First wheel build...first problem?
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
Using Sheldon Brown's tutorial, I believe I 3-cross laced this front wheel correctly.
Then, I gradually ran the nipples in until the bottom of the nipple reached the bottom of the spoke threads.
Now, though, the trailing spokes on the left side (exiting inside the flange) are very tight, and the leading spokes (exiting outside the flange) are very, very loose.
Conversely, on the right side, the leading spokes (exiting outside the flange) are very tight, while the trailing spokes (exiting inside the flange) are very, very loose.
The wheel is pretty round, and true, but is off-center to the right about 1/4".
My guess is that I went wrong somewhere...so says Captain Obvious!
Quoted: 1105 Post(s)
Liked 1,326 Times
Double-check that you have them ALL in the correct holes. It only takes two swapped to really mess things up. This is easier to do/ harder to notice when all the spoke holes are on the centre-line of the rim.
Quoted: 209 Post(s)
Liked 175 Times
Front wheel, all spokes are the same, 299 mm.
I've started over, and switched to the jimlangley.net site for a different set of directions. Starting the opposite side in the exact correct spot is apparently a key step!
Likes For 67tony:
Quoted: 2362 Post(s)
Liked 1,745 Times
Post photos.
Quoted: 3803 Post(s)
Liked 6,639 Times
I'd loosen all of the spokes, and then work your way around the wheel to tighten them evenly. I usually try and get the nipples threaded most of the way down the threaded part of the spoke before I go at it with a spoke wrench (using my fingers or a screw driver for preliminary tightening).
Quoted: 1372 Post(s)
Liked 1,748 Times
Help us with some pictures. This is interesting.
Quoted: 3464 Post(s)
Liked 2,827 Times
need images, I bet there is an offset to the lacing.
Post an image and or CAREFULLY examine the wheel to another similar one.
Likes For repechage:
Quoted: 1946 Post(s)
Liked 2,004 Times
I can't imagine building a wheel for the first time without a nipple driver. It gets you real close to the best starting "tension" but at the start there is none. At this point though, I agree with above comments: back them all off. They could be a bit short so back them off so that each spoke has the same number of threads showing using only your fingers to turn the nipple. If some are still to tight, back them all of another couple of turns.
Quoted: 235 Post(s)
Liked 349 Times
This would be my guess too (fwiw). Not sure what Sheldon's method is but the way I do it,the hub is pre-filled before lacing so it's easier to notice anything off early in the process.
Likes For Bianchi84:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3867 Post(s)
Liked 6,452 Times
Quoted: 235 Post(s)
Liked 349 Times
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,376 Times
When I built my first wheel, I tried Sheldon's site and found it difficult to follow. Switched to Jim Langley same as you and got the job done.
Liked 2,827 Times
Just be happy you did not try the method shown in the first edition of Sloane’s book.
i looked at it, seemed odd.
learned at work, then returned to it - oh dear for the daring who tried. Reportedly fixed later editions.
Quoted: 789 Post(s)
Liked 1,739 Times
Yup, a bit at a time. I hook it all up, then start to snug up. I thread half way, all the way around, then go around again, tightening each nipple a bit more. Repeat this until spokes ate snug. Finger snug, if possible. If all looks good, then start to dish and true. Or...
I usually leave a couple threads showing for the first go round. That gives you more leeway to find out where you're at after the spokes are all in. Depends though. Without pictures we can't tell what your issue is.
A first wheel for everyone is going to be difficult.
Bikes: Indeed!
Quoted: 1506 Post(s)
Liked 3,461 Times
Likes For obrentharris:
Quoted: 209 Post(s)
Liked 175 Times
Thanks for the great replies.
I started all over, and built up a spoke at a time. But, again, half the spokes on each side are pretty tight, and half of them pretty loose (last two pics). Same as the first go-around, but not quite as bad. And, this is with all 32 nipples run in evenly, so that no threads currently show on the spokes.
I'm confident that the right side is done right, but the first spoke on the other side is where it gets a bit confusing. The jimlangley site describes a method for making the 17th spoke parallel to the 1st one, surrounding the valve hole, and I thought I was careful there.
señor miembro
Liked 6,452 Times
If I laced it correctly, threaded nipples just to where I can no longer see threads, and notice some spokes are loose, I just keep going. If I didn't lace it correctly, I always find the mistake before I'm done lacing.
Bikes: Hokitika Tandem; Cannondale, '87 ST400 & '88 ST1000; '84 Trek 460; Romic, etc.
Quoted: 7 Post(s)
I don't know enough to help you figure out what's wrong, but I'm pretty sure I had to tear down completely and start over at least
three times on my first wheel. I tried following Sheldon, then Jobst Brandt, then used Zinn''s book. Hopefully yours will go faster, hang in there. I'm sure the experts will be along to help.
Likes For alfonsejr:
Quoted: 702 Post(s)
Liked 671 Times
I read The Bicycle Wheel by Jobst Brandt prior to my first wheel build years ago and I had no problems at all, it is very clear and well written. I still ride those wheels, among others I've built using his book.
In your previous thread, you mentioned using a "fork" as a trueing stand, is that what you are using or did you get a proper trueing stand? Do you have a dishing tool? Spoke tensioner? Spoke wrench?
I don't see anything obviously wrong with your lacing pattern, but I can only see the flange on one side. It looks OK I think, but it isn't possible to definitely know that the two sides are aligned correctly.
It looks to me like your spokes are too long. Spokes often seem all wacky and uneven until you start to tension. By the time the nipples are snugged enough to cover all the threads, they should be getting pretty even, and the wheel should start feeling like a wheel.
IF you have carefully tightened all those spokes just enough to cover the threads, I think it's worth a shot to start to bring it up to tension. Maybe you'll get lucky. Go around, put one turn on each spoke, see how that is. Repeat. If the spoke are starting to stick out the back of the nipples and the wheel is too loose, there's no hope. You'll need to get shorter spokes. Take the wheel apart and start over.
Also, double check your spoke lengths. Are you certain they are all the same length?
Triple check your lacing and the left right alignment before you do any of this.
Likes For Salamandrine:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,865 Times
I think you've got your inside spokes in the wrong rim holes. Probably you didn't rotate the hub enough after placing the key spoke. Jobst Brandt's method has you lace all the inside spokes before rotating the hub, which I think makes this easier to judge.
The spokes you see here, one inside and one outside, should insect at equal lengths and they don't.
My Bikes
My Bikes
Likes For Andy_K:
Liked 1,745 Times
^^^^^ This. Even more noticeable at the outermost cross. Look at any third (outer) cross, follow the outer and inner spokes from that cross to the hub. The distance for the outside spoke is more than for the inside spoke.
Likes For madpogue:
Liked 1,326 Times
p.s. which edition of The Book do you have - first one has a mathematical typo...only Allah is perfect.
