Go Back  Bike Forums > Bike Forums > Framebuilders
First Frame Build Questions
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Old 07-31-19, 01:38 PM
imakecircles
imakecircles's Avatar
Bikes: 1982 Bianchi Nuovo Racing, 2012 Cervelo RS Rival, 20xx Redline Conquest (Commuter/Rain Bike)
Quoted: 17 Post(s)
Liked 8 Times in 7 Posts
I've always wanted to build myself a custom lugged steel bike frame. The idea is to build a classic steel road frame with lively 74 degree angles like the steel racers I rode as a kid.
I found a Columbus SL Tubeset and matching lugs from Nova, and once received, cut each tube to length (size 58.5 c-c) using a tube angle jig that worked with a 1/2" drill motor and a hole saw arbor that a buddy loaned me.
I built a frame jig primarily from 80/20 extrusion, with some machined and threaded cones to center the bottom bracket, head tube, and seat tube, as well as an extension using an old rear axle for centering and aligning the rear dropouts.
I'm getting close to being ready to assemble the frame with flux in the joints and clamp it into the jig to begin brazing, but I have a question about the joints at the seattube to toptube, toptube to headtube, and headtube to downtube. I have read that since the toptube is captured at both ends, failing to drill a hole in at least one of the tubes (head and seat) behind the lug will cause air to be trapped which will heat and try to expand without the hole to let the hot air escape.
My question (finally!) is would it be ok to drill out each of the three joints to lighten the frame, which I'd like to do as this is a dream build for me, or would this affect the structural integrity or stiffness of the build?
imakecircles is offline
Old 07-31-19, 01:49 PM
dsaul
Quoted: 312 Post(s)
Liked 79 Times in 61 Posts
Vent holes.
File Type: jpg
dsaul is offline
Old 07-31-19, 05:33 PM
Nessism
Nessism's Avatar
Bikes: Homebuilt steel
Quoted: 165 Post(s)
Liked 27 Times in 23 Posts
I like to drill large vent holes partly because it allows water to flow inside to wash the flux. It's also nice to drain out excessive rust preventive spray applied after completion.
Nessism is offline
Old 07-31-19, 05:48 PM
TiHabanero
Quoted: 875 Post(s)
Liked 140 Times in 93 Posts
This spring I brazed up the main tubes for a touring frame and decided not to vent the top tube joints. Not a problem. Did not experience any blow outs from heat. Of course I am unable to get in the top tube to flush it, but that will be another chapter in this story at some other time.
In a previous frame I used 3/4 hole at the head tube to vent with. The seat stays were not vented either. Does not seem to affect anything from were I sit. Long term corrosion may be an issue, but I doubt it.
TiHabanero is offline
Old 07-31-19, 06:16 PM
unterhausen
Randomhead
Liked 96 Times in 82 Posts
I have heard people say they had breakage on frames with vent holes bigger than 3/8", but there are plenty of counterexamples. I have always drilled 1/4" vent holes, but went larger on this most recent frame.
I think you should go with 3/8" and not worry about a little weight. It's negligible. Hopefully your dreams will get bigger after this frame.
unterhausen is offline
Old 07-31-19, 07:29 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1948 Post(s)
Liked 135 Times in 101 Posts
I've made vent hole from tiny 1/8" ones to hugs 1/2". Can't say the diameter made any difference in how the frame turned out. It is nice to be able to drain/shake stuff out so I currently drill about 1/4" holes.
I learned to vent every tube, to not get cute with vent locations and follow my painter's preferences as to tube ID access questions. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 08-01-19, 02:59 PM
imakecircles
Quoted: 17 Post(s)
Wow, thanks all for the informative responses! Sounds like the general consensus is that drilling larger holes won't affect the frame's riding character noticably and will aid in the ability to vent moisture and apply steel treatments to the inside of the frame.
Andy, you mentioned your painter's preferences. Are there implications for painting that I haven't considered?
Old 08-01-19, 07:41 PM
Andrew R Stewart
Maybe. Your cover will sell your book. People look at the paint job as the first (and often the last) aspect in determining the grade of your work. So if you want your work to be highly thpught of you need a nice paint job. For that you need a painter who wants to do a good job. For that you want a painter who isn't finding reasons to not work on your job.
I have had about 13 different painters over the years (including myself early on) and learned that making their job easier made my bikes look better. So when you have "hidden" vent hole locations, when sand or stripper chemicals are trapped in tubes and that perfect combo of time/heat/air pressure/position hasn't been found then the paint starts the hidden **** finds it's way out and onto the wet paint Don't assume that a list of the vent locations are going to be followed 2 months later when the painter is applying that last coat of clear. Or when a dip tank fluid can't drain and keeps dribbling out of a tube's single vent over time.
Either a tube should be completely sealed off or have two vent holes. Andy
AndrewRStewart
Old 08-02-19, 01:46 PM
imakecircles
Quoted: 17 Post(s)
OK, thanks for the great advice! I had definitely not looked that far ahead.
jayd2
Framebuilders
9
10-13-14 10:06 PM
dedhed
Framebuilders
6
09-15-13 05:44 PM
Contour
Framebuilders
8
06-25-12 06:16 PM
RoboMonkey
Framebuilders
13
10-31-11 03:46 PM
unterhausen
Framebuilders
13
08-07-10 07:47 AM
