of the commercially available ones:
http://www.bikeforums.net/showthread.php?t=482839
dclaryjr is offline
Old 11-07-08, 04:00 PM
  #149
AEO
AEO's Avatar
Bikes: Bianchi, Miyata, Dahon, Rossin
trustfire TR-801 cree Q5-WC is brighter than a 200L dinotte head light, but has about half the run time.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
http://sanfrancisco.ibtimes.com/arti...ger-photos.htm
AEO is offline
Old 11-10-08, 09:37 AM
  #150
oakback
I was excited to use this light. It worked great, I used the strobe setting more than anything else (since the mornings have more light after the time change.
Recently I pulled it off the bike to assist with some auto repair with my d-cell maglite died. Quickly I noticed a problem, as the light wouldn't turn on. Changed the battery, and it still wouldn't work. I'd shake it, and sometimes it comes on. I don't know what the problem is, I figured the mechanics of a flashlight aren't too difficult to get right, but sometimes I shake it and it works, other times it won't come on at all. I'm disappointed. I think I'll go with the Romisen next time.
oakback is offline
Copyright Š 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
