Nishiki threaded headset lock nut issues
I found this jem, 20$ nishiki competition. from the early 70s I am guessing. I am taking her down to the frame. I cannot remove the headset. I screwed off the top cap, then the brake cable holder, and below this is a lock ring with three slots. I do not have the tool. how do I get this off without that three pronged tool?
I have not seen a headset like this one. I want to remove it, and clean the chrome on the forks. any ideas? there is another notch on the other side. I want to remove this headset. i have tools to remove a typical threaded headset, but not this.
SE Wis
Quoted: 2740 Post(s)
Liked 3,388 Times
You need a "spanner" wrench. I've found a beer tap spanner to be about right.
https://www.amazon.com/Krome-843431-.../dp/B001CDQKVW
Or just use a bigger channel lock pliers, seeing as it's not some $$$ Campy headset.
Quoted: 1438 Post(s)
Liked 1,092 Times
You might be able to catch the notches with a properly-adjusted (or modified) Channellock-type pliers, but having the right tool is by far the best. If you are going to put it back together you will need a tool to tighten it back up.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I use the Hozan tool. Hammer and punch will work to remove but they're a little indelicate for fine adjusting on reassembly.
I will search online and try to find the right size tool. i have two spanner wrenches, but they do not fit this lock nut. I might try the screw driver and hammer approach. I am not going to reuse this headset. Thanks for the help.
Old fart
Quoted: 3582 Post(s)
Liked 3,395 Times
SE Wis
Liked 3,388 Times
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Or a hammer and nail set or punch.
Quoted: 980 Post(s)
Liked 580 Times
Dumb question: That fastener isn't part of the actual headset, is it? It seems that unless the OP isn't going to re-use the original fork, he'll need that piece to put the fork back on after headset replacement. So it might be a good idea to not destroy it.
SE Wis
Liked 3,388 Times
Channels locks etc are going to mar the finish, not destroy it. If for some reason they needed to use it it would still function. Especially if they used plenty of penetrant and some heat to remove it.
His existing headset is very similar to this.
Likes For dedhed:
Thanks for all the replies. I went with brute strength. I used a hammer and nail. came lose pretty easy and I did not even damage anything. Yes, the headset looks exactly like the one pictured. Now I have clean up the frame. Not sure how I will build it up. I am thinking a 1x5.'
success thanks for all the help.
