Go Back  Bike Forums > Bike Forums > Framebuilders
Stem spacer material
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Old 10-31-19, 10:38 AM
mikeread
Quoted: 27 Post(s)
Liked 8 Times in 3 Posts
When I assembled my new frame a few months back, I machined a one piece tapered steerer/stem spacer from a piece of delrin/acetal. The stock spacers I had were very clumsy looking.
At the time I did consider the material choice and concluded that being loaded in compression only it would be fine. Carbon spacers are commonly used, the epoxy giving the compressive strength and in this respect delrin must be about comparable with Epoxy. I chose delrin over alloy as it is black and will not tarnish.
I have been riding the bike for months now with no problem, no loosening of the headset etc, but for some reason I am now having doubts. Does anyone have a view on this?
Spacer can be seen in this pic:
mikeread is offline
Old 10-31-19, 12:33 PM
unterhausen
Randomhead
Liked 94 Times in 80 Posts
I am somewhat biased against that just because I would worry it would break.
I have used aluminum and stainless tubing.
unterhausen is offline
Old 10-31-19, 12:39 PM
mikeread
Quoted: 27 Post(s)
It is not going to break, I was thinking it might have a little 'give' allowing the stem to rotate more under impact and flex the steerer tube.
mikeread is offline
Old 10-31-19, 01:31 PM
motorapido
Bikes: 1976 Schwinn Super Le Tour, tricked out with modern components. Shimano Alfine 11 internal gear hub. Dynamo hub. Titanium racks and bottle cages. Mercier Kilo Wide Tire dropbar singlespeed
Quoted: 41 Post(s)
Great idea
I wish I could buy single piece tall spacers. I have an uncut steerer on a touring bike for comfortable more upright positioning (my personal preference isn't common or popular, I know) and the stacked spacers I use tend to produce pop and crackle noises now and then depending on terrain and speed. A tall single piece spacer would solve this. Hmm. I'll start my home brew plans.
motorapido is offline
Old 10-31-19, 02:35 PM
tyrion
tyrion's Avatar
Bikes: Breezer Radar
Quoted: 1303 Post(s)
Liked 166 Times in 107 Posts
There's not much pressure on spacers, is there - just whatever you preloaded it to be, right?
I'm no engineer, but it wouldn't bother me.
tyrion is offline
Old 10-31-19, 03:55 PM
Nessism
Nessism's Avatar
Bikes: Homebuilt steel
Quoted: 164 Post(s)
Liked 25 Times in 21 Posts
It wouldn't bother me either. Sounds like a good idea even. I sweat a lot and corrosion develops on the stem and spacers creating creaking noises and even corroding the spacer to the steerer tube. Chris King headsets have these thin plastic washers that help that situation but a plastic spacer would be even better I think.
Nessism is offline
Old 10-31-19, 04:19 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 4062 Post(s)
Liked 539 Times in 335 Posts
I turned a one-piece bearing cap + spacer for my wife's bike out of Delrin-- and not even real delrin, but generic acetal homopolymer from McMaster-- and it's been on the bike for over 5 years.
Delrin is outstandingly strong, and should (and does) serve perfectly well as stem spacer material. I mean c'mon, I have some FSA branded spacers here made of acrylic.
DrIsotope is online now
Old 10-31-19, 06:50 PM
Canaboo
Quoted: 17 Post(s)
From a plastic supplier:
Delrin behaves like most engineering materials in that as temperature increases, elongation increases and strength decreases. Delrin has a tensile strength at room temperature of 10,000 psi, no true yield point and a stiff flexural modulus of 410,000 psi.
Delrin has outstanding fatigue resistance, almost indefinitely withstanding cyclic compressive/tensile stressing 5,000 psi.
Delrin does not permanently deform or retain dents, and has good impact toughness. The higher molecular weight resin formulations will deliver even greater toughness.
The Delrin-steel coefficient of friction is very low (0.1-0.3), and friction values remain virtually unchanged over a wide range of temperatures, loads and relative surface speeds
Sounds like more spacers should use this material.
Canaboo is offline
Likes For Canaboo:
Old 11-01-19, 02:34 AM
mikeread
Quoted: 27 Post(s)
OK I am happy now, the spacer stays.
mikeread is offline
Old 11-05-19, 06:29 PM
Canaboo
Quoted: 17 Post(s)
Delrin spacers are actually available it turn out.
Canaboo is offline
Old 11-06-19, 01:59 AM
mikeread
Quoted: 27 Post(s)
Lighter than Carbon too - result!
Everything has been done before.
mikeread is offline
Old 11-08-19, 02:16 PM
TiHabanero
Quoted: 870 Post(s)
Liked 132 Times in 89 Posts
I have a Cadex frame cut up into pieces that were used in another project and I plan on using some of the tubes to make a single spacer around 30mm in length. Should work just fine. Though of using PVC pipe, but ID does not fit the steerer.
TiHabanero is offline
