Removing Shimano 105 shifters with cables attached?
Old 08-30-20, 09:06 PM
ScottRiqui
Quoted: 38 Post(s)
Liked 34 Times in 22 Posts
I'm about to do my first handlebar swap - replacing the drop bars on my wife's Trek Domane with a more compact version. On road bikes, is there usually enough slack in the brake and derailleur cables to get the shifters off of the old bar without disconnecting them? Or is it a "sometimes yes/sometimes no" kind of thing?
ScottRiqui is offline
Old 08-31-20, 06:23 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
You will find out soon enough.
dsbrantjr is offline
Likes For dsbrantjr:
Old 08-31-20, 06:27 AM
alcjphil
alcjphil's Avatar
Quoted: 1813 Post(s)
Liked 1,691 Times in 972 Posts
If you don't have enough slack, simply remove the bar from the stem
alcjphil is offline
Likes For alcjphil:
Old 08-31-20, 07:12 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,835 Times in 2,293 Posts
Depending on the cable routing and if there's slotted casing stops external one can often remove the casing from the frame stop and gain a lot of slack. Of course if your frame has internal routing then you are about to "pay" for that with the extra work to deal with this kind of service/change. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 08-31-20, 09:04 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
You don't need 'slack'. Just remove the shifters w/ the cables/housing installed and put them on the new bars. I don't understand what the problem is here.
cxwrench is offline
Old 08-31-20, 09:35 AM
Chuckles1
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times in 94 Posts
That!
Chuckles1 is offline
Old 08-31-20, 10:59 AM
ScottRiqui
Quoted: 38 Post(s)
I may not be understanding the job - I thought that the shifters were held on with clamp bands that could be loosened but not removed entirely, such that the shifters have to be slid off the ends of the bars. But it sounds like even if that's the case, I should be able to manage, between unbolting the bar from the stem and the slack in the cables.
Thanks!
Old 08-31-20, 12:44 PM
Crankycrank
Quoted: 836 Post(s)
Liked 1,058 Times in 742 Posts
Most Shifters (but not all) have a band clamp on the bars and can be completely unbolted from them so you can remove your bars without worrying if the cables will be long enough to slide the shifters off the bars. Install new bars, slide on shifter band clamps, bolt shifters to clamps, done.
Crankycrank is offline
Likes For Crankycrank:
