Sub 20lb steel rides
#77
Quoted: 4234 Post(s)
Liked 2,949 Times
Can you ride that without the rear wheel rubbing the seat tube?
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
#82
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
Two years ago I sold my Terry O'sell to a good friend of mine. It was set up as a 2-speed using a SA kickback hub. The frame was a track frame (fillet brazed) and had no provision for a rear brake so the SA did that with a coaster brake, supplemented by a caliper on the front fork. Total weight was barely over 17 pounds. Trying to find a photo...
#83
Love the coaster brake.
My ice bike is an old Peugeot mtb, and it has studded tires and a shimano coaster brake.
(way over 20 lbs with the fenders, rack and gas pipe frame, but it handles and rides incredible on the ice/snow).
I have a 27 x 1/4 aluminum wheel set with conti gator hardshell tires from harris cyclery with a shimano coaster brake.
My next project is to find a lightweight Peugeot road frame and build it up as a summer commuter.
That should easily be my 20 lb or less bike.
I would like to find a PX-10 frame for this but I am afraid if I did this to a PX-10 I would be banned for life at CV...lol
Please post some pictures Salubrious, I would love to see it.......
#85
Now we enter the realm of the unreasonable. Would you consider replacing your pedals with expensive (and some say impractical) Aerolite pedals? That's a few ounces.
#86
Quoted: 1372 Post(s)
Liked 1,751 Times
I managed to get this old Windsor down to 17lb 7oz, using some clever and rarely unheard of bikelitetricks...
Both top tubes, the seat tube and down tube are filled with helium, as are the tires and and handlebar. The saddle sports alloy springs and hard to obtain lightbutted saddle cover over a rubber band mattress support.
The bottom bracket, head set, spokes, chain guard, and drive chain are all made of Dupont's Delrin plastic, replacing the heavier and more commonly used steel components, found on most 20lb+ vintage road bicycles. And yes, Delrin is the same stuff that brought fame to the Simplex transmissions of the day, one of the lightest transmissions offered at the time.
To this impressive combination of little know bikelite components chosen, add the crowning glory of lightness. That being the hot air offered by the owner, at the time these pictures were taken. That said, the pictures were taken the morning after a pretty significant Aurora borealis, which as everyone knows, offers considerable lightness to any situation it touches.
Sadly, nothing could be done, on the Windsor, to make the rear lite, light:-(
#87
Quoted: 7348 Post(s)
Liked 2,470 Times
People say light bikes don't achieve the goal, only a lean and strong rider does. But wait, what is the goal? If the goal is to have a light bike, then to achieve that, you'll need a light bike.
I like riding light bikes more than I like riding heavy bikes. I don't know why that is. I can make the claim that I like them without claiming that they make me faster.
#88
Decrepit Member
This is probably going to sound a little picky, but shouldn't we post the size of the frame along with the weight?
It's easier to build a steel framed bike that weighs less than 20 pounds if it's a 49cm frame instead of a 61cm frame.
This 61cm frame with a steel fork weighs 20.28 pounds as shown; it's ready to ride with pedals and one water bottle cage. The saddle is pretty heavy at 315g (0.7 lb).
#89
Wood
Bikes: Raleigh Sports: hers. Vianelli Professional & Bridgestone 300: mine
Quoted: 8 Post(s)
Liked 12 Times
That's not fair, its a single speed, and one brake is incorporated into the rear hub.
I've never heard of the helium trick, but I suppose that can make it a LOT lighter!
#92
Decrepit Member
#93
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
#95
Quoted: 1361 Post(s)
Liked 423 Times
Any of the above vintage steel at 20 lbs. is impressive enough. For grins on Sat. at a LBS, weighed a few bikes. Without trying or any concern for weight reduction, my '80 RRB 58cm w/ Champ. T-deuce tubed, lugged, all early 600 DT shifter group, 600 hubs, 32 hole Matrix rims, 600 pedals with steel toe clips, 600 brakes and levers with top feed cables, a leather RHM saddle (Brooks steel frame), Tufo tubular clinchers, Campy aero post, Cinelli quill stem, Cinelli bars, Stronglight crank and BB, steel fasteners, single bottle cage - came in at 22 lbs..
Now for the surprise. A brand new Felt AR5 carbon aero w/ full Shimano 105 and NO PEDALS weighed 18 lbs.
'14 Felt spec:
NO PEDALS
'14 Felt spec:
NO PEDALS
- Frame:Felt Aero Road UHC Performance Carbon Fiber w/BB30, carbon fiber dropouts, replaceable derailleur hanger, and internal cable routing (electronic compatible).
- Fork:Felt Aero Road UHC Performance Carbon Fiber Monocoque Construction, AeroTaper 1.125" - 1.25", and carbon fiber steerer tube w/ integrated crown race, crown, blades and dropouts
- Shifters: Shimano 105 5700 STI (10-speed)
- Front Derailleur: Shimano 105
- Rear Derailleur:Shimano 105
- Crankset:FSA Omega BB30, 50/34T
- Chain:Shimano 10-speed
- Bottom Bracket:FSA BB30
- Brakes:Shimano 105 dual pivot caliper
- Handlebar:Felt Aero Road
- Stem:Felt SuperLite
- Seatpost:Felt VariMount Aero Road flip position UHC carbon fiber, 350mm length
- Saddle:Prologo Zero T2.0
- Rims:Felt Aero R3
- Hubs:Front: Felt R2, sealed cartridge bearing, 24H, Rear: Felt R2, sealed cartridge bearing, 28H, 10-speed(11-speed compatible)
- Sizes: 48, 51, 54, 56, 58, 61cm
#96
Quoted: 359 Post(s)
Liked 265 Times
Here is the Terry O'sell track frame I mentioned, built into a 2-speed kickback embodiment with a front caliper brake. Sorry for the bad focus- its really hard to take a decent photo with an iphone in poor lighting! In the second photo you can see the nature of the quality fillet-brazing- this frame is a work of art. The bottom bracket is lugged but the rest is brazed. Total weight came in just over 17 pounds. There is no carbon anywhere on the bike. Wheels are Velocity with stainless triple-butted spokes- Campy front hub, Sturmey Archer 2-speed on the rear (w/coaster brake). Front brake is also a Campy. Brake leaver is Cane Creek. Mr. O'Sell told me that this is one of two frames of which are the lightest he has ever built.
#97
Decrepit Member
I believe it. What size frame was the one you weighed?
#98
Liked 423 Times
Stan- Either a 56 or 58. Definitely an interesting and reasonable price point bike with stealthy aero details yet appears lighter than it is. I handled the saddle just before installation and sort of felt heavier than expected. Just a guess but perhaps the rest of the weight handicap is in the 105 group.
I used to be a weight weenie back in the 1980's. Built a Colnago with a mix of components and hardware - no loyality to any brand or groupo. Come early 1991, a re-do with some trick built wheels, changed out to a Kestrel carbon fork, Sampson Stratics Ti BB, Ti hardware everywhere (including Dura-Ace ti parts), etc.. Wasn't easy but was sub- 20, maybe dangling 19. After that bike was stolen, I caved into ever doing again.
Although I appreciate it, now long out of my bike building mentality. The only thing I seek in an older race bike and to find speed is in the wheels and rubber.
#99
Liked 423 Times
If one wants to stay true to vintage and not into tubulars, some of these older clinchers are really lightweight. Add a 70 gm latex tube and you're in the tubular weight category. Of course not the same in ride quality but.....
#100
Quoted: 786 Post(s)
Liked 520 Times
