Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
DIY Bike Fitting for Track
Old 06-19-17, 03:13 PM
carleton
Elitist
carleton's Avatar
Quoted: 1312 Post(s)
Liked 34 Times in 31 Posts
Hi, all.
At some point in time, just like we should all learn to do maintenance on our bikes, we should also learn how to fit ourselves on our bikes. While I do believe that paying for a good bike fit from a professional can be worth it, there are times when it may not.
Ask any bike fitter to fit you for your track bike, and probably all of them will say, "Sure!" thinking that it's gonna be just like fitting for a road bike.
Bike fitting for track is similar but significantly different than for road which is why I recommend asking the fitter if they are familiar with fitting riders for track and if so, how would they describe the differences when fitting for track sprinting, mass start, pursuiting, and all-around. If they launch into a 30 minute explanation, then you've found your (wo)man! If not, beware!
Why the difference?
Because the difference between fitting for track vs road bikes is like the difference between fitting a crit bike vs a touring bike. Why? Because the physical and time demands are different.
Just like a touring rider may ride for days vs a road rider riding for 3-4 hrs, a road rider riding for 3-4 hours is also different than track rider riding for 20 seconds up to 15 or 30 minutes.
Also, the same goes for time trial aerobar fits. A triathlete may be in aeorobars for an hour. You might be in your aerobars for 30s (500M), 60s (kilo), or 3-4.5 minutes (pursuit). BIG DIFFERENCE.
Now, maybe you'll see why going with the guy at the local bike shop that fits all of the roadies and triathletes may not put you in the best position
carleton is offline
Old 06-19-17, 03:30 PM
carleton
Elitist
carleton's Avatar
Here's what I've done in the past:
Get a stable, repeatable bike position setup:
Get a bike trainer that locks the rear wheel. This is a basic setup.
Use Rollers for a more advanced setup only when you want to measure pedaling mechanics and not just angles.
Use a camera:
Either find a good adjustable stand for your mobile phone, use a digital camera, or a GoPro. There are plenty of stand/brace options. You don't need a tripod. Maybe a barstool is enough. You need it to be at a repeatable height, maybe top tube height so as not to distort angles.
Keep the same zoom on the device. Changing zooms will change angles slightly.
Mount up:
Setup the bike such that you and the bike are in the center of the frame. Make sure that you are square to the camera and not angled off. You have to figure out a way to set repeatable cues like (tires on the bottom edge of the frame, top tube on the center line, x meters distance back from the bike...)
Record:
Record yourself pedaling at various cadences (even very slow). This is important. The slow speed is so that you can freeze frame and check your leg angles for comparison.
Check your race tuck.
Add resistance:
Add various levels of resistance and see if your posture changes adversely.
If you can, add enough resistance to simulate a standing start (if that's part of your event).
Download and Review.
Take screenshots of yourself and legs in various positions.
Look for "angle measurement software" for your computer and learn to measure your hip, leg, back and arm angles.
Compare
Now compare all of those to athletes who race the events you prefer and share a similar body type.
Google image search for your favorite athletes and SAVE THE PHOTOS. Use the angle measurement software to roughly measure the angles that they are using and compare them to yours.
I have dozens of videos like this, here is one example:
https://www.flickr.com/photos/carlet...l/12847821545/
This video helped me realize that my arms needed to be extended further out several centimeters. This is a 58cm frame and simply adding a 3cm longer stem would have adversely affected the handling. So, I had a 61cm frame built that kept the same handling but gave me the longer reach...which consequently lowered my back and made me more aero.
What techniques do you folks use?
carleton is offline
Old 06-19-17, 04:20 PM
jsk
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
Kinovea (open source freeware) is really useful for analyzing your video. It can vary playback speed or advance frame by frame, lots of other tools included for measuring angles etc.
jsk is offline
Old 06-19-17, 05:00 PM
taras0000
taras0000's Avatar
Quoted: 318 Post(s)
Liked 15 Times in 14 Posts
That's pretty cool stuff. I can see this being useful to a coach, or someone with some kinesiology background. It used to be that we did bike fitting by looking to align certain points of the anatomy with our contact points of the bike. I believe that kinematics will be the new way we end up fitting people. We already have equipment that can test someone's output as they move through the motion of a squat. Dialing someone's seat height to maximize the amount of time spent in the range of greatest output is something that I've always thought would be a good way to deal with bike fit. This may help in developing tools like that.
taras0000 is offline
Old 06-19-17, 06:38 PM
carleton
Elitist
carleton's Avatar
Nice! I'm a mac user, so I can't give it a try.
There is a iPhone/iPad app called Coach's Eye that does similar.
https://www.coachseye.com/
It's kinda pricey now. I was an early user of it before it got expensive. The problem for me was the the videos ate up all of the storage on my iPhone and I also had to do the analysis there...on the small screen. So, it wasn't optimal. I found it better for me to download the videos/images and work off of my computer.
carleton is offline
Old 06-19-17, 07:02 PM
carleton
Elitist
carleton's Avatar
Yeah, I agree. I'd like to learn more about the subject for sure.
I'm not sure how I feel about the super high-tech ($$$$) bike fitting machines that are out there now. I don't know if they are fluff or not. The bike industry is good creating stuff like that because people will pay for it. That's the same crowd that buys $10,000 - $15,000 tri bikes every year or two.
I wonder how they would compare to a Serotta fit bike with a power meter attached to it:
I mean, that's essentially with a modern spin bike can do:
With the fit bike and spin bike suggestions, I'd figure out a way to use adjustable cranks as crank length is very important.
carleton is offline
Old 06-19-17, 07:36 PM
taras0000
taras0000's Avatar
Quoted: 318 Post(s)
I think a spin bike, but one without pin detents for adjustments, but adjustments like the Serotta would be good. A Velotron eddy brake style rear wheel would also be nice. It acts as the flywheel, resistnace unit, and PM all in one.
I'm not so weary of the hi-tech fit bikes. To me they are an economical way to make rapid adjustments on the fly. They aren't that expensive to manufacture (any decent welder/fitter would be able to fabricate one for you for the cost of a normal decent road bike. For a shop this can be amortized over many customers, so in the end, in the hands of a good bike fitter, the small investment in time and $$ can really pay off. A low tech bike can bring the same benefit in the end. It will just happen a lot slower, and may be arrived at over multiple sessions. At the same time, I believe a bike fitting process is an evolution. It doesn't happen over the course of one fitting. I had a coach who tweaked my position 5 times in the course of a year, and two the next. It takes time to adjust to a position, even miniscule adjustments. Often times, a new position will result in a detrimental performance value in the short term, only to rebound to better than before. If done multiple times with positive results, you can make great leaps if you're willing to sacrifice a season.
Old 06-19-17, 09:54 PM
jsk
Quoted: 160 Post(s)
Yeah I'm pretty sure the fitter I used locally was using Kinovea or something similar. Even for an individual at home I think it can be pretty useful. I've only used the more basic functionality, but for instance I was able to dial in cleat position by using the slow-motion playback to look at knee tracking (left knee was kicking out at the top of the pedal stroke, but it wasn't obvious watching full-speed playback). And you can load two videos side-by-side to evaluate fit adjustments on a single bike or to compare fit across different bikes.
jsk is offline
Old 06-19-17, 10:27 PM
jsk
Quoted: 160 Post(s)
Coach's Eye looks pretty slick but yeah that's kind of expensive for individual use and being limited to a small touch screen interface could get annoying.
jsk is offline
Old 06-20-17, 06:10 AM
dunderhi
dunderhi's Avatar
Bikes: Little Wing, XTRACK, Electron Pro, SuperCorsa, Paramount, & Thunderdrome
Quoted: 68 Post(s)
Liked 2 Times in 1 Post
As an official, I am using Coach's Eye to provide photo finishes for Ttown's Masters & Rookies and previously for the Six Days of Kissena. It's surprising how often a rider comes to the officials with 100% confidence stating that he won particular sprint and that we have no clue how to judge a track race only to walk away very quickly and quietly when we say we have it on camera that he didn't.
I installed Coach's Eye on my Android phone for free and paid $14.99 to have the advertisements removed.
dunderhi is offline
Old 06-20-17, 07:00 AM
Poppit
Poppit's Avatar
Quoted: 109 Post(s)
I've been using this, the app is fairly cheap and easy to use. The angle measuring tool is good for knee/trunk etc measuring, get some sticky dots for the key points on your body and you're good to go. If you use Zipp Vuka bars Zipp also do an app which helps you set them up, I've not used it but it looks good.
Poppit is offline
Old 06-20-17, 08:51 AM
topflightpro
topflightpro's Avatar
Quoted: 1432 Post(s)
Liked 153 Times in 104 Posts
I am fairly new to track racing. I naturally set my track bike up to mimic my road fit, as that seemed like the most appropriate place to start. Now that I've got a little bit more experience under my belt, I am learning that is not the best position for track racing.
Does anyone have a more thorough explanation of how the fits are different? I have plenty of experience using mirrors and videos to adjust my fit on the road bike, but I'm not entirely sure how I should be fitting myself onto the track bike. I get that it's generally longer and lower, but I would be curious to know, on average, how much longer and lower people are?
topflightpro is offline
Old 06-20-17, 09:33 AM
carleton
Elitist
carleton's Avatar
Does anyone have a more thorough explanation of how the fits are different? I get that it's generally longer and lower, but I would be curious to know, on average, how much longer and lower people are?
How long is a piece of string?
This is why I suggested comparing yourself to photos of faster/elite racers to mimic their positions as a starting point.
As Taras says, it's a process. Your fit will change several times even in the same 4 month season as you become more flexible and have usable power when being more aero.
Flexibility is very important. It's not just for injury prevention. When your muscles are stretched (even slightly) this inhibits their ability to perform the micro-recoveries that happen between each pedal stroke. If the muscle were longer, then going to that same low point would still allow them to relax fully and revitalize itself for the next pedal stroke.
To test this, get on a trainer or do a normal road ride while using a heart rate monitor. Ride at a steady pace in a comfortable position and note your heart rate. It will be, let's say 120bpm. Now lower back and bend over until you feel a slight tension in your muscles, you'll see that your heart rate begin to rise alarmingly, up to say 140bpm while maintaining the same cadence.
NOW, if you go and introduce a proper stretching routine to your training plan and do the same exercise a couple of weeks later, you'll see that your heart rate won't rise when you go to that same low position.
That is a quantifiable benefit of stretching.
carleton is offline
Old 07-19-17, 12:10 AM
Flyright
Flyright's Avatar
Bikes: Salsa: El GO GO, Van Dessel: Drag Strip Courage
Hi all, newbie here. I have mostly been lurking, rather than posting to try and glean as much knowledge as possible.
With that being said, I recently got certified to ride my local track (BVV in Erie, CO). I had a blast, but, after the session -which was about 4hrs long- I was left super tense, and sore, especially in my neck from looking down the line. I setup my bike fairly aggressive (as pointed out by the instructor) which I tried to do, in comparing with some of the pros. I can't seem to post a pic because im so new. However, I am left wondering if it might be the aggressiveness of the setup, the size of the frame (i'm 5'8" riding a 50cm frame) the length of the cert session, or a combination of a few that left me so sore/ tens? I filmed myself riding on the trainer, and used the Kinovea app to analyze it; my leg angles were good, as was height over pedals etc... so any help would be greatly appreciated!
If this should be a new topic please let me know and I will repost. I figured as this was the DIY fitting topic -which is what I am doing since I can't afford the bike fit by the local track olympian- I would post here.
Flyright is offline
Old 07-19-17, 07:45 AM
carleton
Elitist
carleton's Avatar
Hi, and welcome to the forum and to the sport!
It's not gonna be comfortable at the beginning...especially if you are new to riding in general. It's hard to say if you are just sore from a long session in a new position or if the position is awful. My guess is that it's the former. Meaning that you'll get used to it. I haven't been on the track in 2 years and I'm dealing with odd sorenesses (neck, traps, shoulders, fingers), mostly from standing starts but some from riding.
The body likes homeostasis and complains when you change things.
Try to determine and distinguish between pain from injury and pain from adaptation.
Pics would help a lot. Maybe you can save them to an external host (imgur, wordpress, etc...) and then add an inline link (but that may not be allowed by new users, either. Not sure).
Stretching helps a lot. "Cold" stretching is bad. This is when your muscles aren't warmed up. It's best to stretch after exercise when you are warmed up or after a some active warmup.
carleton is offline
Old 01-08-18, 09:30 AM
pi03k
Hi guys/gals. First time poster. Thank you for all the knowledge that you share. I would like to kindly ask you for your opinion on my track fit.
I'm 6 feet tall (184 cm). Inseam of 85 cm. Possibly long arms.
My bike is Cinelli Mash Bolt (XL)
geometrygeeks.bike/bike/cinelli-mash-bolt-2-0-2017/
Reach 416
Stack 552
Top Tube (effective) 575
Top Tube (actual) 589
Seat Tube C-T 620
Seat Tube C-C 580
Head Angle 75
Seat Angle 74
Head Tube 163
Chainstay 388
Wheelbase 972
Front Centre 589
Standover 843
BB Drop 51
Fork Rake / Offset 35
Fork Length (A2C) 367
And here I ride 14 cm stem with 2-3 cm of spacers with 37 cm Scatto. Saddle has around 20 mm of offset. Cranks are 170 mm long.
youtu.be/6_kxZ6t-T4M?t=1m21s
What do you think?
pi03k is offline
Old 01-08-18, 12:50 PM
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 337 Post(s)
Liked 37 Times in 25 Posts
From a quick look, your fit looks good. You look pretty comfortable, well-stretched and aero. Comfortable neck position, nice bend in the elbow with room for more.
When you rev up a little bit, around 1.42, you bounce. And you're not even at high RPMs yet, but your hips are moving a lot - it's a red flag. There are some setup hacks that might help this, but there's no magic bullet: plenty of people can get souplesse at higher RPMs without equipment hacks, just from training.
Setup hacks that can work are lowering your saddle a little (and tweaking the rest of your fit to suit), and using shorter cranks to open your hip angle at the top of the stroke. And, infuriatingly enough, raising and sending your saddle forward might help too. It's trial and error. The best solution is training.
queerpunk is offline
Old 01-08-18, 04:08 PM
carleton
Elitist
carleton's Avatar
Hi, pi03k. Welcome to the forum.
The fit looks good.
I want to second what queerpunk says about you might be reaching a tad with your legs. Maybe lowering the saddle maybe 5mm increments and see what that does.
There are 3 basic leg extension types:
- Toe-Dippers
- Neutral
- Heel-Droppers
I'm a heel-dropper. You seem to be toe-dipping, which is how it seems that most elites ride. But, maybe you can come down a tad and see if that helps at higher RPMs because sometimes when your leg has to reach down too far, your hips will help you get that last few millimeters, causing the rocking. This can be really pronounced in recreational riders (not you).
carleton is offline
Old 01-08-18, 11:44 PM
carleton
Elitist
carleton's Avatar
Originally Posted by spartanKid View Post
One common "rule of thumb" is that in the drops on a road bike with your elbows bent in a race position, when viewed from the side, your elbows will "cover" your knees when your knees are the most forward in the pedal stroke:
Yeah, why is that? I've never been much of a road rider. And when I did ride on the road, my road bike was setup to mimic my track fit but with the bars about 2" higher for comfort.
Do the roadies like the position in the pic above so that they can set back further in the saddle and grind using their glutes when necesary (not being done in that pic, though)? Is it for easier climbing in or out of the saddle with the bike at an angle going up an incline?
carleton is offline
Old 01-09-18, 12:04 AM
carleton
Elitist
carleton's Avatar
I believe a lot of it has to do with finding a balance between a comfortable hoods position and a comfortable drops position with one stem and bars. If you push your road bars out 3-5 cm further, the hoods position would be really extreme/uncomfortable, and in modern road racing/cycling, 90%+ of the time is spent on the hoods.
Ah! The Hoods. That makes sense. Thanks!
carleton is offline
Old 01-09-18, 12:35 AM
jsk
Quoted: 160 Post(s)
Also it's because shorter reach with more elbow bend is better for aero than longer reach with straighter arms. In fact the most aero position on a road bike is not in the drops; it's on the hoods with elbows bent such that forearms and torso are parallel to the ground (or nearly so). This more modern fit style also allows riding a slightly smaller frame, which will be a little lighter/stiffer. If you look back a few decades, roadies were riding more stretched out and spent more time in the drops, this is a fairly recent development.
jsk is offline
Old 03-02-18, 06:03 AM
Morelock
Morelock's Avatar
Quoted: 236 Post(s)
Liked 16 Times in 13 Posts
bought a new saddle (Fizik Mistica) so now playing around with tuning the position again.
Gonna bring the saddle down 5mm or so from these pictures (knee angle is towards the high end) and do some hard efforts this weekend.
Gotta be within all the jig measurements (currently am with a few mm to play with in every check)
File Type: jpg
File Type: jpg
Morelock is offline
Old 03-02-18, 11:12 AM
jsk
Quoted: 160 Post(s)
Torso/head/hands all look good. Are those the Zipp Evo extensions?
I've also been trying to figure out the right position for a Mystica. Conventional wisdom (especially in places like SlowTwitch) is to put the saddle as far forward as you can, but even at 5cm setback I found myself constantly scootching back on the saddle. Currently have the saddle nose 7.5cm behind the bottom bracket which sounds extreme, but it feels good and has mostly solved the scootching problem.
jsk is offline
Old 03-02-18, 11:26 AM
Morelock
Morelock's Avatar
Quoted: 236 Post(s)
yes evo 110s
That's what I've found too. (although it's been only 2 days) I started 6cm back (about where the nose of my ARES sat) but have went back a full cm almost immediately because I felt very cramped. Even so, I'm still much farther forward than I was on the ARES. Still some adjustments likely to be made, but I suspect it'll go back a touch more before I'm done.
Morelock is offline
Old 03-15-18, 08:00 AM
Morelock
Morelock's Avatar
Quoted: 236 Post(s)
Moved to J bends, forearms weren't loving the end's of the Evo's extension. Need to get on the track and aerolab it.
You'd think after a couple of years, trips to the wind tunnel, and lots of field testing that you'd find a position you were happy with...
Morelock is offline
