Largest tires on a Giant Escape?
Quoted: 455 Post(s)
Liked 112 Times
I am curious as to what is the largest tire you have been able to fit on a Giant Escape with fenders?
Thanks!
Thanks!
aka Phil Jungels
Don't you have one********** Use a measuring device********** LOL
Quoted: 455 Post(s)
Liked 112 Times
Wanderer, What kind of device could I use in this application?
aka Phil Jungels
Possibly a ruler******************************?? Or, possibly a tape measuring device.
Actual Measuring is So Pre Internet . But since most Posts are from work, I suppose, waiting to do that at home takes too long.
Quoted: 455 Post(s)
Liked 112 Times
So if say I want to see if a 38mm tire will fit I would measure from the outside edge of the rim to an obstruction?
aka Phil Jungels
Measure what you have on there, and the space to the closest of ANY frame parts(both sides of tire and tread) ..... Available space will give you the max additional tire that will fit. I'd subtract 4mm to give myself some fudge room.........................
Sooooooo, if you have 28s on there now, and the available additional space is 16mm, theoretically a 40mm wide tire will fit. (don't forget to recheck tread to frame measurements to clear seat stay bridge, or chain stay bridge, or fork)
p.s., it's always wise to measure the actual width of the tire that is on there now ---- measurements and tire markings don't always equate.
aka Phil Jungels
You are more than welcome - and don't feel bad. I've asked the same question, even though I know how to do it.
DancesWithSUVs
Quoted: 7 Post(s)
Here's where you need to take your measurements. Also note,wider tires are also taller.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
Likes For dynaryder:
Bikes: Giant Escape 2 XL; 2015 Felt Z75 Disc
I'm glad you asked the question. I was wondering the same thing for my 2014 Escape 2.
aka Phil Jungels
And don't forget to also measure the distance from the tire tread to the seat stay bridge, and the chain stay bridge, and the top of the fork.
Likes For Wanderer:
