Tyre pressure at altitude
So far I have done all my cycling at altitudes less then 300 metres but I will be tackling passes over 2700 metres in Europe later this year.
My question is how much does the higher altitudes affect tyre pressure? I understand that bicycle tyres are known to explode in planes which fly at 10,000 metres. (so I will deflate the tyres when flying)
Should I let some air out to compensate for the altitude? I have my tyre pressure at 75psi which is the limit for the tyre I use. (28mm tyre) If I pump the tyres to 75psi at sea level will they still be 75psi at 2700 metres? or is the tyre pressure relative to the outside air pressure?
Thanks
Mat
Thanks
Mat
i did a quick search on the web, but didnt find anything good. my guess would be to check your tire pressure as you gain altitude to make sure it doesnt go above what you want.
hopefully someone with better knowledge will respond.
have a great time on your trip
No matter how fast I'm going, I'm in no hurry.
there are no bicycles in the valley, the only bicycle you find in the valley is the bicycle you ride down there.
Ride in the front, this space is available to anyone that wishes to take it-jjmolyet
The Red Lantern
If you have 75psi at sea level you will have a higher pressure at 2700 meters because the air is less dense and is not pushing as hard against the outside of the tire. Since the tire casing is does not have that much give I dont think it will be a big deal. Besides, at sea level air pressure is 14.7psi, so at any altitude you can still breathe at your tires should be OK. For example the pressure at altitude has dropped to 7psi so your tire would raise to 82psi. However your guage should still be accurate,
I hope this makes sense, reading it back it, I don't think I worded it to well.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
made sense to me.
basically that altitude wont have a huge effect, and your tire gauge will work so you can check them and make adjustments as needed?
Quoted: 19 Post(s)
Liked 7 Times
Ive never heard of a tyre exploding inside an aircraft; has anyone else?
Tyres can generally take a lot higher than their lawyer-proof safety guidline.
It tastes like burning!
all tire pressure gauges measure RELATIVE air pressure... that is, the pressure difference between the air inside and outside the tire. so a 75PSI tire at sea level will "feel" as hard as a 75 PSI tire at the top of mt everest
That said, I took the liberty of calculating how much the pressure would increase if you were to start your ride at 300m and climb to a 2700m elevation:
a measly 3.6 PSI!!!
so I doubt you have any reason to worry about your tires popping as you climb the mountain .
a measly 3.6 PSI!!!
After getting used to the pump I keep at my parents' home which reads one bar low, I unthinkinkingly continued to compensate by filling my tires one bar over after I came home.
On the descent from a 750 meter climb. my overfilled rear tire blew out at 70kph. The tubular tire blew right off the rim and locked the wheel. It was a miracle that i managed to stop the bike upright.
I don't think the altitude will make a big difference, but the heat from the rims on long hairpin descents will make a difference. If you overfill the tires they just might blow at high speed.
Hucker Extraordinare
I beg to differ.
On the way to colorado from kansas 2 years ago.... my rear tire was at 55 PSI .... and it suddenly & randomly exploded as we gained altitude climbing in the mountains... (while it was still in the trailer behind us on the highway).
So... I dunno... heh.
Ok your tire is inflated to 75 PSI at 300 m, and atmospheric pressure is 14.7 PSI at sea level. So lets say you pedal your bicycle up to the International Space Station, you now have virtuallly 0 PSI outside the tire, so your total effective pressure on the tire is 75 PSI plus the "missing" 14.7 PSI atmospheric pressure or 89.7 PSI total. Most 75 PSI tires can handle that kind of overpressure without blowing. I think you need not worry about the reduced atmospheric pressure causing a blow out at any elevation you can breathe enough to pedal.
cycle-powered
Bikes: '02 Specialized FSR, '03 RM Slayer, '99 Raleigh R700, '97 Norco hartail, '89 Stumpjumper
as most of the posters here have said, it will make a slight difference, but it shouldn't be significant.
i do most of my high altitude riding on a mountain bike with more like 40-55psi but i have hardly noticed a difference (last year did about 5 passes over 2700m). just check your tire pressure at the beginning of a ride and you should be fine.
and most of the passes in Europe aren't really that high. there are only a few places where you can ride a mountain bike over 3000m and even fewer on a road bike --- i'll probably be riding the GrossGlocknerHochStrasse some time this summer
and i agreed last night to do a roadbike race with a friend in July that goes over Stilfersjoch which is 2700m... (i rode it on the MTB last August)
Yeah it was the GrossGlockner I was thinking about...I will be up there around September 21 this year. All up I will be tackling about 12 passes over 2000m.
By the sound of it I dont have much to worry about though I do tend to have my tyres pumped close to their limit as all up the weight load is 122kg's. (me, bike, gear, 4 litres water) I guess I will check the pressure as I ascend just to be sure.
Thanks for all the responses.....
I suspect you tires will be alright. I was on the Jungfrau train and saw a packet of crisps (chips) explode, but a tyre is much tougher
The tyres should also be OK in the aircraft as the hold is normally pressurised, however if it was depressurised for some reason (not sure this can be done without affecting the passenger cabin - Any pilots care to answer?) the sudden change in pressure may cause problems.
Enjoy the Grossglockner, Austria is a lovely country - I was there about 9 years ago doing some walking.
cycle-powered
hey Mat,
send me a message before you head out this way... maybe i'll be up for riding the HochStrasse with you...
through the end of august i'm pretty booked (the 9-day TransAlp MTB tour i lead is Aug 1-10), but September is still open. i should be SUPER fit by then (just finished a MTB race last weekend in Italy with 3530meters of vertical in 104km in 7hours 13 minutes)
Hi Nathank,
I think my fitness level would be pretty ordinary against yours and I would probably hold you up somewhat. I start out from Budapest via Vienna, Prague, Salzburg before I hit the big hills so I should be in reasonable shape but I am more of a plodder. (never know I may suprise myself..I have just never tackled huge climbs before...dont know how the thin air will affect my asthma)
I will keep your offer in mind and let you know the exact dates I will be there. I am still very much planning at the moment.
Cheers
Mat
Cheers
Mat
Carfree Retro Grouch
Dave
Just ride.
Two related, but off-topic anecdotes.
I don't know about planes or high altitude riding, but as pucci says, heat can do it. I used to drive a station wagon and often left my bike in the cargo area. Twice during the summer, I came out from work to find that I had one or two flat tires. The bike shop guy told me it was from heat... deflate the tires if you're going to leave the bike in the car during the summer.
Story 2, further off topic: I had a friend that was out in California, driving up... whatisit, Bishops Valley? On the Nevada side of the Sierras, anyway. Drove up Tioga Pass to Yosemite, and on the way heard a big POP!! Couldn't figure out what it was until that night when the found the exploded bag of potato chips. (I know, I know. Celllophane bags aren't tires, I just thought it was funny.)
As a mechanical engineer, I must take this opportunity to clear up a couple of points.
Firstly is the difference between absolute pressure and gauge pressure. The pressure value listed on the tyre is gauge pressure, which assumes an initial (empty) reading of zero. Absolute pressure is simply gauge pressure + atmospheric pressure at any given point. If the difference here is 3.6 psi atmospheric pressure, then the difference in gauge pressure would likewise be 3.6 psig.
Secondly is the relationship between pressure and temperature. Using the equation of PV=mRT that every student learns in chemistry 101, you can easily produce the equation P2=P1(T2/T1). (Tempeatures must be in absolute temperature, by adding 273 to degrees celsius, or 460 to degrees farenheit).
The blowout described by one person was likely caused mostly by temperature increase, due partly to friction on the tread, but mostly by heat from the brakes.
Je vais à vélo, donc je suis!
are you sure?
Atmospheric air pressure at sea level is about 14.7psi. if you went up to an altitude of 10000ft, the pressure would be about 10psi. So wouldn't the pressure if the tires be multiplied by (14.7/10)? That comes out to 1.47. If your tire was at 100psi at sea level, it would be at 147psi at and elevation of 10000ft. This seems to more accurately explain why road tires pop in airplanes if they are inflated to normal riding pressures. Both of my 26" Primo Comet's popped when I was going through a mountain pass. They were pumped up to 100psi. This would mean that it would have been 1.3 times the pressure at sea level.
My reasoning may be off, but here it is.
If the atmospheric pressure pushing against the outside of the tire decreases to half of what it was originally, wouldn't the tire pressure pushing out effectively double?
I got my pressures from here:
https://www.engineeringtoolbox.com/ai...ure-d_462.html
I know this is an old thread, but i'm driving down again and just wanted to clarify.
Quoted: 14 Post(s)
Liked 13 Times
WTF? Add or subtract, not multiply or divide. If worked as you say the pressure in anything would go to infinity as the ambient pressure went to zero, as it essential does in space, in which case any space capsule would blow up...especially if made of carbon fiber.
Quoted: 659 Post(s)
Liked 7 Times
And no, road tires do not pop in airplanes. I've taken my folding Bike Friday on numerous airline trips in its suitcase with the tires fully inflated without any problems. In fact the rear tire is a Primo Comet with a rated pressure of 85psi that I normally inflate to 100psi which is still not a problem when in the cargo hold of an airliner (which is pressurized to be equivalent to an altitude of 8000' or lower regardless of flying altitude). Even if the plane's pressure system failed and all those oxygen masks came down, the effective pressure in the tire wouldn't go over 110 psi which is still well within its safety margin.
Bikes: 2000-something 3 speed commuter, 1990-something Raleigh Scorpion
gauge pressure is a difference between inside and outside pressure. If you inflated a tyre to 70 psi, then took it into space, the gauge pressure would increase by just under 15psi, so tyre pressure would effectively be 85psi. Nothing to worry about, even if you tried cycling on the moon. High-altitude cycling should be a non-issue, especially as there is a safety factor built in to the tyre's rated pressure.
Cargo holds in airliners are at exactly the same pressure as the passenger cabin. It's far easier to pressurise the entire aircraft (cylinder shaped) than just the cabin (cylinder with flat edge)
Never mind the fact that you can't get the tire up to that altitude instantaneously. The tire will leak (why else would we inflate our tires before every ride) on the way, and it's just not going to matter.
