Bikepacking/Touring, Alum. or steel?, Can I get a decent bike for under 1000?
TBrown0203
New to cycling, planning a 200 mile touring trip in a few months and I need a new bike. (Currently have a 1973 Schwinn for putting around) I went to my LBS for guidance and they are set on me getting something (that I like also) but is a little more than I wanted to pay (there is wiggle room there). I decided I want something that I can load up for bike packing but also take down dirt trails, gravel roads and can also handle big potholes in the city. Is it possible to find a bike under $1000... Also, what is the reason I should go with steel instead on aluminum? Oh yeah and I am 4'11- to make things a little more difficult. I will choose Terrain over gear but I still want a back rack . Everything that was being suggested was $1500 and up.. I feel like there are somethings being left out .
UPDATE: I FINALLY FOUND A BIKE!! It's A 2018 Salsa Vaya . I am switching the 700c tires out for 650b... Maybe 26" ( not 100% sure if I could do 26" ) it's for toe clearance... I'm pretty happy with it...
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
Hmmmmm...
"I feel like there's something being left out."
200miles. Loaded touring. Maybe not all paved.
(guessing the terrain you plan is Not mountainous)
Since you have experience with vintage, why not a vintage tourer with clearance for 38mm tires?
New bikes offer disc brakes which are important in the mountains.
New bikes offer a lighter frame + fork which isn't important in a tourer.
Everything else is pretty much a wash.
Unless you just want new.
Trek, Centurion, Miyata, Cannondale (many others) offered full-on touring bikes. $1000 buys a great used touring bike possibly including the racks/bags you may need.
Likes For Wildwood:
Quoted: 604 Post(s)
Liked 1,063 Times
You can get an awesome bike for under 1K, just won’t be new.
Tim
Tim
Likes For tkamd73:
Quoted: 1034 Post(s)
Liked 1,290 Times
The bike shop was being honest with you. $1500 is pretty much the least expensive you can get through a bike shop, and even online when it comes to touring bikes. Bikes Direct though does offer bikes cheaper, but you will have to do some assembly yourself, or take it to someone to get it done. Their prices a good though, so you could probably pay a local bike shop to do the work and still save money.
Try the Windsor Tourist. https://www.bikesdirect.com/products/...ke-tourist.htm
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Salsa Journeyman would be more than capable - great versatile bike for the money! Flat & drop bar options, 650B or 700C wheelsets, Claris drivetrain with subcompact crankset starting under $1,000. Lots of mounts for hauling gear and bikepacking - i have loaded up my rear rack pretty heavily and it handles great with a load.
Likes For SalsaShark:
TBrown0203
I am kind of leaning towards a Surly Bridge Club. Price point is still within reason.
Likes For tmbrown0203:
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
If you have no problem with 700c bicycles, the best deal going up until 2020 was the Fuji Touring with Disc. That was discontinued after 2019 but, may be coming back (you might even find that still available in some stores, left over from last year). Right now, the best 700c bicycle for the price is the REI Co-op Adv 1.1, for $1300. But make sure that it comes with mechanical disc brakes, rather than the hydraulics that it's spec-ed with. When I saw this bicycle in the store, it actually had TRP Spyer-C brakes, which are very good. Another is the Masi Giramondo.
If you can go with V-brakes instead of disc, there is the Fuji Touring for under $1000 and probably other bicycles like it.
In the 26" wheel category, the Surly Trucker series is over $1000 but they are popular. A lot of people say that riders on the shorter end of the scale should consider 26" wheels.
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
This is what I did with an old mtb.
(Bags have been swapped and low rider tilt since corrected)
Buy quality used steel and spend money on gear
4'11? with big wheel bike designs have a bunch of compromises, front wheel toe touching overlap one of them ..
I have a Bike Friday, 20" wheels solve that , they have frames of different lengths .. so shorter or longer reach ..
A USA made Bike, keep your eyes out for a used one,*, people already ride those around the globe..
Company has pre loved refurbished ones .. (they don't sell thru dealers)
and the google Bi Fri [Yak] group has private sales posted...
Likes For fietsbob:
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,646 Times
Welcome to the forum fellow New Orleanian! You can get a fantastic bike for $1000. The local dealers don't have much inventory though, so you may have to order online. If you decide to order online, I will be glad to help you set the bike up at no charge if you need any help. I have helped quite a few people set theirs up.
Are you going to be touring in an area with hills or steep climbs? That should probably be a major consideration. Most modern touring bikes aren't geared well for loaded climbs.
Something like this might serve you well, and it's right at the 1K mark. It has acceptable gearing and rack eyelets. It is available in extra small.
https://www.adrenalinebikes.com/stor...oductid=205207
Likes For Paul Barnard:
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
Used 26' rigid mtb from the late 80s or early 90s.
Many have quality tubing, wide gear range, mounts for racks, and geometey that will work for your height.
Itll cost $150-300.
Take it to a shop, have them tear it down and clean it, then build it up with a mix of original and new components(where wanted or needed).
The shop work will cost $300-600, depending on what you have replaced.
$450-900 and you will have a fully capable bike for what you mention wanting to do.
Itll cost $150-300.
Likes For mstateglfr:
+1 for 90s rigid MTB as your base. Sturdy as they come and with your smaller stature, you'd probably benefit from the 26" wheel platform anyway.
Quoted: 178 Post(s)
Liked 355 Times
Universal has the 50cm Salsa Journeyman 650b Dark Olive finish dropbar in stock for $849 - just sayin'
Bikes: Soma San Marcos
Quoted: 7 Post(s)
700c wheels that use 2" or wider tires exist, they are rather frustratingly referred to as "29'ers" because marketing. In fact both 700c and 29'er wheels are actually 622mm in diameter, with 28/32mm wide road bike tires in that rim size roughly figuring out to 700mm in overall diameter. The bigger, fatter 29'er tires usually bump that up to a nominal 29" or ~736mm overall tire diameter.
Equally frustrating is that 650B wheels are basically the same as 27.5 MTB wheels, both share a rim diameter of 584mm. 650B is to 27.5, as 700C is to 29'er.
Clear as mud!
Likes For General Geoff:
Quoted: 18413 Post(s)
Liked 15,536 Times
I hope everyone is recommending models that can fit someone who is 4’11’.
Expired Member
Quoted: 3672 Post(s)
Liked 5,427 Times
Yep. I was going to throw out the Giant ToughRoad until I checked the sizing.
Quoted: 2604 Post(s)
Liked 1,932 Times
Used 90s mountain bikes would give a lot of room in the budget, but it depends on what OP is looking for. It'll be a project in itself finding the right bike (of course, that's going to be true of a new bike as well, if you're looking for one of a few specific touring models, which aren't often stocked, in this age of the epidemic). Getting it set up right, rebuilt with bearing repacks and new drivetrain and brake pads, and outfitted with racks, will be another project. You want to skip the extra work, plunk down your money and ride off with that new bike smell and a warranty -- you'll be buying new.
Liked 15,536 Times
For a frame of reference, I bought my ex a 42cm LHT. She's 5' even.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Don’t let a shop put you on a bike that is too big. If they try to get you on a 49cm bike, they are putting you on a bike that is far to large for your size. You should be riding a road bike around 42 cm± 2 cm. Anything over 44 cm is too large. Unfortunately you are likely not going to find anything under 44 cm.
If you can, avoid anything with 700C wheels. A bike with 26” wheels will fit your much better because of the smaller wheel size. It will give you more standover space and the angles on the head tube won’t be as relaxed. Unfortunately finding bikes with 26” wheels is difficult now.
Don’t let someone put you on a mountain bike that is the same size as the 44cm road frame, i.e. a 17” bike. A 17” mountain bike is designed from someone around 10” taller than you are. A 15” mountain bike is too tall (for someone 5’4”). You need a 12 to 14” mountain bike. Mountain bike riders use mountain bikes that are around 4” shorter than their road sized frame and the proportions are made for those taller riders. You’d have to stretch too far on a 17” mountain bike...kind of like your Schwinn.
As to materials, go with aluminum over steel. It’d be nice if you could get carbon but that’s not something that is offered for touring bikes. The geometry on a carbon road bike would be too tight for comfortable riding with a touring load.
I’m sorry but I’m going to have to suggest you look at “youth” bikes. I know how demeaning that is but it is a solution to your problem. Frog Bikes has a number of different bicycle configurations that are worth a look (on paper at least). They seem to be out of mountain bikes (if you are doing real bikepacking) and hybrids but they seem to have road bikes. $700 is a pretty good price as well.
You might also consider Bikes Direct. They have some bikes for smaller riders. They aren’t as good a quality as the Frog Bikes seem to be but it’s an option. Do a Google search for “youth bikes” and you’ll get several results.
Finally, look on Craiglist or EBay for “Terry bicycles”. You’ll find a lot of saddles...their main business...but Terry also make makes for women and small women in particular. This is an example of one of the old Terrys. Look for Terry Symmetry in your search. The Symmetry has a 700C rear wheel and a 24” front wheel. It’s a compromise but it does solve frame problems for small people. Look for Specialized Vita while you are at it. Those work for smaller riders but the Terry is a better design.
Stuart Black
Stuart Black
Quoted: 1218 Post(s)
Liked 298 Times
90's rigid MTB with 26" touring tires! Equip it with a swept back bar like a jones bar or convert to a drop bar. A flat bar with bar ends might suffice, but......
Liked 4,218 Times
If you want to share the experience...assuming about 6’ tall...go ride a 22” mountain bike and see how it fits.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 298 Times
I have to disagree. They didn’t make mountain bikes in the 90s with frames shorter than 15” which are far too large. Small size mountain bike frames didn’t start to show up until the very late 90s/early 2000s.
because late 90's isn't the 90's .... who F'n knew?!?!!?!?!?!?!?!!
1996 Trek 850 Bicycle Type Mountain bike, non-suspension Weight 27.6 Sizes 14.5", 16.5", 18", 19.5", 21", 22.5" Colors Red, silver/blue Item ID 57250
It's bad enough you people are trying to rewrite history, and definitions, but what you do not get to do is claim 1996 isn't the 90's!!! LOL
