Go Back  Bike Forums > Bike Forums > Fatbikes
Fat tires - can you put them on any bike?
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 08-02-19, 07:48 PM
KittyBikes
KittyBikes's Avatar
Quoted: 11 Post(s)
Liked 6 Times in 2 Posts
Hey all -
This may be a dumb question, but even though I am terrible at it, I enjoy riding and I'd like to keep riding in Michigan all year long. We sometimes get a significant amount of snow, especially January-March. I have a hybrid bike and it does better than I thought it would on trails and gravel, but I don't think it would handle snow well. Can I just attach the fat tires on my current bike? Do I need to buy new wheels? Or will I end up needing to buy a different bike?
Thanks so much!
KittyBikes is offline
Old 08-02-19, 08:00 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 4078 Post(s)
Liked 548 Times in 342 Posts
You can put conventional MTB wheels and tires on a fatbike, but not the other way around. Fatbikes have completely different axle spacing, because in some cases the rims are 4 inches wide. A fatty front hub is as wide as an MTB rear hub.
So if you want to ride in the snow, start shopping for fatbikes before winter hits.
DrIsotope is offline
Old 08-02-19, 08:18 PM
KittyBikes
KittyBikes's Avatar
Quoted: 11 Post(s)
If I get one, I'm going to try to find something used. I just spent money on a hybrid bike...but I hate exercising indoors for the most park unless its weight lifting. Running/riding on the treadmill/stationary bike is just not for me! Thank you for the info.
Old 08-03-19, 06:10 AM
dabac
Quoted: 845 Post(s)
Liked 17 Times in 15 Posts
What kind of snow are you thinking of?
Fat Bikes are great for semi-packed snow like snowmobile tracks, but not required for hardpack and snow-cleared roads. For stuff like that, regular width tires, preferably studded, will do just fine.
dabac is offline
Old 08-03-19, 06:36 AM
jon c.
Quoted: 1028 Post(s)
Liked 82 Times in 51 Posts
The size of the tire you can use is limited by the clearance at the fork and brake bridge. You can't put fat tires on anything but a fat bike, but you may be able to use a somewhat wider tire and relatively small increases in size can make a difference.
jon c. is offline
Old 08-03-19, 07:19 AM
NYMXer
NYMXer's Avatar
Bikes: Cannondale SuperSix EVO w Hi-Mod frame, Raleigh Tamland 1 and Giant Anthem X
Quoted: 352 Post(s)
The fat bike tire width will not clear the fork or chain stay of a regular width designed bike. I have a fat bike and enjoy riding all year long because I have it. They roll great on the snowmobile trails and ridable up to 4" of snow, but it isn't easy breaking fresh snow first.
NYMXer is offline
Old 08-06-19, 05:22 PM
linigari.1
Fat tires
Not any kind of expert but Iím sure you can slap fat tires on any kind of bike just as long as they fit
linigari.1 is offline
Old 08-06-19, 05:24 PM
terrymorse
climber has-been
terrymorse's Avatar
Bikes: Scott Addict R1
Quoted: 332 Post(s)
Liked 166 Times in 123 Posts
Aye, there's the rub.
Literally.
(I'll let myself out now)
Ride, Rest, Repeat
terrymorse is offline
Old 08-06-19, 05:32 PM
CliffordK
CliffordK's Avatar
Quoted: 9786 Post(s)
Liked 329 Times in 259 Posts
If you have a Hybrid, you can mount "Fatter" tires. Probably. Perhaps 40mm tires + STUDS.
A 26" or 29er MTB might be able to take slightly wider tires. 60mm?
If you really want a FAT bike, then you'll have to get a specific style of bike. Walmart may have some cheap FAT bikes. Maybe not for heavy trail use, but it might be good enough to get a taste for the concept.
CliffordK is offline
Old 08-07-19, 10:14 PM
KittyBikes
KittyBikes's Avatar
Quoted: 11 Post(s)
Literally.
Dad jokes, eh.
Old 08-07-19, 10:24 PM
KittyBikes
KittyBikes's Avatar
Quoted: 11 Post(s)
Hmm. I will have to think about this topic and maybe I will go back to the bike store to see what they think, although I bet they will probably try to sell me another bike if they can, haha.
I live in Central Michigan, so we get a fair amount of snow, the majority of it from January-March. They're not as great about plowing as they should be here, so yes, sometimes the snow is loose and not packed down, and it's icy. I do have an indoor stationary bike for when it's an absolute no-go, but I'd like to get out there as much as I can.
Old 08-08-19, 08:08 AM
qclabrat
qclabrat's Avatar
Quoted: 125 Post(s)
Liked 25 Times in 22 Posts
I have to ask what size were you thinking of?
I'm pretty sure a 4" tire will not fit, even it there is clearance on the fork and frame, the brakes will get in the way if you have non-discs.
Also it's most likely the rims are too narrow for a wider tire. For example plus sized tires of 2.8-3.0" shouldn't run less than 30mm width rims. Too narrow and you risk the tire popping off the rim, which is pretty terrible especially on front wheel.
I do a fair amount of winter riding in NJ, though last year was a bit of a bust, and run 3 types of tires on 3 bikes.
1) 5" tires for when there are several inches of unpacked snow, these are on a dedicated fat bike
2) 3" round studded tires on a 29+ full hardtail bike, great for trail riding, but studs are noisy on the roads and down right sketchy on rock faces
3) 2.1" Nokians for the clear ice days, These are on a regular 29r hardtail
IMO all three are probably an overkill for your needs. Just get a bigger and more aggressive tire which can shed snow pack. Michigan winters can be brutal, if you plan to go out in sub-zero weather, I'd consider getting a bike meant for it.
qclabrat is offline
Old 08-08-19, 08:51 AM
5teve
Quoted: 58 Post(s)
Liked 21 Times in 10 Posts
Me too, in the Lansing area.
If you really want to fit 4" fat tires you will in fact need another bike, so the shop would not be steering you wrong there. But, if you want to ride the bike you have and ride mainly riding for fitness on (sounds like) snow covered roads and pathways, you would be well-served by a set of studded tires sized to fit your hybrid. Something like the Suomi Hakkapeliitta W240 in either 32X 700 or 40X700 size should fit your hybrid fine, assuming it has 700c wheels. (most do) Scroll down here:
https://www.peterwhitecycles.com/studdedtires.php
You local shop may be able to order them for you or something similar. Don't flinch at the price-compared to 4" fat tires (not to mention the wheels and frames made to fit them) they're a bargain. And they'll be slow and heavy, good for getting a quick work out in unpleasant conditions, and when you put your summer tires back on you'll feel like you're flying.
Also, consider trying skiing. Either cross country or downhill, depending on what's available close to you. Or even snowshoeing.
5teve is offline
Likes For 5teve:
Old 08-10-19, 07:49 AM
JonathanGennick
JonathanGennick's Avatar
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 684 Post(s)
Liked 49 Times in 31 Posts
I second this advice so long as we're talking about paved roads -- because my winter experience is pretty much limited to paved. I'm in the central U.P by Lake Superior, and my go to tires in winter are a set of 700 x 38 studded tires on my commuter bike. I ride mainly paved roads and streets that are eventually plowed. There will be times when the snow building gets annoying, or when the ice melts into slush and I struggle, but in the main the pavement is plowed and I'm able to ride regularly.
My other thought is that buying a good set of studded tires is an inexpensive experiment in comparison to buying a second bike. Even if you end up doing both, you probably wouldn't regret having both options available.
JonathanGennick is offline
Old 08-12-19, 10:22 AM
qclabrat
qclabrat's Avatar
Quoted: 125 Post(s)
Do any of you ride on frozen lakes? It's all fun and games till you get too ambitious and loose grip.
Completely different riding and you find yourself running 3-4 psi.
qclabrat is offline
DarKris
Mountain Biking
16
02-08-19 02:08 PM
Happy Onion
Mountain Biking
3
10-27-17 11:03 AM
DaveQ24
Winter Cycling
33
01-02-17 07:22 PM
Clawed
General Cycling Discussion
20
04-18-13 08:31 PM
scale
Winter Cycling
21
11-30-11 04:48 PM
