Clamp on versus braze on with adapter?
02-27-16, 08:43 PM
Quoted: 394 Post(s)
Was planning to buy a braze on FD with an adapter clamp. Any disadvantage as compared to a direct clamp on FD? It's a bit cheaper but more important I can later use the same FD on a braze on frame if need be. So, any reason not to do this?
This is for a Force 22.
02-27-16, 08:51 PM
Quoted: 276 Post(s)
I think the popular opinion is braze on because as you said you can use it if you swap to a frame with braze on. There is no disadvantage to using the adapter.
02-27-16, 08:52 PM
Quoted: 5 Post(s)
IME it works just fine and as you pointed out, if you decide to move your group to a frame with a braze on you can just remove the clamp and install.
02-27-16, 10:27 PM
Quoted: 394 Post(s)
02-27-16, 10:31 PM
Bikes: Davidson ’81
Quoted: 120 Post(s)
Another bonus of the adapter is that you can get them in the correct size for your seat tube, some band on FDs require using ugly plastic shims.
02-28-16, 06:12 AM
Quoted: 6556 Post(s)
Braze on with adapter is the smart choice. Another reason is that it is more easily height adjustable without moving the whole band and exposing some marking on the frame should you change chain rings size, etc.
Robert
Quote:
No matter where I go, here I am...
02-28-16, 06:17 AM
Interocitor Command
Bikes: 3 Road Bikes, 2 Hybrids
Quoted: 596 Post(s)
Quote:
Originally Posted by
seymour1910
Won't it require a special spacer if one does that? I bought a used braze on front with the clamp and had to buy one of these separately on ebay.
02-28-16, 07:19 AM
Quoted: 14 Post(s)
The fixing screw and special washer as pictured above are supplied with each new braze-on derailleur.
02-28-16, 07:49 AM
Interocitor Command
Quoted: 596 Post(s)
Looigi
Ahhh, I bought a used FD-6503 Ultegra triple on ebay and it didn't come with it.
02-28-16, 08:02 AM
On this topic. Anyone know the correct part for a braze on FD-9000 to adapt it to clamp on?
02-28-16, 08:17 AM
Quoted: 276 Post(s)
pcb09
There are a lot of adapters. You need to know the diameter of your seat tube where it will clamp on
02-28-16, 08:18 AM
02-28-16, 08:46 AM
The adapter does not have to be Shimano brand. Nice ones are available on ebay and Amazon as well as many other online stores. They come in aluminum and carbon fiber for not much money.
Robert
Hopslam
Bicycle Mechanics
4
12-20-13 12:19 PM
Tpcorr
Bicycle Mechanics
21
08-27-13 11:48 AM
bklyn74
Bicycle Mechanics
20
10-19-12 06:34 PM
deepakvrao
Road Cycling
8
02-20-11 10:33 AM
P4D
Classic & Vintage
4
02-04-10 07:46 PM
