Choosing my new carbon road bike
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Google harder. There are definitely sub 8.0kg bikes for $4000...with discs and Ultegra (mechanical). For less than $5k, a sub 8.0kg bike can be had with UDi2 and discs, from multiple manufacturers
Quoted: 767 Post(s)
Liked 1,740 Times
I just picked up some of these for my wife's bike. Really nice wheels.
Quoted: 164 Post(s)
Liked 44 Times
i wouldn't even bother with anything new , maybe madone 6 , or caad10 , buddy of mine blew the field away on a fixed gear spec transition , nothing disc , disc for road is stupid , tubeless road stupid , def stay away from specialized and trek new stuff , its just terrible , dentist bikes , maybe tcr , bmc looks good but who knows m its all china carbon with a fancy label , good luck
Quoted: 767 Post(s)
Liked 1,740 Times
I have the Pro 3V on my Domane which are 25mm internal and I run the 32s. No issues with acceleration.
Likes For jaxgtr:
Quoted: 528 Post(s)
Liked 230 Times
Again, not if they are 'aero' or 'endurance'. I made it clear that I was looking for these two. Also you said 7.5kg up at first. Definitely not many aero or endurance bikes with disc brakes at 7.5kg at $4k. If any at all.
Likes For RedllowFenix:
Quoted: 532 Post(s)
Liked 621 Times
For instance, the Canyon Aeroad CF SL 8 Disc (aero) in a size S, effectively a 54cm frame, for US$3999 weighs in at 7.78kg. The Focus Izalco Max 8.8 (aero) weighs in right at 8.0kg. Emonda SL6 Pro (aero) (which the OP mentioned, but is closer to $5k IIRC) is also 8.0kg. The Specialized SL6 Comp is the heaviest at 8.33kg, but also the least expensive at $3500.
I'm also certain that there are $4000 range road bikes on offer that exceed 8kg, I even provided an example. I did say that discs are being offered by all the (major) manufacturers, and if rim brakes are offered, they reside at the low end (and heaviest) models of the relevant product lines. If you desire a sub 8kg bike under $4000 with discs, it can be had...assuming there is available stock.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Agreed, autotrim, effortless shifting, and no cable replacement make it worth it to me.
Quoted: 528 Post(s)
Liked 230 Times
I never said 7.5kg, I said sub-8.0kg. I also didn't say all.
Quoted: 229 Post(s)
Liked 327 Times
My only guess why Trek went with 23mm is that it splits the difference between the old 21mm and the 25mm of their wider wheels and they can make one wheel for all tire sizes.
Quoted: 767 Post(s)
Liked 1,740 Times
I'm curious, too. I ordered a pair for my new bike arriving in June after the shop owner told me he could no longer order the XXX 4. You can see the wheels as an option in Project One and the default is the RSL 51 with the 23mm internal width paired with a 25mm tire.
Quoted: 532 Post(s)
Liked 621 Times
Decreased acceleration is a function of weight, especially at the rim. Carbon is pretty amazing, though, just because the rim is wider (or deeper) doesn't mean it is heavier.
Quoted: 532 Post(s)
Liked 621 Times
Thanks for clarifying, because it sure sounded like you were saying I said it. By Canyon's sizing it is roughly equivalent to a 54, or 53 depending on the frame. To answer your question, at 173cm tall with an 79cm inseam, I do.
Something to consider about categories aero, endurance, climbing....these are neat terms the industry used to use to separate their various road bikes that were basically the same, or better put, incrementally distinct. But that trend is going away. It started about 3 years ago, and really took off for the 2021 model year, which is what we are talking about, because there aren't many (if any) bikes to be had from the current or previous model years. All this obsessions about weight and aero is amusing to me when (a) the bikes are so light to begin with, taking 500g off the is an exorbitantly expensive proposition, but on a ride exceeding 2-3 hours, water loss will be twice that, and (b) I don't care how aero a frame is, the frontal surface of the human body is the real limiting factor for "aero." As for rim brakes on sub $4k and sub 8.0kg bikes, they might exist, but in most cases don't, because in 2021 sub $4k bikes tend to not be that light, no matter what brakes are in use.
I also didn't say "ah ok" because I'm not going to agree to something that is factually incorrect, or worse extrapolate a single occurrence as being a rule. I'm done, so you can have the last word...
Likes For Badger6:
Quoted: 528 Post(s)
Liked 230 Times
