Vittoria just released gravel tire liners. Anyone use a similar product?
Sunshine
Quoted: 10954 Post(s)
Liked 7,482 Times
https://reviews.mtbr.com/vittoria-ai...vel-first-look
I dont ride on surfaces or hard enough that I am almost breaking rims, so I've never really looked into a liner.
Quoted: 427 Post(s)
Liked 339 Times
I thought these were out for about 2 years. We have a customer that loves them, but they ARE A PAIN to install...
Quoted: 6957 Post(s)
Liked 10,959 Times
I don't get it. Doesn't the sealant just soak into it?
It's a foam (or foam like) tire insert that let's you run even lower pressures, while adding extra protection to the rim from hard impacts, and the tire from pinch flats. They have been around for awhile now on MTBs, and are now trickling into gravel bikes as well.
Liked 10,959 Times
yes, I understand that. How does it interact with sealant?
Sunshine
Liked 7,482 Times
The video says its eva foam and doesn't absorb sealant.
There is a special valve to use too since the typical tubeless valve would just push air into the bottom of the foam liner which would make for slow inflation.
I guess it could be useful if you ride on some aggressive singletrack.
Seems overkill for gravel roads.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
The foam seems kind of heavy. I bet if someone made tire inserts that were bladders of butyl rubber filled with air, they'd sell a million of them.
Liked 10,959 Times
Bikes: 2020 Lynskey GR300, 1987 Diamondback Ascent, 1991 Skykomish Marble Point, 1994 Specialized Stumpjumper FSR, 1996 Specialized Stumpjumper M2 FS, 1992 GT Karakoram
Quoted: 69 Post(s)
Liked 226 Times
At $30 compared to Cushcore inserts ($150!), they’re a bargain. I’d definitely try them since my wheels were expensive and I don’t have options for smooth gravel roads here (near Kern River in Bakersfield).
Quoted: 1456 Post(s)
Liked 1,477 Times
Didn't a pro team experiment with some foam inserts inside tubeless tires on a few stages at this year's Tour de France?
I think the goal there was to keep the tire seated on the rim if it flatted, so that riders could make a quicker change.
Some “gravel” can get quite choppy, especially at speed. Also, part of the idea here is that you will run lower pressures than if you didn’t have them, getting the benefit of lower pressures and stronger damping without risking pinch flats or burping. I haven’t used tire inserts myself, but it’s a proven concept for off-road riding and it makes sense. As previously noted, it’s even being experimented with by professional road teams that use tubeless tires. I don’t think it’s going to be a super mainstream item, with everyone running tire inserts for gravel riding, but it’s going to be a nice option for those who would benefit from it.
Likes For grolby:
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
I haven't had any issues just running tubeless, but a friend has been using the cushcore inserts and loves them. He runs 25psi with no issues and said it helped on the really chunky descents.
Quoted: 427 Post(s)
Liked 339 Times
You can drop your pressure unbelievably low without pinch flatting, burping. For some these are worth giving a try, but again. they are a PAIN to install...
Quoted: 101 Post(s)
Liked 41 Times
It not a bad idea, and at $60 for a pair (with valves) the price isn’t crazy. I would almost buy it just to see what it is like to run narrower tires again but with ridiculously low psi.
