C&V Heart Rates....
C&V Heart Rates....
Old 10-21-19, 08:42 AM
RobbieTunes
Half drunk? Finish!
RobbieTunes's Avatar
Quoted: 364 Post(s)
Liked 586 Times in 376 Posts
C&V Heart Rates....
Do you "listen?"
How strict are you about the limits?
Is the "220 less your age" a real solid parameter?
Should I write a will?
Of course, mine increases when I see a certain someone, or if Helen Hunt would call me on the phone....
However, I've been taking a lot of grief lately about heart rate. The savvy, experienced (and much faster) cyclists I've been riding with simply don't think it possible. I've swapped HR monitors, but now I'm going to get a Fitbit, because I need a different "report" to see if it really is my Garmin messing up.
On a compact, steel Fiorini, compact 50/34, running hard for 30 miles. 205 average, 250 max. :
2 days later, on a 52/36, steel Wraith, running about the same. 5 lb lighter bike. 177 avg, 221 max.
Seemed safer, but the Fiorini is just so sweet. :
Then, on a 111-miler, which basically took a day. 151 avg, 204 max (Cat 4 climb)
No hurry, as if there should be on a long ride.
Robbie ♪♫♪...☻
I have unfinished business.
RobbieTunes is offline
Old 10-21-19, 08:51 AM
TriBiker19
TriBiker19's Avatar
Bikes: '82 Fuji Supreme, '85 Shogun 200, '87 Centurion Ironman, 89' Centurion Ironman
Quoted: 177 Post(s)
Liked 95 Times in 61 Posts
Which Fitbit model are you considering?
(I can't see those links?)
TriBiker19 is offline
Old 10-21-19, 08:56 AM
RobbieTunes
Half drunk? Finish!
Quoted: 364 Post(s)
Something cheap, as all I want is a 2nd readout on an accurate HR.
People tell me I'm a goner, given my HR.
This while on a 57 mile bike ride, where I'm climbing well and feeling just fine (other than the legs)
Robbie ♪♫♪...☻
Old 10-21-19, 09:06 AM
T-Mar
Quoted: 2747 Post(s)
Liked 232 Times in 203 Posts
IMO, 220 minus your age is a rule of thumb for the average sedentary person who is just starting to exercise. When I was competing, I used to monitor my heart rate routinely and I was always above the recommended bpm. I've had three different HRM over the years and never saw a big difference between them or the results from the lab stress tests that I did.
T-Mar is offline
Old 10-21-19, 09:18 AM
PilotFishBob
My brain hurts!
PilotFishBob's Avatar
Bikes: A few. Define "few".
Quoted: 313 Post(s)
Liked 60 Times in 41 Posts
Some skin tones can throw off optical HR readers, to cross-check if you can get one you should use a chest strap model with electrode contacts for a more accurate measurement.
PilotFishBob is offline
Likes For PilotFishBob:
Old 10-21-19, 09:21 AM
TriBiker19
TriBiker19's Avatar
Quoted: 177 Post(s)
My running partner had a Charge that she didn't mind. It gave her accurate readings--to the point that she figured out she was pregnant by change in heart rate alone. I had an Alta HR and while it was accurate, trying to get the display to pop up was tedious. I've switched to an Apple Watch since.
That rate's quite high. What's your resting rate, though?
Old 10-21-19, 09:22 AM
due ruote
due ruote's Avatar
Quoted: 576 Post(s)
Liked 68 Times in 49 Posts
At the risk of stating the obvious, I would ask a cardiologist.
Is your resting hr also high?
due ruote is offline
Likes For due ruote:
Old 10-21-19, 09:27 AM
USAZorro
Señor Member
USAZorro's Avatar
Quoted: 745 Post(s)
Liked 43 Times in 35 Posts
I once had a HRM that would get wonky on me at times. It would show I was at 160, and then start registering 240. (1.5 times actual)
That said, there can be a huge natural variation in max heartrates. Would be worth verifying your HRM isn't glitchy, but plan B really should be to see a doctor about this.
USAZorro is offline
Old 10-21-19, 09:33 AM
TriBiker19
TriBiker19's Avatar
Quoted: 177 Post(s)
Mine will do that, too. I normally max in the mid 180s and it'll suddenly show that I shot up to the 220s. I reboot it.
But I agree with seeing the doctor.
Old 10-21-19, 09:39 AM
caloso
caloso's Avatar
Quoted: 2019 Post(s)
Liked 438 Times in 244 Posts
220-age works for a large sample of sedentary people. For individual athletes, it's pretty worthless. That said, those spikes above 200 look unusual. Maybe check your HRM battery. I notice I get a lot of crazy spikes when mine is starting to go out.
caloso is offline
Likes For caloso:
Old 10-21-19, 09:59 AM
stardognine
Turquoise gatherer.
stardognine's Avatar
Bikes: 1985 Cannondale ST400
Quoted: 485 Post(s)
Liked 83 Times in 72 Posts
I hope this is the case. 🙂 My BP has always been lower than normal, to the point that nurses or doctors who've checked it, would often do it 2 or 3 times, to make sure. 🤔 Some joked that I was TOO healthy, lol. 😁
stardognine is offline
Old 10-21-19, 10:09 AM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 121 Post(s)
Liked 33 Times in 24 Posts
What's normal for some isn't normal for all. I know people that have a BP of 90/50 consistently and are healthy as a horse while I've been fighting hypertension for 20 plus years. Geez, maybe that's my normal... If you're going hard and not feeling any side effects, I'd just go with it. But like others have said, if you want confirmation that it really is that high, go see a doc. I am curious what your sedentary readings are though.
Bigbus is offline
Old 10-21-19, 10:10 AM
bwilli88
bwilli88's Avatar
Quoted: 481 Post(s)
Liked 45 Times in 33 Posts
I use a mi band 4 and love it, it rarely goes above 150 for me at 63yo.
bwilli88 is offline
Old 10-21-19, 10:16 AM
ryansu
Ride.Smile.Repeat
ryansu's Avatar
Quoted: 613 Post(s)
Liked 215 Times in 166 Posts
in the 2000s I had a Polar 720i that I liked but I sold that when I decided that I was being a slave to data and that made riding a drudge and I wanted it to be fun again, funny that is when I found C&V too. I do a HR BP test in my local RiteAid at a Higi station once a month and rarely push hard enough on rides to worry about max hr, but then again I don't do competitive rides. YMMV
ryansu is offline
Old 10-21-19, 10:54 AM
xiaoman1
xiaoman1's Avatar
Bikes: Paramounts, PX-10s, Mondias, Motobecane Grand Record, Specialized Allez Carbon, and Nishiki Tri-A
Quoted: 411 Post(s)
Liked 95 Times in 76 Posts
RT,
Some medical advice is better left to your cardiologist, not the internet...better to be safe than.....
Best, Ben
xiaoman1 is offline
Likes For xiaoman1:
Old 10-21-19, 11:02 AM
Thalia949
Bikes: Masi Gran Crit, Bianchi Nuova Racing 12V, Eddy Merckx Corsa Extra, Ibis Ripley, Co Motion Tandem, Merlin Agilis, Ritchey Breakaway
Quoted: 8 Post(s)
Liked 10 Times in 7 Posts
+1 to all that recommend a discussion with a physician.
Another consideration could be environmental - I've ridden close to powerlines and had them interfere with my HRM, although it returned to normal.
Lastly - a bit old school but do the artery / stopwatch check. Check your pulse, either from your wrist or neck for 20 seconds and then times three to get your HR. This should give you some directional info if your monitor is accurate.
Thalia949 is offline
Likes For Thalia949:
Old 10-21-19, 11:08 AM
squirtdad
squirtdad's Avatar
Quoted: 929 Post(s)
Liked 133 Times in 104 Posts
Not sure....gut says if feels high
agree with check doc...probably best is you can find a doc with sports background....
Questions
What garmin?
Is it wrist based?
If it is wrist based and you can also use a chest band have you tried that?
Another test is using your smart phone to check you pulse and compare or a home blood pressure machine and of course there is always getting a pulse from the carotid artery
what is your resting heart rate?
FWIW
I am using a garmin Fenix 5x (had a garmin vivoactive Hr before)
over all is seems accurate using the cell phone and blood pressure monitor tests
I once in a while get spikes on the high end. I gut check by how I feel I am breathing and heart pounding
more often i get low reading for a part of the morning commute
squirtdad is offline
Old 10-21-19, 11:27 AM
bikemig
bikemig's Avatar
Quoted: 3961 Post(s)
Liked 275 Times in 219 Posts
I like the fitbit charge 3 a lot. I keep meaning to use the heart rate function on my GPS but I never seem to put on my strap before going on a ride. The fitbit does a good job of telling me the zones I'm in after the ride. The only downside--and it's not much of one--is that the fitbit does a poor job of translating time on the bike to "steps."
bikemig is offline
Old 10-21-19, 11:49 AM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Lots. Just...lots.
Quoted: 1123 Post(s)
Liked 91 Times in 67 Posts
Robbie, you and I have had this discussion before, and our max & average heart rates are miles apart.
My resting is in the mid 60's, max is around 170 but I don't go that high on a ride, maybe 155 and an average of 130-ish.
Agree with many others here, go see a doctor and find out if your heart rate is being accurately measured and/or is problematic.
Have him do a stress test.
rccardr is offline
Old 10-21-19, 12:01 PM
Wildwood
Veteran/Pacifist/Resister
Wildwood's Avatar
Quoted: 1931 Post(s)
Liked 217 Times in 160 Posts
At 68, my resting is low-mid 40s.
5 years ago a friend loaned me his HRM with chest strap, I couldn't get above 165 on mostly flat terrain. I haven't used one lately, nor in the mountains.
2 doctors have asked me why i want to evaluate my max.
Last treadmill stress test at the hospital, the tech refused to allow me to exceed 150, which is 220 - age (approx).
edit: no Rx meds.
re-edit: Last time I was in GJ, CO at 5,000 ft - I couldn't suck enough air, even after 4 days with gentle acclimatizing rides. Any steep climbs had me stopping frequently. Reason = a heart/respiration rate I couldn't sustain. No chest pains, just no air. That would be the environment where I'd best check max, if I cared. That trip, I did ride the Monument and from Mesa to PowerHorn and out to Vega(?) park, plus the littler rides. Guess I heard those drs in my head - why put yourself at ANY risk of chest pain? - unless you are still racing for a living or the ego, or the thrill of it?!?
Remember my age - my opinions are based on being older - everyone defines that for themselves.
For healthiness they say you can get 90% efficiency in 'fitness' with no more than 8-10 hours training/week.
Not all of it has to be hardcore HIITs, some prefer more mellow LSD sessions.
YMMV
Wildwood is offline
Old 10-21-19, 12:08 PM
crank_addict
crank_addict's Avatar
Quoted: 1167 Post(s)
Liked 139 Times in 91 Posts
C&V heart rates...... hmmmm.....
Even at her age of 65.... Christie Brinkley.
Good day!
crank_addict is offline
Likes For crank_addict:
Old 10-21-19, 12:15 PM
smontanaro
Bikes: many
Quoted: 496 Post(s)
Liked 44 Times in 35 Posts
I recently started using a heart rate monitor and have been pondering the same sort of questions. 220-age tells me mine is 155. I routinely run above 130 on a ride and can get into the 150s on modest hills. My resting HR is in the high 40s, so in theory I have a fair amount of room between resting and max.
What exactly does "max heart rate" mean (ignoring the rule-of-thumb equation)? Is it the fastest your sinus node will tick, does it reflect some level above which your heart loses efficiency, or does it represent some sort of danger level (risk of throwing a clot or some major electrical malfunction)?
smontanaro is offline
Old 10-21-19, 12:17 PM
Slightspeed
Slightspeed's Avatar
Quoted: 565 Post(s)
Liked 246 Times in 153 Posts
I'm on Metoprolol beta blocker for aortic stenosis. Its like a speed governor on an old U-Haul. I usually average 108-110 and peak is usually below 140 bpm. My resting HR is in the low to mid 40s. My cardio doctor told me average HR is more important than max bpm on a ride - as long as it comes back down when you back off. I'm 70, in decent shape, usually 14-16 mph average speed. I am an ex racer, but that was 50 years ago. Before the beta blocker, I would max about 165 bpm, but not come down for a very long time. I have less power now, but like the fact that I may live longer to enjoy it. I use a Garmin 810 with chest strap, and wear a Garmin Vivosmart watch with HR as a backup.
Slightspeed is offline
Old 10-21-19, 12:51 PM
jimincalif
Bikes: '96 Trek 850, '08 Specialized Roubaix Comp, '18 Niner RLT RDO
Quoted: 531 Post(s)
Liked 54 Times in 35 Posts
How old are you? Did I miss that?
As others said, 220-age is just a rough starting point to estimate max HR. I use a Garmin chest strap. Most of the time it is pretty accurate, but it sometimes reads wonky when I first start out.
My wife has a fitbit, its HR readings when she rides are not much better than a WAG. It is a bit more reliable when she's on the treadmill, but cycling it's not even close, she will climb a hill at max exertion and the fitbit will show 85. If I take her pulse it's more like 150.
FYI I'm age 61, just under 200#, my resting HR is about 48-50, looking at my Garmin data over the last 12 months, my average HR is 120, my average max HR per ride is 165, my highest HR is 177.
A couple riders in our club, similar age, were seeing rates north of 200, turns out they have AFib. See a doctor and get properly checked out.
jimincalif is offline
Old 10-21-19, 01:00 PM
caloso
caloso's Avatar
It literally means your maximum heart rate: the fastest your heart can beat. I don't use a formula, I use my observed highest HR. Whether it represents some sort of danger is a separate question.
caloso is offline
Likes For caloso:
