Freehub overhaul vs. flush and lube
I have a Deore LX hub that's about 20 years old and the freehub is sticky. I'm comfortable removing the freehub and making a spline tool to disassemble it if it comes to that, but I wanted to ask for opinions on doing a full overhaul versus flushing it with solvent and lubricating with a heavy oil. I'd rather do less work, but how long would tenacious oil effectively lubricate the bearings? Won't solvent remain in the freehub and make it even less effective? If I overhaul, how likely is it that park grease won't eventually run and impede the pawls? Anyone have thoughts or experience?
Recreational Road Cyclist
Quoted: 256 Post(s)
Liked 252 Times
BTW, what do you mean that the freehubs is "sticky"?
Less work, more riding.
Quoted: 836 Post(s)
Liked 1,060 Times
I'm a do-less-work guy too. Whenever I am repacking the hub bearings, I remove the freehub body and lube it. For me, this means peeling back the rubber seal and dripping a little 30w oil into it. I spin it to distribute the oil and listen. When it begins to sound wet, I'm done.
Likes For Crankycrank:
I got it from a friend, don't know how many miles on it but the rim it's laced to is very worn. It ratchets but there's a lot of resistance when turning the freehub by hand, my best guess is the grease in the freehub has turned to gunk.
Ditto. You can also soak the freehub in Odorless Mineral Spirits after removing the rubber seal. Spin the hub around every few hours to loosen up the gunk. If you have access to an air compressor you can blow out the residual OMS to dry or just let it sit for a couple of days to dry. I've found that Shimano hubs like a lube roughly in the 90 weight viscosity such as Phil's Tenacious, Chain L chain lube, 90wt gear oil, etc. Anything heavier such as grease tends to slow the teeth from engaging and lighter tends to seep through the seals. I've done the complete disassembly/clean/re-assemble deal and is a PITA trying to count and put all the little ball bearings in place and not much better than the flush and lube method.
I'd make the options a) remove flush and relube , or b) just replace ..
given, as you say, : "It's about 20 years old" ...
Freehub drivers separate from the hubshell (except for low/least cost bike's parts) ...
might be time to get a new replacement wheel, general bike shop repair wheel ..
Blamester
[QUOTE=BCDrums;20909114]I'm a do-less-work guy too. Whenever I am repacking the hub bearings, I remove the freehub body and lube it. For me, this means peeling back the rubber seal and dripping a little 30w oil into it. I spin it to distribute the oil and listen. When it begins to sound wet, I'm done.
This to begin and see how you get on. Most likely all you need to do.
Quoted: 4197 Post(s)
Liked 3,849 Times
I'll add that on the various freewheels and FH bodies I have greased I've never had an issue with pawl hang up. But I only applied grease to the ball pathways and coated all else with Phil oil or equivalent. Same as I do with SA AW hubs Andy.
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Years ago I bought the shimano freehub tool so I could add a heavier spring for the pawls. The reason for the heavier spring is that I have a Freehub Daddy and use it to pump grease through the freehub body every 5k miles. I never have freehub problems.
If I were going to service mine today I would flush and oil because the 'Daddy' is no longer available.
Liked 3,849 Times
Morningstar and JA Stein both offered (still do?) grease injection tools for freewheels and FH Bodies. I've used both many times and sometimes they work less messily the other times. Always with Phil grease which is thinner then some and less prone to pawl stick. Not heard of the "Daddy" tool name though. Andy
AndrewRStewart
AndrewRStewart
Quoted: 569 Post(s)
Liked 580 Times
[QUOTE=Andrew R Stewart;20909561]Morningstar and JA Stein both offered (still do?).../QUOTE]
Andy, I don't think I have seen anything in a several years as my family could use a couple.
[QUOTE=easyupbug;20910287]
https://www.steintool.com/portfolio-...eehub-flusher/
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
After the solvent, I like to spray brake cleaner inside. It drives out the solvent and naturally evaporates quickly. Then the air.
