Power meter and calorie counting?
Disco Infiltrator
I've been idly shopping for a power meter. I'm curious other than doing the math independently, do any of the popular calorie counting apps (like say My Fitness Pal) receive and use the power data to calculate calories burned? I haven't used it in a while, so maybe it's more clever now, but it used to get time and distance from Strava and shunt the workout into a bracket by speed - no accounting for type of bike, type of terrain, or elevation.
Genesis 49:16-17
Genesis 49:16-17
Not sure what fields myfitnesspal pulls, anytime I've used it, it's been manual entries and I've just used the kj metric from my ride file, which is approximately equivalent to calories burned
All these apps seem pretty well connected. MyFitnessPal takes Calories from Garmin Connect. If you have a powermeter Garmin uses kJ for Calories. Once you connect Garmin to Myfitness the transfer is automatic.
Likes For gregf83:
Bikes: Giant Toughroad SLR1 and Motobecane Sturgis NX
Quoted: 712 Post(s)
Liked 51 Times
There is a lot of metabolism going on between the calories in the food you eat and the output energy of your legs. You also don't measure any core and upper body and heart and lungs energy.
With other words, depending an all the digestion and metabolism inefficiencies and auxiliary needs you could put out 500 calories out of your legs, but that may mean 2,000 calories eaten. Or 1,000, or 3,000.
Quoted: 9458 Post(s)
Liked 960 Times
My experience has been that over a period of weeks/months if I carefully count Calories in and out that the resulting weight loss is very close to predicted. It doesn't work very well at the daily level as changing the sodium intake will result in large weight swings due to water retention but these cancel out over time.
Likes For gregf83:
Quoted: 2027 Post(s)
Liked 448 Times
There has been a tremendous amount of research on this. Riding a road bike, there isn't much difference between any two humans in terms of metabolic efficiency. That's not true with a lot of exercise, but in cycling, you just don't have the opportunity to waste much energy that can't be accounted for. You clip your feet into pedals and turn them in circles, always the same size. A power meter measures physical work done, and "converting" that to calories burned has a maximum error of about 5%. If your power meter says you burned 500 kCal, the truth might be anywhere from 487 to 513 kCal. The +/- is like 1/4 of an oreo.
Likes For caloso:
I suspect that, for most people, using a power meter as part of a weight loss plan is a chance to play with a new toy. Racers and long distance tourists might be the exception, as they're likely trying not to lose too much, too fast. If you just link power meter output and additional food input, you'll gain weight.
Far better to spend that time planning meals, and cooking real food, and figuring out how to avoid grabbing random junk food and stuffing your face when you're bored. That business of eating 500-1,000 calories a day less than your body needs to maintain its current weight? Old-fashioned, tired, not much fun; oh, and it works.
Likes For redlude97:
Well, the best success I've had losing weight involves calculating baseline metabolism (based on body weight), ignoring calories burned off through exercise, and basing my caloric intake on that (less 500 calories a day). Adding in any kind of exercise allowance reduced the weight loss, as you might expect. No need for PM, HR or software based guesses (although I agree some of those are ridiculously high).
Disco Infiltrator
Thanks everyone
Genesis 49:16-17
Genesis 49:16-17
Liked 448 Times
Yeah, I don't understand how ignoring additional, reliable data is better.
Likes For caloso:
Liked 960 Times
You don't have to choose between using a power meter and eating well. Looking at a single data point from the summary of a ride doesn't take any time away from preparing quality food.
If you're riding 20 miles a week it's not going to hurt anything to ignore that, but at some point undereating has real consequences for your energy and fitness levels, and your overall health.
When I'm going through high intensity training blocks, I don't count calories for the most part. My goal during these periods is to maintain weight. A couple pounds +/- isn't a big deal. The goal is not to hinder the performance improvement by underfueling.
Then there are times in the year that I dedicate to weight loss. Long, low intensity rides where I'm mostly burning fat. No insulin spike when I get home, so I can just go about my day as if I hadn't ridden at all. Easy 1500 kCal caloric deficit for that day.
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 390 Post(s)
Liked 88 Times
FWIW, in 2010 I weighed 325 lbs. In 2013 I weighed 165 lbs. Today I weigh 165 lbs. Power meter is a great way to get quantifiable data on how much you're burning. Food tracking apps are a great way to get quantifiable data on how many calories you are putting into the system. Think of it as trying to make a budget if you only know your income but not your expenses.
To the OP - most apps will use power meter data to give you a reasonably accurate estimate of calories burned on the bike - FAR more accurate than the estimates they give without PM data.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Quoted: 712 Post(s)
Liked 51 Times
I'm curious how all the people before "civilization" maintained their weight and avoided all the civilisation diseases (e.g. heart, diabetes,) without having power meters, calorie counters or any knowledge of metabolism? Same with animals in the wild.
For me, adding an extra 1000+ Cals/Day of consistent exercise makes it much easier to maintain a 500 Cal/day deficit. I can even have a beer or two which is difficult to do without exercise. Of course you can do it but you end up sacrificing nutrition.
Remember how Lance Armstrong famously weighed everything he ate? Do you do that? (I don't.) Research has shown that most people underestimate what they eat, and overestimate how much they burn. Even if you figure out (to within 10%) how much you burn on your bike, consider that people who exercise generally depress their basal metabolism the rest of the day; so 1,000 calories burned on the bike doesn't mean an automatic 1,000 calories less burned in 24 hours.
For a full picture (information, as above), you'd need to live in a metabolic measurement chamber. Or check your weight regularly and compare weight today to a month ago, or a month from now. A good scale is cheaper than a power meter, and gives better information over the long term.
Every day this week I've burned an extra 1400+ Cals/day from commuting. Using your approach I'd be running a deficit of 1900 Cals/day. I don't think I could manage that.
Second, congratulations on your commuting. You must burn twice as much as I do on my 20 mile round trip. I consistently come up with about 700 calories/day on the power meter when I commute; of course, the old 3 miles = 100 calories rule of thumb gives me similar results.
Third, I agree with you that running a 1,900 calorie a day deficit isn't sustainable. I tried something similar for the first month and a half on my cross country tour. Lost weight, but I was miserable and not very pleasant, I fear. Giving up an avoiding sugar, and adding a dessert every day, and I enjoyed the rest of the trip much more.
However, I'll argue that your 1,400 calories per day commute is substantially longer or harder than most bike commuters (check the bike commuter forum for examples). I think my initial post had that covered, you're obviously not "most people."
Liked 960 Times
I don't think most bike commuters are reading the training forum either.
Personally I don't commute at all, I'm lucky enough to work from home. But I enjoy long rides, where I cover a lot of ground and see different neighborhoods and backgrounds. 1,100 kJ in a day is typical for me (except during time of injury) between lunch and after work rides. I don't think @gregf83 is very unusual among people in this forum.
Newbie racer
Bikes: Propel, red is faster
Quoted: 590 Post(s)
Liked 241 Times
So you commute about 20mi each way to work at about 200w avg (including coasting)?
That would be 1400 per day.
Meaning you’re commuting both ways at probably over 220w NP. Unless you’re a cat 1 racer in zone 1 the whole time you’d be showering twice a day from that.
That doesn’t seem right.
