Useless and Worthless Tools
#76
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
I must be the only person that builds wheels with the Park SW-7 triangle spoke wrench. I have two "dedicated" spoke wrenches that work much better on really tight spokes (final tensioning). But for me the SW-7 is easier to add a full turn or two to every spoke.
Worthless tools? The Park chainring bolt holder. I bent mine up pretty bad the first time I ever tried using it on a tough chainring bolt that would turn but wouldn't loosen. Any tool that isn't as strong as my hand is pretty lousy.
I need a pair of these for my 600 headset! I used normal wrenches very carefully with a rag underneath, but would like to have the correct tool.
Count me as another. Darn 600 headset gets hand tightened since I cant get the star nut tight enough.
#78
Quoted: 2026 Post(s)
Liked 1,096 Times
#80
Quoted: 1182 Post(s)
Liked 833 Times
Park USED to have a good warranty. However I'll no longer buy a Park tool unless it's the ONLY tool made for the job. The Park warranty sucks and they refused to replace two tools i have that broke in use.
A warranty is only as good as the company's willingness to stand behind it. My experience is that Park does everything it can to get out of a warranty replacement of a tool. Other's may have had better luck but I've blacklisted Park tools as far as any of my future purchases go.
Cheers
Cheers
#84
Bikes: 89 Schwinn 754, 90 Trek 1100, 93 Trek 2300, 94 Trek 1400 (under construction), 94 Trek 930, 97 Trek 1400
Quoted: 29 Post(s)
No, when you return a tool to a Performance Store, you get your choice of Tool Exchange, or Store Credit, or Cash Back (I don't know if a receipt is required for Cash Back, for Exchange or Store Credit the receipt is not required).
Tools wear out with use, no matter how high the initial quality is/was. It's nice to know that I won't have to pay for a replacement wrench (unless I lose it). I have some U.S. Made Craftsman hand tools that date to almost 45 years ago when I bought them new from Sears Stores. Over the years, some wrench and socket sizes have been worn-out, broken, or sprung several times, while others are still like new. It's all about how much you them them, and how hard.
Bicycle cone wrenches are much thinner (and weaker) than mechanics wrenches. I expect the life of a cone wrench to be shorter than a regular mechanic's wrench. I wore-out, broke, or sprung several inexpensive cone wrenches (replacing the entire set when it happened) before I bought my first set of Park Tool cone wrenches, and haven't worn-out, broken, or sprung one since.
#85
#86
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
I have a matching headset, but no tools.
#88
Superlight aluminum chain breakers .
I gave a friend a decent steel chain tool to take on a tour of southern Argentina, He found an aluminum one and went weight weenie .
When he needed a chain break repaired the tool broke, immediately, and so had to figure out the spanish phrase to get a Nail
and used a Nail An a Rock to try to get the bike fixed again..
#91
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
#92
Bikes: CUBE Acid 29er, Salsa El Mariachi SSGT Avalanche X 2009, MMVZ Minsk 1980, Trek 4300 custom, HVZ Ukraina 111-411, Cannondale Trail 5
Quoted: 22 Post(s)
I make about half tools in my workshop himself hands. For example- whip to the hold cassette, BB and Cassete tool upgraded simply weld left crank.
I make that because nice tools very expensive in my country. A buy cheap tool that's about drop money in trash.
#93
Not a fan? YRMV. I drive in Boston, MA on a daily basis. Try potholes, crazy drivers and contact parking. Been rear ended 4 times. The good car is not my regular commuter. 165,000 miles, works well. Allows for " other things" in my budget. Oh, and just recently got 2 daughters up to speed on driving. Start there. And I dislike making interest payments on a depreciating assets.
#94
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Just teasing; Corolla is the original "Smart" car...
Today, I believe my jurisdiction ends here...
#95
I had the opportunity to use a Park crown race puller, CRP-2, last night. Talk about overkill. The tool weighs more than an average frame. It takes at least three hands to hold it, the fork, and to position it on the fork to pull the crown race off. Then it has a big honking handle to turn to pull the race off. All it needs if a flick of the wrist, and knob would do fine. By the time you get it on the fork, and pull the race, you could just pop it off with a razor blade, or a thin screw driver. And it's pretty expensive too.
#96
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,427 Times
BB-cradle-style bike stands like this are the worst. Even at $35 delivered it's overpriced.
It takes an annoying amount of time to bolt the bike into the BB-cradle, and the clamp on the downtube arm is not big enough for your average modern MTB.
For just a few more dollars, one can get a clamp-type stand; although the build quality will be similarly low, at least it will be much more usable until it breaks. If you use it gently and/or rarely, it may well last a lifetime.
#97
#98
Bikes: 2010 Trek 7100
Quoted: 697 Post(s)
Frankly, I'm about ready to commission a set of nipples made from AUS8. The weight can't hurt as much as the drag from not being able to turn the ones I need to to finish truing because they're rounded off by crappy "spoke wrenches."
#99
Liked 1,096 Times
#100
a77impala
I have a set of Performance cone wrenches that useless, they are soft metal, why would a wrench not be hardened steel?
