Madone SLR - Slipping Seatpost
Old 03-19-19, 04:26 PM
Cyclefiend
Bikes: 2019 Madone SLR 7 Disk, Felt Decree
Quoted: 18 Post(s)
Liked 3 Times in 2 Posts
Have any Madone SLR owners experienced their seatpost slipping? I’ve had my Trek Madone SLR 7 Disk for about a month and notice that the seatpost slipped 3 cm during that time. It happened so gradually that I didn’t notice it until I took it to my fitter complaining about knee pain. He raised the post back up, used the gritty seatpost lube/paste & torqued the binder clamp to spec, but on my ride home the seatpost had already dropped 2-3 mm.
I will contact Trek, but wanted to find out if anyone else has experienced this problem.
Cyclefiend is offline
Old 03-20-19, 08:28 AM
Noctilux.95
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times in 65 Posts
This happened to me on a ride yesterday! I have a 2019 Madone SLR and noticed creaking from the saddle/seatpost area while in the saddle. The noise would go away every time I would get out of the saddle. I took it to my dealer and he showed me how loose the seatpost was. I'm not sure about this, but a few days before I adjusted my Iso speed to make the bike stiffer. Maybe that could have had an affect on the seatpost too as the L shape iso speed is connected to the seatpost. Good to know I'm not the only one.
Noctilux.95 is offline
Old 03-20-19, 10:54 AM
maartendc
maartendc's Avatar
Bikes: BMC SLC01, Trek Checkpoint ALR5
Quoted: 542 Post(s)
Liked 32 Times in 26 Posts
If it is torqued to spec, should not be slipping. This is very strange. Especially if using carbon fiber grip paste.
I would contact Trek and ask for a fix or my money back. Those are expensive bikes.
maartendc is offline
Old 03-20-19, 12:34 PM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
I believe Trek instructs it’s mechanics to not use carbon paste in the original build. I had them build up a track frame with an aero seat post. On my first at the velodrome, seat slowly dropped. Took it back and asked if paste was used and they told me no.
colnago62 is offline
Old 03-20-19, 06:08 PM
Cyclefiend
Quoted: 18 Post(s)
I hadn’t touched the ISO-Speed adjustment. In fact my bike fitter re-torqued the bolts, but on the short ride home from his shop the post slipped a few mm. He had even added a dab more of the carbon paste before re-tightening the post : /
Old 03-20-19, 06:11 PM
Cyclefiend
Quoted: 18 Post(s)
Trek said to have my LBS tech inspect it. I’ve got an appt next Monday, 3/25/19. I’ll keep everyone informed as to what they find.
Old 03-20-19, 06:15 PM
Cyclefiend
Quoted: 18 Post(s)
My bike fitter (not the tech who assembled the bike) added a dab of carbon paste before he re-torqued the bolts. It still slipped. Trek says to have tech who originally assembled the bike to inspect it. Have an appointment for next Monday. Will keep forum informed.
Old 03-21-19, 07:18 PM
tntyz
tntyz's Avatar
Bikes: 2018 Domane SL7
Quoted: 36 Post(s)
Liked 41 Times in 24 Posts
I had the same problem with my Domane. Dealer gave me a torque wrench for the seat with advice never to use anything else. The wrench is rated at 5 nm; the seatpost seat clamp spec is 6-9nm. I tightened my seatpost up to 7 nm and no more slippage.
tntyz is offline
Old 03-25-19, 03:01 PM
Cyclefiend
Quoted: 18 Post(s)
Latest update 3/25/19: Bike is into the shop today, however I did remove the seatpost, cleaned off the post, the clamping wedge and the inside of the seat tube. I smeared the post with a thin coat of gritty carbon paste (TACX brand) and tightened the seat bolts to spec (5 Nm). Went on two long rides (total 90 mi) and the post did not move. So I’m guardedly optimistic.
Old 03-27-19, 03:57 PM
FlashBazbo
Chases Dogs for Sport
FlashBazbo's Avatar
Quoted: 983 Post(s)
Liked 141 Times in 94 Posts
This isn't a problem limited to Trek. It seems that all the bike companies who have gone to the "hidden" / integrated seatpost clamps are having the same issue. My first 2019 BMC SLR01 had the same problem -- curable only for brief periods of time -- until BMC eventually replaced the frameset. The replacement frameset hasn't had the same problem, but the post height is clearly marked and I check the torque at least once per month. (It's on my calendar.) The benefits of these clamps are purely aesthetic -- there's no meaningful aero benefit because of the location of the seatpost clamp. Sometimes, the manufacturers "innovate" purely to please the marketing department. And the buyers pay the price. Very frustrating.
FlashBazbo is offline
Old 03-27-19, 06:55 PM
TiHabanero
Quoted: 1745 Post(s)
Liked 1,370 Times in 719 Posts
"This isn't a problem limited to Trek. It seems that all the bike companies who have gone to the "hidden" / integrated seatpost clamps are having the same issue."
This is an age old problem with hidden post binders, wedges, etc. They have always done this as everything is conspiring against the "clamp" system. Gravity, weight, movement, etc. all want to drive the post down into the frame. If I recall correctly Profile had the Fly bike with a hidden binder and it did this. There have been steel and aluminum frames with wedges and hidden binders that did this. Nothing new in cycling, is there?
TiHabanero is offline
Old 04-01-19, 10:58 AM
Cyclefiend
Quoted: 18 Post(s)
After taking Madone into LBS they did the same clean & carbon paste as I did. In addition, I torqued the lower bolt to spec first, then the upper bolt. Idea is that this will cause the lower point of the clamping wedge to “bight” into the seat tube a little. Anyway, after 250 miles this week the seatpost is holding fine - no slippage!
Old 04-28-19, 01:05 PM
choddo
Quoted: 682 Post(s)
Liked 453 Times in 338 Posts
Took my Madone SLR out for its first proper long ride (60m) today. Exact same problem. It had dropped by 3-4cm by 15 miles in. The Trek assembly manual doesn't seem to have the recommended torque for these bolts, but I was doing it by hand anyway. After the problem showing up more than once, I tried to give it a little extra torque the third time (there's grip paste in there from the LBS) and I did each bolt at least twice - it seemed to hold for the rest of the ride. Not a huge body of evidence but I'm hoping that's done the trick.
choddo is offline
Old 04-28-19, 06:47 PM
Cyclefiend
Quoted: 18 Post(s)
Update: 5 Weeks & 1600 km On
No slippage since I cleaned and re-installed the seatpost. Reiterating that I torqued the lower bolt first then the top bolt using the 5.2 Nm torque key that came with the bike.
Old 04-29-19, 03:22 AM
choddo
Quoted: 682 Post(s)
Thanks, interesting.
Checked mine with a torque wrench last night and it was >8Nm. I didn’t want to push the wrench any higher. If it slips now I’ll get the shop to sort it rather than risk over-stressing it.
choddo is offline
Old 04-29-19, 05:05 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
There's always the pro solution seen at Paris-Roubaix, aka the taped up hose-clamp
Sy Reene is offline
Old 04-30-19, 08:10 AM
Noctilux.95
Quoted: 376 Post(s)
My seatpost keeps getting loose by rocking back and forth. The plastic cover hides two bolts that tighten the L Shaped ISO Speed and seatpost. I have to tighten it every few rides.The rail on the back is for adjusting saddle height. Efeeing pain in the ass!
Old 05-10-19, 04:26 AM
choddo
Quoted: 682 Post(s)
I had cleaned my seatpost wedge etc as @Cyclefiend suggested but I still lost 1cm in 30km. So I took it back again.
I think mine has been dropping (only had it 2 weeks) when the isospeed has moved a lot, it does seem to be the back/forth movement that prompts it to slip but that coincides with hitting vertical drops in the road so it's hard to be sure.
I don't think anything holding the seatpost is under that plastic cover in your first photo. I don't think there's any reason to go inside there unless you're replacing the isospeed mechanism.
The only thing holding the seatpost up is the friction between the wedge at the front of the post and the inside front of the tube, and the two edges at the back of the post against the inside of the back of the tube. And that is done by tightening the two 5mm hex bolts (ideally using a long torque wrench attachment) in the slot at the back of the post which your second yellow arrow points at.
BUT that pressure/friction maxes out once those bolts are in as far as they can go. You can put as much torque on that as you like (don't try) and it won't push the wedge any further forward because they physically run out of thread. The ends of the bolts just go into two threadless hollows on the back of the wedge to force it forwards.
Apparently Trek told my retailer to cut off two washers from those bolts which then allows them to push the wedge a little further (using the recommended 7Nm). This is obviously a slightly insane engineer's response to a design or manufacturing tolerance failure but they've done it anyway.
I'm going to test it today. (edit: I am reviewing this plan in light of the massive hail storm that just began)
... As an aside, I've spoken in person to 3 Madone 2019 owners - of a 6 disc, 7 disc, and 8. None of them have had this problem and two of them are heavier than me.
choddo is offline
Old 05-10-19, 05:34 AM
RShantz
Quoted: 278 Post(s)
Liked 29 Times in 19 Posts
Very good post. I've got a SLR disc (just built up from the frame) so have been following this. Mine slipped after my first ride, but after putting friction paste all has been good. I was going to ask about weight, but you covered that in your post.
Maybe this isn't relevant but thought I'd throw it out there. Have you compared saddle position to those of the other 3 owners you spoke of. Meaning the forward/back position relative to the post. I'd imagine that could change the amount of pressure at the contact point of frame/seatpost.
RShantz is offline
Old 05-10-19, 05:51 AM
choddo
Quoted: 682 Post(s)
Thanks.
I haven't, I did wonder about that - mine was approx 8cm offset* from the nose of the saddle to the crank vertical, but I've changed saddle to my trusty Selle Italia C2 so it's probably slightly different now. I've just emailed the other owners to check...
* I've got the normal seatpost, I think there are options on a custom Madone to have one that curves further back?
choddo is offline
Old 05-10-19, 02:19 PM
RShantz
Quoted: 278 Post(s)
Thanks.
Not sure about the curving back bit, but I know there's options for height of the seatpost.
RShantz is offline
Likes For RShantz:
Old 05-10-19, 04:06 PM
choddo
Quoted: 682 Post(s)
Well the surgery seems like it might have worked. Did the exact same 32km route that lost me 1cm the other night and it seems fine. Felt more solid too. Fingers crossed!
choddo is offline
Old 05-13-19, 10:52 AM
Shaunthesheep
Shaunthesheep
Trek slipping seat post
Just purchased Trek madone and guess what - seatpost slipped on first ride. Back to retailer who also informed by trek to cut the washers from the bolts. I pick it up tomorrow. Give me good news - you’ve had no problems since ???
Shaunthesheep is offline
Old 05-13-19, 04:04 PM
choddo
Quoted: 682 Post(s)
Good news indeed. Did a 50 miler Sunday and no problems. Measured my crank-saddle afterwards and still the right distance. Reasonably bumpy roads at times too. Seems solid. Make sure they don’t over-tighten it though I’m sure they know what they’re doing.
choddo is offline
Old 05-13-19, 05:58 PM
RShantz
Quoted: 278 Post(s)
No problems since & I've probably got something like 2k miles on it. Hit some rough bumps and potholes during one event & no movement.
RShantz is offline
