Cannondale ST Frameset
58cm frame fork and headset, a few chips that have been touched up and a couple
small areas that looks like small bit of corrosion. $165 shipped, please add PayPal or f/f SOLD
I found a smaller frame that fits better.
Semper fi
Semper fi
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Looks like an 86. Serial number starts with 23?
Yep, I think this is just what I have been waiting for to swap my components to from a frame that's too large! And I'm guessing maybe it's a little earlier, like an '84, seems to be without the mid fork mounts...
The frame is actually a 62cm to the top of the seattube, 58cm to top of toptube.
Semper fi
Semper fi
Anybody here that can recommend me a good FD for this frame w/triple? My parts donor is a steel frame and the current (Suntour AR) has a fixed clamp that will be too small. Believe these Cannondales should be a 31.8 clamp size.
Believe these originally came with Cyclone IIs mounted but all the ones I see are 28.6 clamp size. The steel band clamp looks easily swap-able thou, just don't know if these are easy to find...
Quoted: 1872 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Likes For mountaindave:
Thanks for any advice...
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
Well, if you can view this in desktop mode, you’ll see my sig which has a link to pictures of my Trek 710 running first gen Cyclone with a triple. Granted, it’s a half-step plus granny (50-45-28), but that’s still technically a triple. Edit: I see you’re trying to run exactly the same thing!
I couldn’t guarantee your setup would run just any triple from my armchair, but I also wouldn’t hesitate to try it out.
