Wind Block Base Layers?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I'm looking for wind block base layers similar to the Under Armour Coldgear Thermo Wind Block long sleeve at the link below. It is no longer available.
Ideally it should have wind block all the way down the front of the arms as well as the front of the torso.
Suggestions warmly (pun) welcomed. Not looking for windproof/breathable garments or jackets and I already have plenty of gilets. Thanks.
-Tim-
-Tim-
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
I have absolutely no idea why one would want such a thing. If wind is getting all the way to your skin, something is seriously wrong with your layering. Your base layer should be very porous to get rid of heat and moisture, conducting those things away from your skin. Ideally a sort of waffle-looking synthetic material. Craft base layers are by far the most popular around here. I have both LS and SS base garments from them.
Results matter
Results matter
Quoted: 18407 Post(s)
Liked 15,496 Times
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
I honestly cannot say I know much about this win block base layer but I have found a shell or jacket (breathable) to be all I need over 2-3 layers max. I did try windproof-front bibs once (still have them) but after a while I found myself sweating and becoming clammy. If it is insanely cold and windy, I stay home though I ride fat bikes in the snow. I still layer properly and use a shell.
That said, look at motorcycle stuff...I recall they used to have windblock base layers, and it kinda makes sense there though I'd still use a windproof jacket. Maybe that would not be enough in certain cases but I'm no cold-weather moto expert.
Emondafied
Bikes: See sig
Quoted: 63 Post(s)
Someone must like it. It's sold out.
my bike page - my journal
Current Stable: Trek Emonda SL - Trek Top Fuel 8 - Scattante XRL - Jamis Dakar Expert - Trek 9700 -AlpineStars Al Mega
I have the short sleeve version of the Craft Wind Stopper baselayer: Baselayer - Men
The long sleeve version appears to not have blocking fabric all the way down the arms, though.
To the naysayers, I've done a lot of cold weather cycling and the baselayer mentioned above was one of my best purchases. My torso catches far more wind than any other body part and when my torso gets cold, everything else gets cold. I overheat easily wearing any 'breathable' windproof jackets which seem to never meet their promise. The Wind Stopper baselayer keeps my core warm and dry like nothing else can.
don't try this at home.
Quoted: 972 Post(s)
Liked 510 Times
I'm looking for wind block base layers similar to the Under Armour Coldgear Thermo Wind Block long sleeve at the link below. It is no longer available.Ideally it should have wind block all the way down the front of the arms as well as the front of the torso.
-Tim-
-Tim-
What other layers do you use with it? And what temperatures do you use these blocking base layers?
Like the other posters, I look for a wind resistant shell and very breathable base layers. But I do sometimes wear just a long sleeve jersey with two regular long sleeve base layers, which does reduce the wind that passes through, and still breathes very well.
And I've put a sheet of newspaper / wrapping paper under my jersey as a temporary wind vest. So that's a wind blocking base layer. It works great, but does get damp from sweat at times.
Quoted: 18883 Post(s)
Liked 10,646 Times
- Soli Deo Gloria -
Liked 736 Times
I have plenty of high-end wind block jackets and gilets - Assos, Arc'teryx, etc. Morvelo Hemisphere and Thermoactive are my favorites. There is no problem with my layering system.
I'm susceptible to bronchitis and like to keep the cool air off my chest. I also perspire a lot. Sometimes a gilet does the trick but wind block on the outside leaves the garments under clammy. Other times I'll just put a piece of Saran Wrap over my chest under the base layer. Saran wrap works perfectly for me but sometimes leaves my arm pits or arms chilly. Hence my query re wind block on the arms.
-Tim-
Expired Member
Quoted: 3657 Post(s)
Liked 5,396 Times
It's always fun to buy gear for a specific purpose, but I have to agree that a simple sheet of newspaper or a piece of Tyvek is just about ideal for an actual cycling windblock. Too much arm coverage can quickly become uncomfortably warm. As the day warms up, it's easy to snatch out the newspaper and stick it in your jersey pocket, don't even have to stop riding.
Liked 10,646 Times
If that's the case, moving the barrier closer to your skin seems like it will make the problem worse.
Some people use a wind shirt immediately next to their skin when they sleep (camp). You could try something like that for a ride, use your smallest and tightest wind blocking jacket as a base layer, then add insulation over it. See how it works before you invest in more gear.
Quoted: 34 Post(s)
Liked 17 Times
Have you tried merino wool? It's pricy, but (a) breathes, (b) stays warm even when damp or wet, (c) doesn't stink like synthetics [polypropylene, I'm looking at you] get stinky, (d) isn't scratchy like old-school wool.
Quoted: 4793 Post(s)
Liked 3,918 Times
I"ve been using those recyclable wind blocks under my outermost jersey for deacdes. Theo ones the pros use. Newpaper. And yes, the pros are still using them. Just not the team leaders. But the lowly domestiques on smaller teams who crest the passes minutes after the leaders and get zero camera coverage still can be seen stuffing newspapers under their jerseys before the descent.
Ben
Ben
Quoted: 324 Post(s)
Liked 251 Times
Another good way to be certain that your core stays warm is to protect your hands, feet and head properly from the cold. If those three things begin to get cold, guess where the heat is redistributed from? Yup, your core.
- Soli Deo Gloria -
Liked 736 Times
My hunch is that you get clammy because your outer layer isn't breathing enough, so your sweat has nowhere to go and you stew in it. (Not always, just when conditions aren't favorable to you, probably during more intense rides.)
When the wind block is strategically placed, just the forward facing portions of the torso and perhaps arms, there is plenty of remaining surface area for evaporation. I'm not considering wind block for the entire upper body. That would be suicide for me.
Merlin has the Craft Extreme 2.0 long sleeve for $57.14 vs $130 direct from Craft. Still looking for a something with a little protection around the arm pits and perhaps the forearm. The Under Armour linked in the first post would be perfect and I found one at the UK Amazon site but it is $122 after shipping. Yikes!I found one here for $67.19 but never heard of this site and they only have red.
-Tim-
Quoted: 77 Post(s)
Liked 19 Times
Rode this morning wearing my *disposable* wind stopping stuff . . .
A folded up couple sheets of folded newspaper between my bare chest and long sleeve jersey.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Today, I believe my jurisdiction ends here...
NYC
Quoted: 1169 Post(s)
Liked 107 Times
Stuff like this is why I find this forum less and less useful every single day.
Did the OP ask for alternatives to wind block base layers? No.
Did the OP ask whether a wind block base layer is effective? No.
Did the OP ask whether he should want a wind block base layer? No.
The OP asked very simply where he can find one similar to one that he likes, but sadly is no longer available.
It's not just the fact that people offer alternatives.... its the smug snarky tone they take in doing so. This happens again and again and again, and honestly I just grow wearing digging through this crap in every. single. thread.
BTW: Not picking on you personally... yours was just the first response on this particular thread.
NOW, NOT THAT ANYONE SHOULD HAVE TO JUSTIFY WHY THEY WANT A PARTICULAR THING, BUT I WILL TELL YOU WHY I PERSONALLY WANT WIND BLOCK BASE LAYERS: BECAUSE I WANT TO WEAR MY REGULAR / EVENT / TEAM JERSEY OVER IT AND NOT HAVE IT COVERED UP WITH WIND BLOCK LAYERS.
- Soli Deo Gloria -
Liked 736 Times
Right now I am wearing gilets and jackets with external wind block on the front. I sometimes need to pull down the zippers a little to regulate temperature and moisture but then the cold air hits my chest. I'm susceptible to bronchitis and need to keep the cold wind off my chest.
To be clear, I'm not looking for wind block around the whole torso. Just strategically placed on the chest. The front of the armpits and forearms would be a bonus. Such a garment would allow me to pull down the zipper on the outer layers without a blast of cold air on my chest. Saran Wrap, newspapers and garbage bags have all worked well in this regard so why not a base layer with wind block on the chest?
The Craft garment has the chest covered nicely.
NYC
Liked 107 Times
That said, I have been on this same mission this fall. I borrowed one at HGF so I wouldn't have to wear a jacket over my team jersey. 42 at the start, 60 ish by the end. Worked like an absolute charm. Yes, I was slightly overwarm by the end and a little sweaty, but not boiling hot or drenched, and overwarm works better for me than underwarm, and just arm warmers would have left my core cold with the 20mph winds that day.
So when I got home, I set out to buy one. Talk about a frustrating endeavor.
I found that bike shops don't have much in stock and I got tired of going from shop to shop. Surprisingly, sporting goods stores had nothing! The Nike store had nothing! The addidas store had nothing!
I found some Nike dri-fit, both crew and quarter zip, that were reasonable on weight and semi-windblock (which is all I really need) at JCP and Kohls. Bought one, but the smallest they make is a S, and it's a loose fit S, which looks sloppy and ill fitting under a tight jersey sleeve.
I found some Nike-Pro dri-fit at Marshalls... S is SMALL. Compression fit small. Perfect. But they're slightly less thick, and I only found one orange one. I intend to stop at more Marshalls this weekend (I have some other errands to run that will get me near 3-4 stores) because I want to pick up 2-3 more.
I think the Craft sounds about perfect, but with as much variability in design, weight, and FIT, as I've encountered in this search, I'm not willing to buy online sight unseen.
- Soli Deo Gloria -
Liked 736 Times
HUGE!!!
I'm probably going to buy the Craft Extreme 2.0 windstopper from Merlin for $57. I need some Vittoria G+ tires anyway.
-Tim-
Liked 1,938 Times
Results matter
Results matter
- Soli Deo Gloria -
Liked 736 Times
I really hesitated before posting my question. It worked out this time though and I really appreciate the conversation here.
-Tim-
