New Sora group with concealed housing routing
Bikes: Surly Krampus, Salsa Vaya, Specialized AWOL
Quoted: 24 Post(s)
Still a 9-speed group, but now with concealed housing routing and wider hoods. Still comes with a triple crank as an option. I'm glad to see that there will still be a choice for a modern 9x3 system.
Shimano's New Sora and Metrea Groups | Bicycling
Quoted: 5888 Post(s)
Liked 3,471 Times
I like it. This could be a good option for touring with the 11-34 cassette and a different crank. I'm no fan of the 50/39/30 crank for touring.
George Krpan
Quoted: 12 Post(s)
Those Metrea integrated shifters are interesting. I reckon the brake lever swivels to shift and other lever is operated by the forefinger.
Quoted: 276 Post(s)
Liked 6 Times
Well current Sora is around $250. Looks like Sora also has the same style FD as other groups. So in theory if you're getting the same performance in a heavier package with 9 speed for $50 less than Tiagra. What they really need is similar Claris group with all the trickle down so people can upgrade vintage bikes with 126mm spacing without needing new wheelset or squeezing bigger hub in
I wonder what cable pull the front & rear derailleurs are using. Tiagra 4700 uses the same design as 5800/6800, and I wonder if the new Sora will as well or if it will share the older SIS cable pulls.
I really like the Metrea group though. Especially the 46/32 cracnk, which seems like an ideal option for urban riding. I may have to do a full conversion on my flat bar mountain/commuter bike...
Quoted: 276 Post(s)
Liked 6 Times
Shimano Metrea groupset is aimed at urban cycling market | road.cc
Quoted: 276 Post(s)
Liked 6 Times
Quoted: 24 Post(s)
I'm using the previous generation of Sora (3500) 9-speed STI shifters with a Deore M592 rear derailer. As far as I know, the cable pull on Shimano's 9-speed road shifters is the same as that on 8-10 speed mountain shifters. I'm sure that the new 9-speed Sora (3600?) will have the same pull ratio.
AFAIK 10-speed and 11-speed road shifters (Tiagra and above) are not compatible with any MTB rear derailers. This could be a reason for some people to stick with the new Sora over Tiagra.
George Krpan
Quoted: 12 Post(s)
This groupset is actually more interesting because it comes in 1x11 and it's only hydraulic disc brakes. The bullhorn shifters are cool too. Makes me want to build a dedicated commuter
The bullhorn shifters are barend shifters. I haven't seen a commuter using bullhorns but I gotta' hand it to Shimano for trying something new. They would be pretty vulnerable on the ends of bullhorns.
I would like to see brake levers/shifters with ergonomics specifically for "alt" bars like the Jones H-Bars. MTB levers/shifters work but the ergonomics could be improved.
Shimano road 10-speed (other than Tiagra 4700), shares the same cable pulls as 9-speed MTB components. Many people use 10-speed 105/Ultegra road shifters with 9-speed Deore rear derailluers, the same as you're doing. Shimano 10/11-speed mountain (Dyna-Sys) is utterly incompatible with all road hardware (other than cassettes).
When Shimano introduced 11-speed road, they changed the cable ratios. Then when they introduced Tiagra 4700, it uses the same rear derailleur design as 11-speed. This means that Tiagra 4700 is 10-speed group which is incompatible with all other Shimano 9/10 speed hardware. It wouldn't surprise me if the new Sora also uses the new design, making it incompatible with older 9/10 speed hardware.
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
Yeah, but I believe the main advantage of the 5 arm crankset was the standard bolt pattern (so you could use a commonly-available chain ring).
However, the last couple generation's Shimano cranks have been heavily sculpted (ugly, IMHO) and would look terrible with a non-matching chainring anyway.
So, I don't see the 4-arm bolt pattern as a specific disadvantage.
Like I said, I think all of Shimano's cranks are ugly so I wouldn't buy one at any level.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I admit it, I don't see how that Metrea bullhorn shifter works. I see the release trigger, where's the pull lever? It doesn't look like an STI.
To date, all of Shimano's 9-speed stuff has still been SIS, on both road and mountain side. If this RD goes to the new ratio then that will be a big change for the future.
Genesis 49:16-17
Genesis 49:16-17
Personally, I don't see the need. Even 126mm spaced aluminum frames easily accept 130mm hubs. And one can always do a 8 of 9 on a 7 speed freehub. Further, 130mm 8/9/10 freehub wheels can have some non-drive side spacer removed and a little more dish added to get closer to 126mm.
Disco Infiltrator
Liked 2,105 Times
Maybe. The reasons for the cable pull change become less pressing with fewer bigger shifts. 10-speed SIS had the smallest pull of any indexing system so far as I can figure. 9-speed SIS was long-running and well-loved and still-current across several other lower groups, unlike 10-speed SIS which was orphaned a while ago.
Genesis 49:16-17
Genesis 49:16-17
Bikes: '93 911 Turbo 3.6
Quoted: 109 Post(s)
Edit: after googling - this looks awesome. I'm sold already.
The new front derailleur is only compatible in a triple though. I guess this is obvious based on the fact that the double uses the design based on the latest 11 speed stuff.
