Grease outside of chainring bolts?
Bikes: 2006 Novara Randonee, 2009 Fuji Cross Pro, 2013 Specialized Roubaix Pro, 2013 Allez Smartweld A5 Frankenbike, 2021 Diverge Comp Carbon
Liked 7 Times
So I recently hit the wall regarding wear on the drivetrain. Replacing the chain caused noise (chainring) and skipping (cassette). Most of the wear on the crankset is on the small ring, so I replaced only that one, along with the chain and cassette. So I don't have any spec regarding how hard to torque the chainring bolts, nor whether to grease them. I greased the male threads as usual, and torqued them to somewhere near 80 in/lb (off the scale on my low range Park torque wrench). Riding it finds the crankset really creaky.
Is increasing torque or greasing the outside of the sleeve where it meets the chain rings and spider the next step?
'06 Novara Randonee
'09 Fuji Cross Pro
'13 Specialized Roubaix Pro
'13 Specialized Allez Smartweld Frankenbike
'21 Diverge Comp Carbon
'06 Novara Randonee
'09 Fuji Cross Pro
Liked 7 Times
FSA Crankset on the Fuji 209 Cross bike if it matters
'06 Novara Randonee
'09 Fuji Cross Pro
'06 Novara Randonee
'09 Fuji Cross Pro
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Yes, grease. Uhhmmmm...95% wear? 95% of what?
Likes For cxwrench:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
Likes For veganbikes:
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Chain ring bolts get torqued to about 5 to 7 newton meters. Off the top of my head thats about 45 inch pounds. Any more & there's a good chance of breaking the chain ring bolt; Especially if it is an aluminum bolt.
I do chainring bolt threads at 5nm with blue Loctite 242. Grease is ok too, but may need a retorque at some point, in my experience.
Creakiness & whatnot indicates other issues.
FWIW: It doesn't hurt to label your units. You torqued to 80 what? Foot pounds? Inch pounds? Newton meters? Help us help you by properly & concisely conveying information in conventiontional terms. If you want to be taken seriously, proper prepositions, grammer, & sentance structure are a must. Hence the light & totally justified mockery above.
Quoted: 1438 Post(s)
Liked 1,092 Times
I grease only the male threads and keep the contact surfaces clean. And as base2 mentions, units are crucial. Confusion regarding units has resulted in the loss of an interplanetary spacecraft: https://en.wikipedia.org/wiki/Mars_C...cecraft_design
Liked 7 Times
Apologies for the messy post - I have cleaned it up. Thankfully I'm not allowed to have anything to do with interplanetary craft - just my creaky bike.
'06 Novara Randonee
'09 Fuji Cross Pro
'06 Novara Randonee
'09 Fuji Cross Pro
Quoted: 581 Post(s)
Liked 921 Times
As dsbrantjr says, grease the threads but keep all other surfaces clean. If you grease the outside of the chainring bolt/nut combo, it will turn in its hole on the chainring and this will keep it from tightening.
If you have the chainring bolts even moderately tight and you're still getting creaking, it's not the chainring bolts that are causing it.
Other possible causes:
Bottom bracket spindle interface with crank arms
Bottom bracket bearing/cup interface with frame
Saddle rails
Cable housings in housing stops
Saddle rails
Liked 7 Times
Thanks, I've recently had the BB serviced - I'll pull the rings back off and make sure all contact surfaces are clean and see if that helps.
'06 Novara Randonee
'09 Fuji Cross Pro
'06 Novara Randonee
'09 Fuji Cross Pro
Bikes: lots
Liked 2,932 Times
Saddle rails
Saddle rails
Likes For cxwrench:
Quoted: 4209 Post(s)
Liked 3,875 Times
Having just Wednesday drilled out a ring bolt that was frozen in place I fully recommend greasing the bolts, and nuts, and insides as well as outsides. Been doing this for decades and haven't suffered a frozen bolt or a self loosening one on both my personal bikes as well as the customers' ones.
But lubrication is much like bathing. That you do it periodically is more the deal then which soap you use. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 839 Post(s)
Liked 1,061 Times
I'm with posts 10 & 11. Grease the inner and outer of the chainring bolts/nuts. It isn't always necessary for all riders in the conditions they ride but it sure can't hurt to keep things from getting corroded and stuck. Buy or make a chainring nut tool to hold the slotted nut in place. You'll need one at some point.
Quoted: 581 Post(s)
Liked 921 Times
I have the tool, but since I learned to selectively grease certain parts of the bolts and leave other parts dry, I have not needed to use the tool on my own bikes. On others bikes I can never guess how things are assembled.
There was a thread about this exact thing a few weeks ago, including people wo dislike the chainring bolt spanner tool:
https://www.bikeforums.net/classic-v...ring-nuts.html
I am potato.
Liked 1,629 Times
Thanks for that. It would make sense that steel bolts would be higher.
It's so rare I come across steel chainring bolts for my own uses, I forgot the torque range for steel bolts. Though I do have some extra, extra, extra long (15mm) steel Raceface bolts I installed recently that specify 5nm on the bolt head. Interesting... That probably explains my faulty memory.
Car dependency is a tax.
Quoted: 645 Post(s)
Liked 797 Times
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Huh. Never even though about greasing the outsides.
Bikes: lots
Liked 2,932 Times
Advanced Slacker
Liked 2,537 Times
Liked 3,875 Times
Some modern cranks don't have nuts on the chain ring bolts, since they screw into the spider. Shimano bolts from the factory have a thread locking compound on them. I use anti-seize on those.
Advanced Slacker
Liked 2,537 Times
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Clark W. Griswold
Liked 3,994 Times
Mine also works just fine and have yet to have issues with it. Shimano TL-FC21 is my go to and it always has done the job. It also works great on my T.A.Extractor Bolts for my square taper cranks.
